Come da vostre indicazioni rimetto gli esiti dell'analisi di detect x.
Un dubbio: ho eseguito l'analisi quando il kernel_task è 3
V bene comunque o devo fare l'analisi quando il kernel sale e il retro iMac scalda?
Grazie del vostro tempo dedicatomi, innanzitutto.
Nino
Running Processes:
PPID PID %CPU USER COMMAND
0 1 0.6 root /sbin/launchd
1 135 0.0 root /usr/sbin/syslogd
1 136 0.0 root /usr/libexec/UserEventAgent (System)
1 138 0.0 root /Library/PrivilegedHelperTools/com.bombich.ccchelper
1 139 0.0 root /Library/PrivilegedHelperTools/com.crystalidea.macsfancontrol.smcwrite
1 140 0.0 root /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/RTProtectionDaemon.app/Contents/MacOS/RTProtectionDaemon -i 062A9D2E-AAF7-41CF-A6C2-53F314C18CE3.pkg
1 142 0.0 root /System/Library/PrivateFrameworks/Uninstall.framework/Resources/uninstalld
1 143 0.0 root /usr/libexec/kextd
1 144 0.0 root /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
1 145 0.0 root /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
1 149 0.0 root /usr/sbin/systemstats --daemon
1 150 0.0 root /usr/libexec/configd
1 151 0.0 root endpointsecurityd
1 152 0.0 root /System/Library/CoreServices/powerd.bundle/powerd
1 156 0.0 root /usr/libexec/logd
1 157 0.0 root /usr/libexec/keybagd -t 15
1 160 0.0 root /usr/libexec/watchdogd
1 164 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
1 165 0.0 _iconservices /System/Library/CoreServices/iconservicesd
1 166 0.0 root /usr/libexec/diskarbitrationd
1 169 0.0 root /usr/libexec/coreduetd
1 170 0.0 root /Library/aruba/bin/convert -f
1 173 0.0 root /usr/libexec/opendirectoryd
1 174 0.0 root /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
1 175 0.0 root /System/Library/CoreServices/launchservicesd
1 176 0.0 _timed /usr/libexec/timed
1 178 0.0 _usbmuxd /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd -launchd
1 179 0.0 root /usr/sbin/securityd -i
1 180 0.0 root auditd -l
1 182 0.0 _locationd /usr/libexec/locationd
1 185 0.0 root autofsd
1 186 0.0 _displaypolicyd /usr/libexec/displaypolicyd -k 1
1 187 0.0 root /usr/libexec/dasd
1 189 0.0 root /usr/libexec/PerfPowerServices
1 191 0.0 root /System/Library/CoreServices/logind
1 192 0.0 root /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
1 193 0.0 root /usr/sbin/KernelEventAgent
1 195 0.0 root /usr/sbin/bluetoothd
1 197 0.6 _hidd /usr/libexec/hidd
1 198 0.0 root /usr/libexec/sandboxd
1 199 0.0 root /usr/libexec/corebrightnessd --launchd
1 200 0.0 root /usr/libexec/AirPlayXPCHelper
1 201 0.0 root /usr/libexec/amfid
1 202 0.0 root /usr/sbin/notifyd
1 203 0.0 _distnote /usr/sbin/distnoted daemon
1 205 0.0 root /System/Library/CoreServices/coreservicesd
1 206 0.0 root /usr/sbin/cfprefsd daemon
1 207 0.0 root aslmanager
1 208 0.0 root /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd system
1 209 0.0 [U502] /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow console
1 216 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
1 217 0.0 _analyticsd /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
1 245 0.0 root /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/contextstored
1 252 0.0 _coreaudiod /usr/sbin/coreaudiod
1 254 0.0 root /usr/libexec/nehelper
1 256 0.0 root /usr/libexec/lsd runAsRoot
1 258 0.0 root /usr/libexec/trustd
1 268 0.0 root /usr/libexec/searchpartyd
1 282 0.0 root /usr/libexec/syspolicyd
1 296 4.0 _windowserver /System/Library/PrivateFrameworks/SkyLight.framework/Resources/WindowServer -daemon
1 297 0.0 _mdnsresponder /usr/sbin/mDNSResponder
1 298 0.0 _coreaudiod /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
1 305 0.0 root /usr/sbin/mDNSResponderHelper
1 310 0.0 root /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
1 311 0.0 root /usr/libexec/mobileassetd
1 312 0.0 root /usr/libexec/airportd
1 313 0.0 _locationd /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 314 0.0 _locationd /usr/libexec/secinitd
1 315 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper -launchd
1 318 0.0 _networkd /usr/libexec/symptomsd
1 319 0.0 _locationd /usr/sbin/cfprefsd agent
1 320 0.0 _locationd /usr/libexec/trustd --agent
1 321 0.0 root /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar -daemon
1 324 0.0 _coreaudiod /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 325 0.0 _nsurlsessiond /usr/libexec/nsurlsessiond --privileged
1 326 0.0 root /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
1 327 0.0 root /usr/libexec/apfsd
1 329 0.1 root /usr/libexec/usbd
1 331 0.0 root /usr/libexec/firmwarecheckers/ethcheck/ethcheck --integrity-check-daemon
1 332 0.0 _cmiodalassistants /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/Resources/VDCAssistant
1 334 0.0 root /usr/libexec/taskgated
1 346 0.0 root /Library/Application Support/com.bombich.ccc/Frameworks/CloneKit.framework/Versions/A/XPCServices/CloneKitService.xpc/Contents/MacOS/CloneKitService
1 347 0.0 root /usr/libexec/diskmanagementd
1 353 0.0 root /usr/libexec/ApplicationFirewall/socketfilterfw
1 368 0.0 root /usr/libexec/runningboardd
1 376 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
1 377 0.0 root /usr/libexec/thermald
1 380 0.0 root /usr/libexec/secinitd
1 383 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.activity -d -q
1 387 0.0 root /Library/Apple/System/Library/CoreServices/XProtect.app/Contents/XPCServices/XProtectPluginService.xpc/Contents/MacOS/XProtectPluginService
1 391 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
1 402 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.ext
152 408 0.0 root /usr/libexec/ioupsd
1 410 0.0 root /usr/libexec/colorsync.displayservices
1 411 0.0 root /usr/libexec/colorsyncd
1 412 0.0 root /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
1 415 0.0 _appleevents /System/Library/CoreServices/appleeventsd --server
1 418 0.0 root /usr/libexec/bootinstalld
1 421 0.0 root /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 427 0.0 root /usr/sbin/distnoted agent
1 432 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.daemon -q
1 436 0.0 _netbios /usr/sbin/netbiosd
1 446 0.0 root /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 447 0.0 root /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
1 451 0.0 root /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/SettingsDaemon.app/Contents/MacOS/SettingsDaemon
1 452 0.0 root /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp -d
1 455 0.0 root /usr/sbin/systemsoundserverd
1 457 0.0 root /usr/libexec/findmydeviced
1 458 0.0 _ctkd /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -s
1 489 1.2 root /usr/libexec/sysmond
149 494 0.0 root /usr/sbin/systemstats --logger-helper /private/var/db/systemstats
1 495 0.0 root /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
1 522 0.0 _locationd /usr/sbin/distnoted agent
1 579 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.fileshield
1 585 0.0 root /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
1 619 0.0 [U502] /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 620 0.0 [U502] /usr/sbin/cfprefsd agent
1 626 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.proxy
1 631 0.0 root /usr/libexec/securityd_service
1 632 0.0 root /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
1 647 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.securedns
1 692 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.hns -q
1 712 0.0 root /Applications/Avast.app/Contents/Backend/services/com.avast.service -q
1 720 0.0 root /usr/sbin/spindump
1 721 0.0 root /System/Library/CoreServices/SubmitDiagInfo server-init
1 816 0.0 [U502] /usr/libexec/UserEventAgent (Aqua)
1 818 0.0 [U502] /usr/sbin/distnoted agent
1 819 0.0 [U502] /System/Library/PrivateFrameworks/CloudServices.framework/Helpers/com.apple.sbd
1 820 0.0 [U502] /usr/sbin/universalaccessd launchd -s
1 821 0.0 [U502] /usr/libexec/knowledge-agent
1 822 0.0 [U502] /System/Library/CoreServices/talagent
1 823 0.0 [U502] /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
1 824 0.0 [U502] /usr/libexec/secd
1 825 0.0 [U502] /usr/libexec/trustd --agent
1 826 0.0 [U502] /usr/libexec/lsd
1 827 0.0 [U502] /System/Library/CoreServices/backgroundtaskmanagementagent
1 828 0.0 [U502] /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
1 829 0.0 [U502] /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
1 830 0.0 [U502] /usr/libexec/pboard
1 831 0.0 [U502] /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
1 832 0.0 [U502] /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
1 833 0.0 [U502] /usr/libexec/rapportd
1 834 0.0 [U502] /usr/libexec/routined LAUNCHED_BY_LAUNCHD
1 835 0.0 [U502] /usr/sbin/usernoted
1 836 0.0 [U502] /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter -L
1 837 0.0 [U502] /System/Library/CoreServices/lockoutagent
1 838 0.0 [U502] /usr/libexec/networkserviceproxy
1 839 0.0 [U502] /usr/libexec/nsurlsessiond
1 840 0.0 [U502] /System/Library/CoreServices/APFSUserAgent
1 841 0.0 [U502] /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
1 842 0.0 [U502] /usr/libexec/secinitd
1 843 0.0 [U502] /usr/libexec/dmd
1 844 0.0 [U502] /System/Library/PrivateFrameworks/ScreenTimeCore.framework/Versions/A/ScreenTimeAgent
1 845 0.0 [U502] /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/ContextStoreAgent
1 846 0.0 [U502] /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
1 847 0.0 [U502] /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
1 848 0.0 [U502] /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
1 849 0.0 [U502] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
1 851 0.0 [U502] /usr/libexec/adprivacyd
1 853 0.0 [U502] /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
1 854 0.0 [U502] /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
1 855 0.0 [U502] /System/Library/PrivateFrameworks/HomeKitDaemon.framework/Support/homed
1 856 0.0 [U502] /usr/libexec/nsurlstoraged
1 857 0.0 [U502] /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
1 858 0.0 [U502] /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
1 859 0.0 [U502] /usr/libexec/swcd
1 860 0.0 [U502] /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 861 0.0 root /usr/sbin/WirelessRadioManagerd
1 863 0.0 [U502] /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
1 864 0.0 [U502] /usr/libexec/spindump_agent
1 865 0.0 [U502] /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
1 866 0.0 [U502] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 867 0.0 [U502] /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
1 871 0.0 [U502] /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
1 872 0.0 [U502] /usr/libexec/pkd
1 873 0.0 [U502] /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
1 874 0.0 [U502] /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -tw
1 876 0.0 [U502] /System/Library/CoreServices/sharedfilelistd
1 879 0.0 [U502] /System/Library/CoreServices/iconservicesagent
1 880 0.0 [U502] /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
1 882 0.0 [U502] /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
1 884 0.0 [U502] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
1 886 0.0 [U502] /System/Library/PrivateFrameworks/AMPDevices.framework/Versions/A/Support/AMPDeviceDiscoveryAgent --launchd
1 889 0.0 [U502] /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
1 894 0.0 [U502] /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
1 896 0.0 [U502] /Library/CoreMediaIO/Plug-Ins/DAL/EpocCamPlugin.plugin/Contents/Resources/EpocCam.app/Contents/MacOS/EpocCam
1 897 0.0 [U502] /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
1 899 0.0 [U502] /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri launchd
1 901 0.0 [U502] /System/Library/Image Capture/Support/icdd
1 902 0.0 [U502] /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/FrontendAgent.app/Contents/MacOS/FrontendAgent
1 903 0.4 [U502] /Applications/Dike.app/Contents/MacOS/Dike -o NO_SHELL -f NO_MAIN_WIN
1 905 0.0 [U502] /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
1 907 0.0 [U502] /usr/libexec/sharingd
1 908 0.0 [U502] /Library/bit4id/hid/convert -f
1 909 0.0 [U502] /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent --launchd
1 910 0.0 [U502] /System/Library/CoreServices/cloudpaird
1 911 0.0 [U502] /System/Library/CoreServices/diagnostics_agent
1 912 0.0 [U502] /System/Library/CoreServices/TextInputMenuAgent.app/Contents/MacOS/TextInputMenuAgent
1 915 0.0 [U502] /Library/Printers/Canon/CUPSCAPT2/BackGrounder/Canon CAPT BackGrounder.app/Contents/MacOS/Canon CAPT BackGrounder
1 917 0.0 [U502] /System/Library/PrivateFrameworks/AppleMediaServices.framework/Resources/amsaccountsd
1 919 0.0 [U502] /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
1 920 0.0 [U502] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
1 921 0.0 [U502] /Users/[U502]/Applications/Macs Fan Control.app/Contents/MacOS/Macs Fan Control
1 922 0.0 [U502] /Library/Apple/System/Library/CoreServices/XProtect.app/Contents/XPCServices/XProtectPluginService.xpc/Contents/MacOS/XProtectPluginService
1 923 0.0 [U502] /usr/libexec/WiFiVelocityAgent
1 931 0.0 root /usr/libexec/wifivelocityd
1 935 0.0 [U502] /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService
1 940 0.0 [U502] /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
1 941 0.0 [U502] /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
1 942 0.0 root /usr/sbin/filecoordinationd
1 951 0.0 [U502] /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 952 0.0 [U502] /System/Library/Frameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
1 953 0.0 [U502] /System/Library/CoreServices/pbs
1 954 0.0 [U502] /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
1 971 0.0 root /System/Library/CoreServices/CrashReporterSupportHelper server-init
915 972 0.0 [U502] (ccpd)
1 973 0.0 root /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
1 974 0.0 [U502] /Library/Printers/Canon/CUPSCAPT2/CCPD/ccpd
1 975 0.0 [U502] /System/Library/PrivateFrameworks/AppSSO.framework/Support/AppSSOAgent.app/Contents/MacOS/AppSSOAgent
1 977 0.0 [U502] /System/Applications/Mail.app/Contents/MacOS/Mail
1 978 0.0 [U502] /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent
974 984 0.0 [U502] /Library/Printers/Canon/CUPSCAPT2/CCPD/ccpd
984 985 1.0 [U502] captmoncnac8 --data-write-fd=4 --data-read-fd=11 --cmd-write-fd=12 --cmd-read-fd=15 --output-fd=-1 --input-fd=-1 --printer-uri=usb://Canon/LBP5050?serial=0000A1B071IC
1 1016 0.0 [U502] SafeEjectGPUAgent
1 1017 0.0 [U502] /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
1 1018 0.2 [U502] /Applications/Safari.app/Contents/MacOS/Safari
1 1023 0.0 [U502] /Applications/Avast.app/Contents/MacOS/Avast -standaloneInstanceAllowed YES
1 1027 0.0 [U502] /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
1 1043 0.0 [U502] /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
1 1044 0.0 [U502] /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
1 1049 0.0 [U502] /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled
1 1053 0.0 [U502] /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 1054 0.0 [U502] /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 1055 0.0 [U502] /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
1 1058 0.0 [U502] /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
1 1059 0.0 root /Applications/Avast.app/Contents/XPCServices/com.avast.av.api.xpc
1 1060 0.0 [U502] /Library/Application Support/AvastHUB/com.avast.hub.app/Contents/MacOS/com.avast.hub
1 1061 0.0 [U502] /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 1062 0.0 [U502] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
1 1067 0.0 [U502] /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
1 1068 0.0 [U502] /usr/libexec/fmfd
1 1069 0.0 [U502] /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1060 1072 0.0 [U502] /Library/Application Support/AvastHUB/com.avast.hub.app/Contents/Helpers/com.avast.hub.worker /Users/[U502]/Library/Application Support/AvastHUB/run/8E44F220-5740-404C-9699-6C0580989B3D
1 1073 0.0 [U502] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter
1 1074 0.0 _fpsd /System/Library/PrivateFrameworks/CoreADI.framework/adid
1 1076 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
1 1078 0.0 [U502] /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/TrustedPeersHelper.xpc/Contents/MacOS/TrustedPeersHelper
1 1079 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
1 1080 0.0 [U502] /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
1 1081 0.0 [U502] /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
1 1082 0.0 root /Library/Application Support/AvastHUB/com.avast.hub.app/Contents/Helpers/com.avast.hub.xpc
1 1083 0.0 [U502] /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Resources/SoftwareUpdateNotificationManager.app/Contents/MacOS/SoftwareUpdateNotificationManager
1 1084 0.0 _softwareupdate /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
1 1085 0.0 [U502] /System/Library/PrivateFrameworks/PassKitCore.framework/passd
1 1086 0.0 [U502] /usr/libexec/neagent
1 1087 0.0 [U502] /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariLaunchAgent
1 1088 0.0 [U502] /Applications/Safari.app/Contents/XPCServices/com.apple.Safari.SandboxBroker.xpc/Contents/MacOS/com.apple.Safari.SandboxBroker
1 1089 0.0 root /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
1082 1090 0.0 root /Library/Application Support/AvastHUB/com.avast.hub.app/Contents/Helpers/com.avast.hub.xpc.worker /Library/Application Support/AvastHUB/run/B9537107-4187-4E4A-8516-5D13C5EE2587
1 1091 0.0 _nsurlstoraged /usr/libexec/nsurlstoraged --privileged
1 1093 0.0 [U502] /System/Library/CoreServices/mapspushd
1 1094 0.0 [U502] /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
1 1096 0.0 [U502] /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariNotificationAgent
1 1097 0.0 [U502] /System/Library/Frameworks/ImageIO.framework/Versions/A/XPCServices/ImageIOXPCService.xpc/Contents/MacOS/ImageIOXPCService
1 1098 0.0 [U502] /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -a
1 1099 0.0 [U502] /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/com.apple.Safari.SafeBrowsing.Service
1 1100 0.0 [U502] /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/webinspectord
1 1101 0.0 [U502] /System/Library/CoreServices/ReportCrash agent
1 1102 0.0 [U502] /System/Library/PrivateFrameworks/AMPLibrary.framework/Versions/A/Support/AMPLibraryAgent --launchd
1 1104 0.0 _assetcache /usr/libexec/AssetCache/AssetCache
1 1105 0.0 root /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/XPCServices/AssetCacheTetheratorService.xpc/Contents/MacOS/AssetCacheTetheratorService
1 1106 0.0 [U502] /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
1 1107 0.0 root /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
1 1108 0.0 [U502] /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
1 1109 0.0 _applepay /usr/libexec/nfcd
1 1110 0.0 [U502] /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
1 1111 0.0 [U502] /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
1 1178 0.0 _fpsd /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
1 1179 0.0 [U502] /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 1180 0.0 [U502] /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
1 1181 0.0 [U502] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.embeddedspeech.xpc/Contents/MacOS/com.apple.siri.embeddedspeech
1 1200 0.0 root /usr/libexec/rtcreportingd
1 1201 0.0 _spotlight /usr/libexec/trustd --agent
1 1202 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.GPU.xpc/Contents/MacOS/com.apple.WebKit.GPU
1 1204 0.0 [U502] /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 1205 0.0 [U502] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.framework/Resources/com.apple.speech.speechsynthesisd
1 1206 0.0 [U502] /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1 1207 0.0 [U502] /usr/libexec/siriknowledged
1 1220 0.0 root /usr/libexec/dprivacyd
1 1236 0.0 [U502] /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
1 1241 0.0 [U502] /System/Library/PrivateFrameworks/DeviceCheckInternal.framework/devicecheckd
1 1242 0.0 [U502] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
1 1245 0.0 [U502] /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService
1 1255 0.0 root /usr/libexec/mobileactivationd
1 1257 0.0 [U502] /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
1 1261 0.0 root /usr/libexec/tzd
1 1262 0.0 [U502] /usr/libexec/transparencyd
1 1346 0.0 [U502] /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
1 1394 0.0 _fpsd /System/Library/PrivateFrameworks/CoreLSKD.framework/Versions/A/lskdd
1 1396 0.0 [U502] /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
1 1409 0.0 [U502] /System/Library/PrivateFrameworks/UsageTracking.framework/Versions/A/UsageTrackingAgent
1 1412 0.0 [U502] /System/Library/PrivateFrameworks/Categories.framework/Versions/A/XPCServices/CategoriesService.xpc/Contents/MacOS/CategoriesService
1 1414 0.0 [U502] /usr/libexec/silhouette
1 1415 0.0 [U502] /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/Versions/A/Support/photolibraryd
1 1416 0.0 [U502] /System/Library/CoreServices/ScopedBookmarkAgent
1 1443 0.0 [U502] /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
1 1452 0.0 [U502] /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
1 1453 0.0 root /usr/libexec/periodic-wrapper daily
1 1534 0.0 root /System/Library/PrivateFrameworks/StorageKit.framework/Resources/storagekitd
1 1535 0.0 [U502] /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
1 1536 0.0 root /System/Library/PrivateFrameworks/CacheDelete.framework/deleted_helper
1 1539 0.0 [U502] /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
1 1540 0.0 root /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
1 1541 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
1 1542 0.0 [U502] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
1 1543 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
1 1544 0.0 [U502] /usr/libexec/replayd
1 1550 0.0 [U502] /System/Library/PrivateFrameworks/PodcastServices.framework/XPCServices/PodcastContentService.xpc/Contents/MacOS/PodcastContentService
1 1551 0.0 root /System/Library/CoreServices/iconservicesagent runAsRoot
1 1552 0.0 root /System/Library/CoreServices/ReportCrash daemon
1 1556 0.0 [U502] /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
1 1557 0.0 [U502] /System/Library/PrivateFrameworks/AMPLibrary.framework/Versions/A/Support/AMPArtworkAgent --launchd
1 1560 0.0 root /usr/bin/sysdiagnose
1 1565 0.0 [U502] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
1 2223 0.0 root /System/Library/Frameworks/SystemExtensions.framework/Versions/A/Helpers/sysextd
1 2393 0.0 [U502] /usr/libexec/SidecarRelay
1 2413 0.0 [U502] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter
1 2421 0.0 root /Library/Apple/System/Library/CoreServices/XProtect.app/Contents/MacOS/XProtect
1 2422 0.0 [U502] /Library/Apple/System/Library/CoreServices/XProtect.app/Contents/MacOS/XProtect
1 3186 0.0 root /usr/libexec/smd
1 3942 0.0 [U502] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/PrintCore.framework/Versions/A/printtool
1 3944 0.0 [U502] /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
1 3952 0.0 [U502] /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
1 3953 0.0 [U502] /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
1 3956 0.0 [U502] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
1 3961 0.0 [U502] /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
1 3962 0.0 [U502] /usr/libexec/keyboardservicesd
1 3963 0.0 [U502] /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
1 3968 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat -psn_0_290887
3968 3990 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app/Contents/MacOS/AcroCEF "/Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app" --locale=it-it --backgroundcolor=16514043
1 4000 0.0 _gamecontrollerd /usr/libexec/gamecontrollerd
3990 4005 0.1 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper (GPU).app/Contents/MacOS/AcroCEF Helper (GPU) --type=gpu-process --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --lang=en-US --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --gpu-preferences=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 --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=19
3990 4010 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper.app/Contents/MacOS/AcroCEF Helper --type=utility --utility-sub-type=storage.mojom.StorageService --lang=en-US --service-sandbox-type=utility --use-mock-keychain --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --lang=en-US --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=19
3990 4011 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper.app/Contents/MacOS/AcroCEF Helper --type=utility --utility-sub-type=network.mojom.NetworkService --lang=en-US --service-sandbox-type=network --use-mock-keychain --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --lang=en-US --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=19
3990 4012 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper (Renderer).app/Contents/MacOS/AcroCEF Helper (Renderer) --type=renderer --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --first-renderer-process --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --touch-events=enabled --lang=en-US --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=5 --launch-time-ticks=1589544533 --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=19
1 4014 0.0 [U502] /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
3990 4019 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper (Renderer).app/Contents/MacOS/AcroCEF Helper (Renderer) --type=renderer --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --touch-events=enabled --lang=en-US --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=6 --launch-time-ticks=1589823792 --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=19
3990 4020 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper (Renderer).app/Contents/MacOS/AcroCEF Helper (Renderer) --type=renderer --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --touch-events=enabled --lang=en-US --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=7 --launch-time-ticks=1589824245 --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=19
1 4027 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/CrashHandler --monitor-self-annotation=ptype=crashpad-handler --reset-own-crash-exception-port-to-system-default --database=/Users/[U502]/Library/Logs/Adobe/CrashPadDumps/AdobeAcrobat/24.002.20857/24.002.20857/3968 --annotation=plat=OS X --annotation=prod=Acrobat_Mac --annotation=ver=24.002.20857 --handshake-fd=41
3990 4058 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper (Renderer).app/Contents/MacOS/AcroCEF Helper (Renderer) --type=renderer --log-severity=disable --user-agent-product=ReaderServices/24.2.20857 Chrome/105.0.0.0 --user-data-dir=/Users/[U502]/Library/Application Support/Adobe/AcroCef/DC/Acrobat/UserData --log-file=/Users/[U502]/Library/Logs/AcroCEF_debug.log --touch-events=enabled --lang=en-US --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=8 --launch-time-ticks=1592773283 --shared-files --field-trial-handle=1718379636,r,16883090991356683005,14159369301236125865,131072 --disable-features=BackForwardCache --seatbelt-client=26
1 4068 0.0 [U502] /System/Library/Frameworks/QuickLook.framework/Versions/A/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
1 4077 0.0 [U502] /Applications/OpenOffice.app/Contents/MacOS/soffice -psn_0_327760
1 4080 0.0 [U502] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/atsd
1 4102 0.0 [U502] /System/Library/Frameworks/CoreSpotlight.framework/CoreSpotlightService
1 4297 0.0 [U502] /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/Adobe Crash Processor.app/Contents/MacOS/Adobe Crash Processor
1 4302 0.0 [U502] /usr/libexec/USBAgent
1 4330 0.0 [U502] /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
1 4337 0.0 _lp /System/Library/PrivateFrameworks/PSNormalizer.framework/Versions/A/XPCServices/normalizerd.xpc/Contents/MacOS/normalizerd
1 4338 0.0 _lp /usr/sbin/cfprefsd agent
1 4370 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
1 4514 0.0 [U502] /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
1 4618 0.0 [U502] /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1 4712 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 4714 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 4754 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 4760 1.5 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 4761 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 4762 0.0 [U502] /Library/Apple/System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 5034 0.0 [U502] /usr/libexec/studentd
1 5040 0.0 [U502] /System/Library/PrivateFrameworks/ClassKit.framework/Versions/A/progressd
1 5041 0.0 [U502] /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
1 5042 0.0 [U502] /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
1 5097 0.0 root /System/Library/PrivateFrameworks/SystemAdministration.framework/XPCServices/writeconfig.xpc/Contents/MacOS/writeconfig
1 5379 0.0 [U502] /System/Library/CoreServices/screencaptureui.app/Contents/MacOS/screencaptureui
1 5383 0.0 [U502] /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
1 5483 0.0 root /usr/sbin/ocspd
1 5490 0.0 [U502] /Users/[U502]/Desktop/DetectX Swift.app/Contents/MacOS/DetectX Swift
1 5764 0.0 [U502] /System/Applications/Utilities/Activity Monitor.app/Contents/MacOS/Activity Monitor
1 5765 0.0 root /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/XPCServices/AssetCacheManagerService.xpc/Contents/MacOS/AssetCacheManagerService
1 5767 0.0 [U502] /System/Applications/Preview.app/Contents/MacOS/Preview
1 5771 0.0 [U502] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker-shared -c MDSImporterWorker -m com.apple.mdworker.shared
1 5772 0.0 [U502] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker-shared -c MDSImporterWorker -m com.apple.mdworker.shared
1 5869 0.0 [U502] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker-shared -c MDSImporterWorker -m com.apple.mdworker.shared
1 5870 0.0 _spotlight /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker-shared -c MDSImporterWorker -m com.apple.mdworker.shared
1 5871 0.0 _spotlight /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker-shared -c MDSImporterWorker -m com.apple.mdworker.shared
1 5872 0.0 _spotlight /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker-shared -c MDSImporterWorker -m com.apple.mdworker.shared
«»EOF»«
- report.png (721.89 KiB) Visto 517 volte
