Crash drag and drop immagini Safari/scrivania
yale
Buongiorno ragazzi, problema safari (crome funziona a dovere), non riesco trascinare le immagini safari sulla scrivania, succede questo:
da un resoconto...
06/04/17 19:57:29,017 com.apple.WebKit.WebContent[563]: Unsupported pixel description - 3 components, 16 bits-per-component, 64 bits-per-pixel
06/04/17 19:57:29,019 com.apple.WebKit.WebContent[563]: CGBitmapContextCreateWithData: failed to create delegate.
06/04/17 19:57:29,019 com.apple.WebKit.WebContent[563]: CGContextTranslateCTM: invalid context 0x0. If you want to see the backtrace, please set CG_CONTEXT_SHOW_BACKTRACE environmental variable.
06/04/17 19:57:29,020 com.apple.WebKit.WebContent[563]: CGContextScaleCTM: invalid context 0x0. If you want to see the backtrace, please set CG_CONTEXT_SHOW_BACKTRACE environmental variable.
06/04/17 19:57:29,021 com.apple.xpc.launchd[1]: (com.apple.WebKit.WebContent.E9B528E5-6C70-43A7-AFD7-31DD3758EF72[563]) Service exited due to signal: Segmentation fault: 11
06/04/17 19:57:29,210 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.582) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 19:57:29,210 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.582) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 19:57:29,210 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.582) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 19:57:29,211 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.582) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SocialHelper.xpc/Contents/MacOS/com.apple.Safari.SocialHelper error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 19:57:29,211 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.582) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.WebFeedParser.xpc/Contents/MacOS/com.apple.Safari.WebFeedParser error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 19:57:29,337 ReportCrash[562]: Saved crash report for com.apple.WebKit.WebContent[563] version 11603 (11603.1.30.0.34) to /Users/luigi/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-195729_iMac-di-Luigi.crash
06/04/17 19:57:29,338 ReportCrash[562]: AutoSubmitPreference is (null)
06/04/17 19:57:48,517 Safari[484]: KeychainGetICDPStatus: keychain: 0
06/04/17 19:57:48,517 Safari[484]: KeychainGetICDPStatus: status: on
06/04/17 19:57:55,663 lsd[279]: LaunchServices: Could not store lsd-identifiers file at /private/var/db/lsd/com.apple.lsdschemes.plist
Qualcuno ha dei suggerimenti?
iMac-inch, M1, 2021 Chip Apple M1 Memoria 8GB macOS Sonoma 14.4.1
Quel resoconto serve a poco.
Avresti dovuto postare il crash.log.
Ma tanto... Credo sia un problema legato all'installazione in generale.
Quindi:
1) Preferenze di Sistema, pannello iCloud, sincronizza Safari
2) Chiudi Safari
3) Apri Terminale, esegui, copiando ed incollando sulla sua finestra aperta e dando poi accapo
rm -rf ~/Library/Safari/;rm -rf ~/Library/Saved\ Application\ State/com.apple.Safari*;rm -rf ~/Library/Caches/com.apple.Safari*;rm -rf ~/Library/Cookies/com.apple.Safari*;rm -rf ~/Library/Preferences/com.apple.Safari*
Scrivi exit, accapo, cmd+Q per uscire correttamente da Terminale
4) Apri Safari, non ti preoccupare se trovi Safari nuovo nuovo, testa se funziona.
Poi esegui:
5) Preferenze di Sistema, pannello iCloud, desincronizza Safari poi sincronizza Safari.
Tornerà con le tue impostazioni di sempre, testa se funziona
yale
il problema persiste e rimango con safari nuovo, non mi riporta alle impostazioni di iCloud
yale
scusami sono riuscito a riportarlo con le impostazioni di iCloud ma il problema rimane
Allora... Cerca il Safari Crash.log in Console.
Barra laterale, prendi l'ultimo che trovi.
Per favore, segui scrupolosamente queste istruzioni.
Per non postare migliaia di righe inutili, ma solo le poche decine necessarie, con descrizione e thread crasciato:
Come si posta un resoconto di un Crash.Log
viewtopic.php?f=33&t=37701" onclick="window.open(this.href);return false;
yale
spero vada bene...
06/04/17 21:04:49,938 com.apple.WebKit.WebContent[1193]: CGBitmapContextCreateWithData: failed to create delegate.
06/04/17 21:04:49,938 com.apple.WebKit.WebContent[1193]: CGContextTranslateCTM: invalid context 0x0. If you want to see the backtrace, please set CG_CONTEXT_SHOW_BACKTRACE environmental variable.
06/04/17 21:04:49,938 com.apple.WebKit.WebContent[1193]: CGContextScaleCTM: invalid context 0x0. If you want to see the backtrace, please set CG_CONTEXT_SHOW_BACKTRACE environmental variable.
06/04/17 21:04:49,941 com.apple.xpc.launchd[1]: (com.apple.WebKit.WebContent.F0BB9050-0708-4F31-9AB1-CC55F7AC3CA3[1193]) Service exited due to signal: Segmentation fault: 11
06/04/17 21:04:49,955 com.apple.xpc.launchd[1]: (com.apple.ReportCrash[1195]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
06/04/17 21:04:50,051 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1196) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:04:50,051 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1196) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:04:50,051 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1196) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:04:50,051 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1196) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SocialHelper.xpc/Contents/MacOS/com.apple.Safari.SocialHelper error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:04:50,051 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1196) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.WebFeedParser.xpc/Contents/MacOS/com.apple.Safari.WebFeedParser error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:04:50,255 ReportCrash[1195]: Saved crash report for com.apple.WebKit.WebContent[1193] version 11603 (11603.1.30.0.34) to /Users/luigi/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-210450_iMac-di-Luigi.crash
06/04/17 21:04:50,256 ReportCrash[1195]: AutoSubmitPreference is (null)
06/04/17 21:04:50,562 WindowServer[162]: _CGXRemoveWindowFromWindowMovementGroup: window 0x16a is not attached to window 0x16c
06/04/17 21:05:05,651 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1199) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:05:05,651 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1199) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:05:05,651 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1199) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:05:05,651 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1199) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SocialHelper.xpc/Contents/MacOS/com.apple.Safari.SocialHelper error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
06/04/17 21:05:05,651 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.pid.WebContent.1199) Path not allowed in target domain: type = pid, path = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.WebFeedParser.xpc/Contents/MacOS/com.apple.Safari.WebFeedParser error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc
Ma no...
Non hai visto gli esempi nel link?
Cerca in Console > ~/Library/Logs > Diagnostic Reports > com.apple.Safari***.crash
(o WebKit vedi tu, quello che compare nella finestra di dialogo quando crolla il processo)
yale
Ci sono pagine e pagine infinite...vedi questo se ti può essere utile...di WebKit ce ne sono parecchi
Process:               com.apple.WebKit.WebContent [488]
Path:                  /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Identifier:            com.apple.WebKit.WebContent
Version:               11603 (11603.1.30.0.34)
Build Info:            WebKit2-7603001030000034~7
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Safari [484]
User ID:               501
Date/Time:             2017-04-06 19:54:27.846 +0200
OS Version:            Mac OS X 10.11.6 (15G1421)
Report Version:        11
Anonymous UUID:        D6AB1E0C-321D-D5A0-4231-DC82A145CB77
Time Awake Since Boot: 180 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0:
    __TEXT                 000000010655f000-0000000106561000 [    8K] r-x/rwx SM=COW  /System/Library/StagedFrameworks/Safari/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Application Specific Information:
Bundle controller class:
BrowserBundleController
Enabled Extensions:
org.adblockplus.adblockplussafari-GRYYZR985A (1.12.4 - 1.12.4) Adblock Plus
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.apple.WebCore             	0x0000000107f66d17 WebCore::GraphicsContext::platformContext() const + 7
1   com.apple.WebKit              	0x000000010672accb WebKit::WebDragClient::startDrag(WTF::RetainPtr<NSImage>, WebCore::IntPoint const&, WebCore::IntPoint const&, WebCore::DataTransfer&, WebCore::Frame&, bool) + 191
2   com.apple.WebCore             	0x000000010842a00e WebCore::DragController::doSystemDrag(WTF::RetainPtr<NSImage>, WebCore::IntPoint const&, WebCore::IntPoint const&, WebCore::DataTransfer&, WebCore::Frame&, bool) + 270
3   com.apple.WebCore             	0x000000010842a69e WebCore::DragController::doImageDrag(WebCore::Element&, WebCore::IntPoint const&, WebCore::IntRect const&, WebCore::DataTransfer&, WebCore::Frame&, WebCore::IntPoint&) + 1102
4   com.apple.WebCore             	0x0000000108429a5b WebCore::DragController::startDrag(WebCore::Frame&, WebCore::DragState const&, WebCore::DragOperation, WebCore::PlatformMouseEvent const&, WebCore::IntPoint const&) + 4843
5   com.apple.WebCore             	0x0000000108111b74 WebCore::EventHandler::handleDrag(WebCore::MouseEventWithHitTestResults const&, WebCore::CheckDragHysteresis) + 2420
6   com.apple.WebCore             	0x0000000108077cbc WebCore::EventHandler::handleMouseDraggedEvent(WebCore::MouseEventWithHitTestResults const&) + 60
7   com.apple.WebCore             	0x0000000108075343 WebCore::EventHandler::handleMouseMoveEvent(WebCore::PlatformMouseEvent const&, WebCore::HitTestResult*, bool) + 1427
8   com.apple.WebCore             	0x0000000108074bd9 WebCore::EventHandler::mouseMoved(WebCore::PlatformMouseEvent const&) + 169
9   com.apple.WebKit              	0x0000000106599fd7 WebKit::WebPage::mouseEvent(WebKit::WebMouseEvent const&) + 535
10  com.apple.WebKit              	0x00000001067778b6 void IPC::handleMessage<Messages::WebPage::MouseEvent, WebKit::WebPage, void (WebKit::WebPage::*)(WebKit::WebMouseEvent const&)>(IPC::Decoder&, WebKit::WebPage*, void (WebKit::WebPage::*)(WebKit::WebMouseEvent const&)) + 84
11  com.apple.WebKit              	0x000000010664ebe3 IPC::MessageReceiverMap::dispatchMessage(IPC::Connection&, IPC::Decoder&) + 113
12  com.apple.WebKit              	0x00000001067bcb02 WebKit::WebProcess::didReceiveMessage(IPC::Connection&, IPC::Decoder&) + 28
13  com.apple.WebKit              	0x0000000106615ffb IPC::Connection::dispatchMessage(std::__1::unique_ptr<IPC::Decoder, std::__1::default_delete<IPC::Decoder> >) + 119
14  com.apple.WebKit              	0x00000001066187fc IPC::Connection::dispatchOneMessage() + 126
15  com.apple.JavaScriptCore      	0x0000000107bf69f9 WTF::RunLoop::performWork() + 169
16  com.apple.JavaScriptCore      	0x0000000107bf6cb2 WTF::RunLoop::performWork(void*) + 34
17  com.apple.CoreFoundation      	0x00007fff905f67e1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
18  com.apple.CoreFoundation      	0x00007fff905d5f1c __CFRunLoopDoSources0 + 556
19  com.apple.CoreFoundation      	0x00007fff905d543f __CFRunLoopRun + 927
20  com.apple.CoreFoundation      	0x00007fff905d4e38 CFRunLoopRunSpecific + 296
21  com.apple.HIToolbox           	0x00007fff8e14b935 RunCurrentEventLoopInMode + 235
22  com.apple.HIToolbox           	0x00007fff8e14b76f ReceiveNextEventCommon + 432
23  com.apple.HIToolbox           	0x00007fff8e14b5af _BlockUntilNextEventMatchingListInModeWithFilter + 71
24  com.apple.AppKit              	0x00007fff99812df6 _DPSNextEvent + 1067
25  com.apple.AppKit              	0x00007fff99812226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
26  com.apple.AppKit              	0x00007fff99806d80 -[NSApplication run] + 682
27  com.apple.AppKit              	0x00007fff997d0368 NSApplicationMain + 1176
28  libxpc.dylib                  	0x00007fff8e73c194 _xpc_objc_main + 795
29  libxpc.dylib                  	0x00007fff8e73abbe xpc_main + 494
30  com.apple.WebKit.WebContent   	0x00000001065607c0 0x10655f000 + 6080
31  libdyld.dylib                 	0x00007fff89a315ad start + 1
Sono desolato, dice quello che hai detto tu.
Quando fai drag & drop sulla scrivania crolla il motore di Safari.
Perché il coprocessore grafico non ce la fa...
Se ti sembra poco, lo è.
Quindi ho cercato di vedere se è un fatto diffuso.
A chi succede non trova soluzioni, se non in qualche caso.
Perché si tratta quasi sempre di una corruzione di vario tipo ed origine.
Ma che manovre su Safari non risolvono.
Nel frattempo usa il menù contestuale, che dovrebbe essere una alternativa valida.
Possiamo provare a indovinare o a saperlo per intuizione.
Posta un EtreCheck:
iKrypt
faxus ha scritto:Sono desolato, dice quello che hai detto tu.
Posta un EtreCheck:
Anche a me succede da quando safari è stato aggiornato, e non solo questo mi succede. Dopo l'ultimo aggiornamento di sicurezza di EC rotelline di safari e rallentamenti (sempre e solo con safari) a raffica. Cambiando il browser (io uso anche l'ottimo yandex browser come browser numero 2) tutto va a meraviglia. Infatti adesso ho cambiato browser predefinito in yandex browser da safari almeno fino al prossimo aggiornamento di safari. C'è la possibilità che apple faccia un aggiornamento a breve se la cosa è diffusa. Andrò a guardare su apple discussion per vedere se è una cosa diffusa. La prima cosa che si può fare e che farò anch'io ora è disattivare l'accelerazione software di safari. Poi provare.
aggiornamento: pare che sia meglio fate così: safari->preferenze->sicurezza->togliere la spunta a "Consenti WebGL"->chiudere safari->riavviare safari->navigare .
yale
Comunque grazie a faxus e a iKrypt per l'interessamento...ecco il risultato di Etrecheck:
EtreCheck version: 3.1.5 (343)
Report generated 2017-04-07 06:19:39
Runtime 1:54
Performance: Excellent
Problem: Other problem
Hardware Information: ⓘ
iMac (27-inch, Late 2013)
iMac - model: iMac14,2
1 3,4 GHz Intel Core i5 (i5-4670) CPU: 4-core
32 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
BANK 1/DIMM1
Wireless: Unknown
Video Information: ⓘ
NVIDIA GeForce GTX 775M - VRAM: 2048 MB
iMac 2560 x 1440
System Software: ⓘ
OS X El Capitan 10.11.6 (15G1421) - Time since boot: less than an hour
Disk Information: ⓘ
APPLE HDD WD10EZES-40UFAA0 disk0 : (1 TB) (Rotational)
[Show SMART report]
Macintosh HD (disk0s2) / [Startup]: 999.35 GB (853.52 GB free)
USB Information: ⓘ
Toshiba External USB 3.0 1 TB
EFI (disk2s1) <not mounted> : 210 MB
Time Machine (disk2s2) /Volumes/Time Machine : 843.58 GB (496.64 GB free)
Mac HD 2 (disk2s3) /Volumes/Mac HD 2 : 156.15 GB (124.08 GB free)
Apple Inc. BRCM20702 Hub
SanDisk Cruzer Force 8 GB
NO NAME (disk1s1) /Volumes/NO NAME : 8.00 GB (7.98 GB free)
Apple, Inc. Keyboard Hub
Apple Inc. Apple Keyboard
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Configuration files: ⓘ
Gatekeeper: ⓘ
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.tomtom.driver.UsbEthernetGadget (1.0.0d1 - 2017-04-03) [Support]
System Launch Agents: ⓘ
[not loaded] 8 Apple tasks
[loaded] 159 Apple tasks
[running] 72 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 46 Apple tasks
[running] 86 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (2014-08-13) [Support]
[not loaded] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (2015-05-27) [Support]
[not loaded] com.adobe.CS5ServiceManager.plist (2014-08-01) [Support]
[not loaded] com.epson.esua.launcher.plist (2016-08-14) [Support]
[not loaded] org.macosforge.xquartz.startx.plist (2014-08-12) [Support]
Launch Daemons: ⓘ
[loaded] com.adobe.ARMDC.Communicator.plist (2015-05-27) [Support]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (2015-05-27) [Support]
[loaded] com.adobe.SwitchBoard.plist (2014-08-01) [Support]
[loaded] com.klieme.TMSHelper.plist (2014-08-05) [Support]
[loaded] com.malwarebytes.HelperTool.plist (2017-02-04) [Support]
[loaded] com.microsoft.office.licensing.helper.plist (2012-11-05) [Support]
[loaded] com.microsoft.office.licensingV2.helper.plist (2015-08-15) [Support]
[not loaded] com.oracle.java.Helper-Tool.plist [Support]
[loaded] com.timesoftware.timemachineeditor.helper.plist (2014-08-21) [Support]
[loaded] org.macosforge.xquartz.privileged_startx.plist (2014-08-12) [Support]
User Launch Agents: ⓘ
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (2017-03-23) [Support]
[loaded] com.google.keystone.agent.plist (2017-01-14) [Support]
User Login Items: ⓘ
smcFanControl Applicazione
(/Applications/smcFanControl.app)
Dropbox Applicazione
(/Applications/Dropbox.app)
Internet Plug-ins: ⓘ
MeetingJoinPlugin: Unknown - SDK 10.6 (2014-08-01) [Support]
SharePointBrowserPlugin: 14.4.1 - SDK 10.6 (2014-08-01) [Support]
QuickTime Plugin: 7.7.3 (2017-03-28)
Silverlight: 5.1.50901.0 - SDK 10.6 (2016-10-17) [Support]
AdobeAAMDetect: AdobeAAMDetect 2.0.0.0 - SDK 10.7 (2014-08-13) [Support]
Default Browser: 601 - SDK 10.11 (2016-07-19)
3rd Party Preference Panes: ⓘ
Hosts (2012-09-11) [Support]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 999.35 GB Disk used: 145.82 GB
Destinations:
Time Machine [Local]
Total size: 843.58 GB
Total number of backups: 169
Oldest backup: 25/08/14, 17:22
Last backup: 06/04/17, 23:11
Size of backup disk: Adequate
Backup size 843.58 GB > (Disk used 145.82 GB X 3)
Top Processes by CPU: ⓘ
3% WindowServer
2% kernel_task
1% fontd
0% hidd
0% cloudpaird
Top Processes by Memory: ⓘ
1.25 GB kernel_task
164 MB Dropbox
164 MB mds_stores
131 MB Safari
131 MB mdworker(16)
Virtual Memory Information: ⓘ
28.78 GB Available RAM
26.66 GB Free RAM
3.22 GB Used RAM
2.12 GB Cached files
0 B Swap Used
Diagnostics Information: ⓘ
Apr 7, 2017, 06:16:15 AM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-07-061615_[redacted].crash
Apr 7, 2017, 06:10:06 AM Self test - passed
Apr 6, 2017, 09:38:41 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-213841_[redacted].crash
Apr 6, 2017, 09:38:18 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-213818_[redacted].crash
Apr 6, 2017, 09:38:09 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-213809_[redacted].crash
Apr 6, 2017, 09:28:36 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-212836_[redacted].crash
Apr 6, 2017, 09:04:50 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-210450_[redacted].crash
Apr 6, 2017, 08:58:41 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-205841_[redacted].crash
Apr 6, 2017, 08:58:27 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-205827_[redacted].crash
Apr 6, 2017, 08:58:26 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-205826_[redacted].crash
Apr 6, 2017, 08:58:24 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-205824_[redacted].crash
Apr 6, 2017, 08:57:36 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-205736_[redacted].crash
Apr 6, 2017, 08:48:06 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-204806_[redacted].crash
Apr 6, 2017, 07:57:29 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-195729_[redacted].crash
Apr 6, 2017, 07:56:30 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-195630_[redacted].crash
Apr 6, 2017, 07:54:43 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-195443_[redacted].crash
Apr 6, 2017, 07:54:42 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2017-04-06-195442_[redacted].crash
Nulla, un EtreCheck pulito e normale.
(Al massimo posso annotare l'inutilità di due helper di piccole applicazioni regolatrici delle preferenze di Time machine.
Oltre alla scarsa utilità di montare applicazioni e helper al posto di un semplice comando di Terminale.
Sono persino due e fanno la stessa cosa.)
Nulla più di quello che ho detto.
Non trovo indicazioni utili a capire.
Ricordo però che in passato era successo anche a me.
Safari (io uso Safari TP) crollava se cercavo di spostare col puntatore un'immagine sulla scrivania.
Per un po' ho usato il menù contestuale.
Poi ho risolto.
Ma me possono... Se mi ricordo che ho fatto.
E poi, l'ho fatto io o è stato un aggiornamento?...
Vediamo se mi torna alla mente
yale
faxus ha scritto:Nulla, un EtreCheck pulito e normale.
Poi ho risolto.
Ti ringrazio della cortesia e premura che hai nel cercare di risolvere sempre le varie problematiche agli utenti del forum, quasi sempre ci riesci qualche volta no, ma un GRAZIE te lo voglio lo stesso gridare !!!
iKrypt
Poi ho risolto.
Ma perché il sistema non è aggiornato? Sei al 10.11.5 e siamo al 10.11.6 ...
In questo modo potresti non ricevere degli aggiornamenti risolutivi. Il web va avanti safari lo segue. Tu che versione di safari hai?
e poi guarda che se togli WebGL dovrebbe sparire tutto il problema.
Ma comunque la maggior parte dei problemi è sicuramente legata all'aggiornamento non attuale.
Ultima modifica di iKrypt il ven, 07 apr 2017 15:18, modificato 2 volte in totale.
Le considerazioni di iKrypt sono esatte.
Cose che mi sono sfuggite.
Aggiorna subito, sistema, sicurezza e Safari.
Se non bastasse esegui anche quanto ti consiglia sulle WebGL
Visitano il forum: gifin e 7 ospiti
