System info
Operating system: Mac OS X 10.5.6 (Build 9G55)
Model: MacBook (Early 2008)
Processor: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz
Frequency: 2.40 GHz
Total CPU number: 2
Physical CPU number: 1
Bus frequency: 800 MHz
Memory size: 4.00 GB
Memory type: 667 MHz DDR2 SDRAM
Compiled with: GCC 4.2.1 (Apple Inc. build 5564)
Tests results
Composite result: 3.75
iBench_fp test suite
Householder transformation: 3.55
Gaussian blur: 3.86
Mandelbrot set generation: 3.73
Numerical integration: 3.96
JPEG compression: 3.77
LU decomposition: 3.82
Edge detection: 3.97
Fast Fourier Transform: 3.67
Eigenvalue: 3.74
Partial result: 3.78
iBench_int test suite
MD5 hashing: 4.07
Blowfish cypher: 4.10
Kruskal tree search: 3.69
Integer factorization: 4.00
ZIP compression: 3.02
N Queens problem: 4.03
Maximum Common Divisor: 3.62
Quick sorting: 3.67
Binary searching: 3.67
Bubble sorting: 3.51
Prime numbers calculation: 3.69
Partial result: 3.72
