Aggiornamento EtreCheck
tighine
Peccato che lo spirito sia ancora piuttosto austroungarico, "per vedere chi c'é e chi non c'é" di manzoniana memoria...
EtreCheck - 3.0.5
System requirements and release notes >> http://etrecheck.com/#download" onclick="window.open(this.href);return false;
http://etrecheck.com" onclick="window.open(this.href);return false;
EtreCheck - 3.0.6
EtreCheck - 3.1
5.4MB
Novità in 3.1
Improve compatibility with Little Snitch and other network blockers.
Add SMART report.
Improve memory reporting by adding "Available RAM".
No longer require Time Machine backup to remove adware and unknown files.
Add ability to specify search engine (thanks to kiancheong).
Improve user interface and compatibility with OS X 10.6.
Improved French localizations.
Various bug fixes and improvements.
Updates adware and whitelist signatures
[KP sta invecchiando, latita e ci tocca fare gli straordinari...
E neanche qui si è più tanto giovani... Hehe)
Incuriosito, l'ho riscaricato per il report SMART.. Finalmente!
smartctl 6.5 2016-05-07 r4318 [Darwin 14.5.0 x86_64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Hitachi Travelstar 5K500.B
Device Model:     Hitachi HTS545032B9A300
Serial Number:    100113PBPC00QDF8N57L
LU WWN Device Id: 5 000cca 5a0ee3531
Firmware Version: PB3OC60N
User Capacity:    320,072,933,376 bytes [320 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Tue Nov  1 22:16:08 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(  645) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 106) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   062    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   040    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0007   136   136   033    Pre-fail  Always       -       1
  4 Start_Stop_Count        0x0012   097   097   000    Old_age   Always       -       5056
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   040    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0012   085   085   000    Old_age   Always       -       6892
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   097   097   000    Old_age   Always       -       4850
191 G-Sense_Error_Rate      0x000a   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       65800
193 Load_Cycle_Count        0x0012   080   080   000    Old_age   Always       -       207831
194 Temperature_Celsius     0x0002   183   183   000    Old_age   Always       -       30 (Min/Max 5/57)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
223 Load_Retry_Count        0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 3
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	SC = Sector Count Register [HEX]
	SN = Sector Number Register [HEX]
	CL = Cylinder Low Register [HEX]
	CH = Cylinder High Register [HEX]
	DH = Device/Head Register [HEX]
	DC = Device Command Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  10 51 01 81 15 43 e0  Error: IDNF 1 sectors at LBA = 0x00431581 = 4396417
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 db 01 81 15 43 e0 00      00:01:13.100  READ DMA EXT
  25 db 01 81 15 43 e0 00      00:01:13.000  READ DMA EXT
  35 db 01 00 00 00 e0 00      00:01:13.000  WRITE DMA EXT
  25 db 01 00 00 00 e0 00      00:01:12.900  READ DMA EXT
  25 db 01 81 15 43 e0 00      00:01:12.600  READ DMA EXT
Error 2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  25 00 01 00 00 00 e0 00      00:00:35.200  READ DMA EXT
Error 1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%      6407         -
# 2  Short offline       Completed without error       00%      6404         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
EtreCheck, per me, sostituisce di gran lunga SMART Utility (almeno per le condizioni di salute e i vari errori catalogati in precedenza)..
kext ha scritto:Incuriosito, l'ho riscaricato per il report SMART.. Finalmente!
... EtreCheck, per me, sostituisce di gran lunga SMART Utility (almeno per le condizioni di salute e i vari errori catalogati in precedenza)..
Strano. A me dice che Smart support è disabilitato, quando sia Utility Disco che Onyx invece mi danno stato Smart OK.
smartctl 6.5 2016-05-07 r4318 [Darwin 13.4.0 x86_64] (local build)
Model Family:     Apple SD/SM/TS...E/F SSDs
Device Model:     APPLE SSD SD0256F
Serial Number:    1350A1402226
LU WWN Device Id: 5 001b44 a846ce5f2
Firmware Version: A223321
User Capacity:    251,000,193,024 bytes [251 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      Unknown (0x0012)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Nov  1 22:41:53 2016 CET
SMART support is: Disabled
SMART Disabled. Use option -s with argument 'on' to enable it.
(override with '-T permissive' option)
Utility Disco:
faxus ha scritto: KP sta invecchiando, latita e ci tocca fare gli straordinari......
E che cavolo, non ci si può distrarre un attimo (ero al cinema).
Idem anche a me, sia su SSD che su disco originale
Probabilmente lo avete disabilitato, chissà come e perché.
Anche a me, come a Kext, va come deve
faxus ha scritto:Probabilmente lo avete disabilitato, chissà come e perché.
Propendo di più nel pensare che la funzione SMART di EtreCheck, fra l'altro appena introdotta nel programma e quindi non testata a sufficienza, possa dare qualche risultato sballato.
OsX (il mio si chiama ancora così :wink: ) anche in Informazioni di Sistema/Resoconto, così come in Utility Disco, mi da "Stato S.M.A.R.T.: Verificato".
Jethro ha scritto:... Propendo di più nel pensare che la funzione SMART di EtreCheck, fra l'altro appena introdotta nel programma e quindi non testata a sufficienza, possa dare qualche risultato sballato....
Impossibile.
Usa l'utilità smartmontool di Terminale
Jethro ha scritto:... OsX (il mio si chiama ancora così :wink: ) anche in Informazioni di Sistema/Resoconto, così come in Utility Disco, mi da "Stato S.M.A.R.T.: Verificato".
Sono nomi...
Verificato = il disco non ha grossi danni, ma può esser disattivata la raccolta dati..
Ocio a dove mettete le zampe, oggi lo provo sull'SSD..
anche da SSD nessun problema..
Model Family:     SiliconMotion based SSDs
Device Model:     CT240BX200SSD1
Serial Number:    1614F019C75B
LU WWN Device Id: 5 00a075 1f019c75b
Firmware Version: MU02.6
User Capacity:    240,057,409,536 bytes [240 GB]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Nov  2 17:43:33 2016 CET
					was never started.
					been run.
data collection: 		(    0) seconds.
capabilities: 			 (0x71) SMART execute Offline immediate.
					No Auto Offline data collection support.
					command.
					No Offline surface scan supported.
SMART capabilities:            (0x0002)	Does not save SMART data before
					entering power-saving mode.
recommended polling time: 	 (   1) minutes.
Conveyance self-test routine
SCT capabilities: 	       (0x0035)	SCT Status supported.
  1 Raw_Read_Error_Rate     0x0000   100   100   000    Old_age   Offline      -       0
  5 Reallocated_Sector_Ct   0x0000   100   100   000    Old_age   Offline      -       0
  9 Power_On_Hours          0x0000   100   100   000    Old_age   Offline      -       8
 12 Power_Cycle_Count       0x0000   100   100   000    Old_age   Offline      -       191
160 Uncorrectable_Error_Cnt 0x0000   100   100   000    Old_age   Offline      -       0
161 Valid_Spare_Block_Cnt   0x0000   100   100   000    Old_age   Offline      -       19
163 Initial_Bad_Block_Count 0x0000   100   100   000    Old_age   Offline      -       359
148 Total_SLC_Erase_Ct      0x0000   100   100   000    Old_age   Offline      -       5633
149 Max_SLC_Erase_Ct        0x0000   100   100   000    Old_age   Offline      -       160
150 Min_SLC_Erase_Ct        0x0000   100   100   000    Old_age   Offline      -       16
151 Average_SLC_Erase_Ct    0x0000   100   100   000    Old_age   Offline      -       77
164 Total_Erase_Count       0x0000   100   100   000    Old_age   Offline      -       664
165 Max_Erase_Count         0x0000   100   100   000    Old_age   Offline      -       28
166 Min_Erase_Count         0x0000   100   100   000    Old_age   Offline      -       0
167 Average_Erase_Count     0x0000   100   100   000    Old_age   Offline      -       0
169 Remaining_Lifetime_Perc 0x0000   100   100   001    Old_age   Offline      -       100
181 Program_Fail_Cnt_Total  0x0000   100   100   000    Old_age   Offline      -       0
182 Erase_Fail_Count_Total  0x0000   100   100   000    Old_age   Offline      -       0
192 Power-Off_Retract_Count 0x0000   100   100   000    Old_age   Offline      -       1
194 Temperature_Celsius     0x0000   100   100   070    Old_age   Offline      -       20 (30 27 28 28 0)
199 UDMA_CRC_Error_Count    0x0000   100   100   000    Old_age   Offline      -       0
232 Available_Reservd_Space 0x0000   100   100   000    Old_age   Offline      -       100
241 Host_Writes_32MiB       0x0000   100   100   000    Old_age   Offline      -       2332
242 Host_Reads_32MiB        0x0000   100   100   000    Old_age   Offline      -       7143
245 TLC_Writes_32MiB        0x0000   100   100   000    Old_age   Offline      -       3921
246 SLC_Writes_32MiB        0x0000   100   100   000    Old_age   Offline      -       11266
247 Raid_Recoverty_Ct       0x0000   100   100   000    Old_age   Offline      -       0
No Errors Logged
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
    6        0    65535  Read_scanning was never started
EtreCheck - 3.1.2
Chissà se a Jethro e Scialla adesso funziona il check su SMART...
Torna a “Aggiornamenti”
