Aggiornamento GraphicConverter
GraphicConverter - 9.2.1
New features
added auto color
added batch multicrop
Updates features
enhanced JPEG file metadata access
updated Flickr API
Bug fixes
fixed bug in GIF loop detection during import
fixed possible delay/hang during use of the browser.
http://www.lemkesoft.com/xd/public/cont ... M0NA_.html" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 9.4, l'ottimo software capace di convertire le immagini nei più svariati formati grafici, munito anche di potenti strumenti per la modifica ed il controllo delle stesse.
New features
• Now 64-bit only
• added auto convert feature (batch conversion with folder watching)
• added optional display of subfolder count and files count in the folder tree of the browser
• added iOS icon set to save as formats
• added "get move folder" AppleScript command
• added Split JPX data stream into JP2s to convert and modify
• added copy filename to IPTC headline command to context menu and actions menu
• added display of defined move folders to browser context menu
• added search by label to find function in browser
• added display mode: same image on second screen to slideshow prefs
• added option to slideshow to display next image after deletion in sorted order if slideshow is played in random order
• added function to add/remove fish eye effect
• added Four Color effect
• added optional fullscreen preview to the browser
• added option to disable fade effect for quick look palette
• added option to set default browser filter
• added +, -, = zoom shortcuts to quick look palette
• added batch to scale directly to HD and UHD
• added shadow and stroke option to insert text batch
• added option to set default GPS location for images without GPS data
• added context menu action "Copy IPTC headline to IPTC title"
Updates features
• added support for grayscale mode to highlights and shadows effect
• added support for grayscale mode to equalizer effect
• embedded Photoshop paths will be saved in TIFF and JPEG format
• added titles GPS, Script, and Action to the symbol menus for better AppleScript accessibility
• added preference to disable black frame transition at the end of the slideshow to movie export
• added limit color range checkbox to colorize dialog
• added option to enable/disable extension check during IPTC import
• added option to set movie internal date/time kind between UTC and local time
• many updates related to Yosemite
• updated DCRAW
• updated ExifTool
• improved GPX import
• improved behavior of set file date dialog
• added support for search of city in Google map after recent API change
Bug fixes
• fixed one missing unchecked item in rename dialog upon click onto "Uncheck all"
• fixed size of save for Web dialog for small screens
• fixed bug in inversion of GIF frames
• fixed possible memory leak in the slideshow
• fixed size issue in Cocooner export dialog
• fixed possible issue with not appearing drop area
• fixed possible folding issue in the folder tree of the browser during drag-and-drop
• fixed crash during AppleScript "convert file" command
• fixed bug in "MOS" import
Il mio primo Mac aveva una CPU Motorola 603e a 200Mhz e come OS aveva System 7.5.3... e all'epoca GraphicConverter era dato in bundle con ogni Mac.
Sembra siano passati dei secoli da allora...
E per tutti questi anni io ho sempre usato GraphicConverter, praticamente quasi ogni giorno (lo uso, per dire, anche se devo tagliare o ridimensionare una immagine da postare nei forum o nei social).
Probabilmente l'unico software che ho usato più del Finder. :D
Rilasciato GraphicConverter 9.7
http://www.lemkesoft.de/en/products/gra ... /download/" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 9.7.5
Rilasciata la nuova versione di GraphicConverter, il software di fotoritocco e conversione di innumerevoli formati di immagini.
https://www.lemkesoft.de/en/products/graphicconverter/" onclick="window.open(this.href);return false;
GraphicConverter - 10.2
New features
Option to remember last browser selection and position
Added support for editing Spotlight comment
Added basic focus stacking
Added more sort into subfolder variants
Added color balance batch
Added context menu function to copy Fuji filmmode into xmp subject code
Added Photos extension "Edit with GraphicConverter 10"
Added Crop Portrait batch
Added Arranged Fullscreen Preview
Added FPX import with helper commandline tool
Added select similar
Added preference to open/save slideshow setting presets
Added preset selection to Slideshow file selector
Added paste into red/green/blue channel
Added option to import x3f files with x3f_extract
Updates features
Updated Japanese localization
Updated Danish localization
Updated French localization
Updated Portuguese localization
Save menu item by default only enabled after change
Updated ExifTool
Updated DynaPDF
Updated dcraw
Set exif date can adjust movie dates, too
Click into rating matrix onto the current rating will clear the rating
Added rename option "Add HDR"
Reveal in Finder during slideshow with command + cursor up key added
Option to display metadata in slideshow as overlay added
Option to display filename in slideshow with random horizontal location added
Added preview to catalog printing
Set exif date from filename supports MOV/MP4 in addition
Added option to hide movie controls during slideshow
Animation palette supports marking of frames for deletion
Added checking of XMP record size during opening a file
Added support for export of CMYKA TIFFs
Scale to last values with special menu items for width and percentage
Improved sorting prefs (general/misc)
Added CCITT3 and CCITT4 PDF export
Compiled on 10.12 with XCode 8
Improved service menu display
Enhanced FFT support
Added note if user tries to browse pass-code protected and untrusted iOS device
Added option to display basic EXIF data in the window footer
Bug fixes
Fixed preview issue in Picture Package for manual added files
Fixed bug with setting of file date to exif date for some MOVs
Fixed possible flicker during reloading of slideshow
Fixed possible crash during executing FFT operation
Fixed crash on opening PDF with more than 200 layers
GraphicConverter - 10.3
New features
New Image from open Images with Overlay
Browser: context menu item "Resolve Alias and copy Original to…"
Browser: store and reuse searches
Convert & Modify: added auto rotate batch
Convert & Modify: added apply unapplied xmp changes batch
Preferences: added PNG panel to ignore frames of APNGs
Menu: added next/previous frame commands
Menu Effect: added Tilt-Shift effect
Menu Faces: added Anonymise Faces effect
Menu Effect: added old Photo effect
Menu Effect: added Blur effect
Touchbar support (slideshow, browser, image) with customization
XMP: added import/export support for Iptc4xmpExt:PersonInImage
Layer palette: added support for various blend modes
Menu Filter: added direct access to Core Image filters
Menu Filter: added chroma key filter
Convert & Modify Prefs: added option to clear batches and paths upon quit
Prefs Save: added option to clear non-standard exif tags upon saving
Prefs Open: added mrsid import options
Image Context Menu: added option to export pdf as tiff.
Updates features
Import: x3f import with different color profiles
Frameworks: updated Sparkle update framework to 1.14
XMP: improved handling of extended photoshop:DateCreated item.
Bug fixes
Fixed possible inverse fft crash
Fixed possible bug with usage of core image filters during batch on macOS Sierra
Fixed possible crash during saving a renamed collage
Fixed toolbox icon selection issue in the window footer
Fixed possible text flatten issue
Fixed retina issue in Photos extension
Fixed browser refresh issue on 10.12.1
Fixed wrong display of layered images during effects
Fixed offset in mrsid import.
GraphicConverter - 10.3.1
New features
Menu: new image from clipboard after copy of movie frame will set the exif date from the movie date
Image context menu: show open images as slideshow
Browser: added duplicate batch item to the toolbar
Slideshow prefs: loop movie option.
Updates features
Batch: insert text will add automatically a line break if required
Batch: insert text supports typefaces
Japanese, Danish and French localization
Menu: help menu improved
EXIFTool updated.
Bug fixes
Fixed translation issue in the services menu
Fixed size issue of a preference panel on 13 inch MacBook Pro
Fixed a crash during import of a Silverfast DNG with more than 2GB filesize
Fixed a possible crash during batch conversion of PDFs
Fixed html catalog export bug with UTF8 texts
Fixed update check
Fixed possible disk cache issue.
GraphicConverter - 10.4
New
Added 32-bit-per-channel support (HDR)
Batch: added add border batch
Prefs window: option to display complete file path
EBM import and export
Browser: added context menu entry to lock/unlock all
Open: added calling of QuickTime modernizer for old, legacy movie formats
Prefs convert-and-modify: option to activate all cores for parallel batch conversion
Batch: added rename batch
Batch: multiply alpha channel by factor
Menu: added "Browse Amazon Drive"
Menu: added "Texturizer…"
Preferences: added option to select maps provider (general/maps)
Slideshow: added toolbox item to edit picture change behaviour
Open: added IPM import
Menu: smart-crop textbox
RAF: added reading of EXIF data from FujiFilm RAF raw files
Browser context menu:added option to set label from xmp:label
Prefs open: open to suggest always last open path
Prefs browser: added option to show beginning of caption and keywords below the thumbs.
Updates
Save for web: added www-ready filename option
Preferences open/tools
Improved manual download
Browser keywords palette: option to apply automatically parent keywords
Updated Czech, French, Danish, Japanese, Swedish localization
Improved contact options
Improved metadata fetching in the browser.
Fixed
Possible crash with insert text batch
Fixed possible bug after rotate with line with keep proportions command
Fixed possible set GPS issue in XMP sidecar file
Fixed bug with paste into selection if source image has no alpha channel and destination image has an alpha channel
Fixed display issue if iDevice contains multiple images with the same filename.
GraphicConverter - 10.4.1
New
Effect: logarithm and normalize
Batch: logarithm and normalize
Browser context menu: remove camera metadata
Browser context menu: export folder images to csv.
Updated
Improved browser lossless jpeg rotation options
Batch: create alpha channel from transparency supports a tolerance
Updated localizations.
Fixed
Fixed possible crash in colorize command.
Come dicevo più sopra uso con soddisfazione GraphicConverter dalla fine degli anni '90 (il mio primo Mac, con System 7.5.3 e GC fornito in bundle direttamente da Apple)...
Attualmente non sono ancora passato all'ultima versione (10.X) ma sono fermo alla 9.7.6 ossia la versione più aggiornata prima dell'ultimo salto del numero "primario".
L'altro giorno ho provayo la versione 10.4.1, l'ultima rilasciata, ed ho notato che alcune delle voci nei menù dell'applicazione sono in italiano ed altre invece sono in inglese.
Poiché è una cosa piuttosto fastidiosa e anche alquanto strana, vista la qualità che il programma ha sempre avuto, volevo chiedere conferma a voi del forum che sia effettivamente così e non, magari, un problema alla mia installazione dovuto per esempio al sovrapporsi delle preferenze con quelle delle vecchie versioni.
GraphicConverter - 10.4.2
Overview of new features and versions >>> https://www.lemkesoft.de/en/products/gr ... -versions/" onclick="window.open(this.href);return false;
Kernel Panic ha scritto:GraphicConverter - 10.4.2 ...
Lo hai installato? Puoi confermare o smentire quanto ho detto sopra?
(Ha alcuni elementi del menù in italiano e altri in inglese)
No Jethro, mi spiace, non l'ho (più) installato dai tempi di Snow Leopard, mi limito solo a segnalarne periodicamente gli aggiornamenti (se non lo fa l'admin che ha aperto il topic).
Torna a “Aggiornamenti”
