Scusa , ma non rammento se te l'ho gia' inviato.Ad ogni modo nessuna stampante e' collegata al Mac.
Amos
error_log:
Description: Printer error log
Last Modified: 11/06/07 14:24
Recent Contents: ...
I [10/Jun/2007:05:55:06 -0700] Listening to 300f40:0
I [10/Jun/2007:05:55:06 -0700] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [10/Jun/2007:05:55:06 -0700] Configured for up to 100 clients.
I [10/Jun/2007:05:55:06 -0700] Allowing up to 100 client connections per host.
I [10/Jun/2007:05:55:06 -0700] Full reload is required.
I [10/Jun/2007:05:55:06 -0700] Full reload complete.
I [10/Jun/2007:05:55:07 -0700] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
I [10/Jun/2007:05:55:10 -0700] Listening to 7f000001:631
I [10/Jun/2007:05:55:10 -0700] Listening to 300f40:0
I [10/Jun/2007:05:55:10 -0700] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [10/Jun/2007:05:55:10 -0700] Configured for up to 100 clients.
I [10/Jun/2007:05:55:10 -0700] Allowing up to 100 client connections per host.
I [10/Jun/2007:05:55:10 -0700] Full reload is required.
I [10/Jun/2007:05:55:10 -0700] Full reload complete.
I [10/Jun/2007:15:14:37 +0200] Listening to 7f000001:631
I [10/Jun/2007:15:14:37 +0200] Listening to 300f50:0
I [10/Jun/2007:15:14:37 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [10/Jun/2007:15:14:37 +0200] Configured for up to 100 clients.
I [10/Jun/2007:15:14:37 +0200] Allowing up to 100 client connections per host.
I [10/Jun/2007:15:14:37 +0200] Full reload is required.
I [10/Jun/2007:15:14:38 +0200] Full reload complete.
I [10/Jun/2007:15:14:38 +0200] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
I [10/Jun/2007:15:48:48 +0200] Listening to 7f000001:631
I [10/Jun/2007:15:48:48 +0200] Listening to 300f50:0
I [10/Jun/2007:15:48:48 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [10/Jun/2007:15:48:48 +0200] Configured for up to 100 clients.
I [10/Jun/2007:15:48:48 +0200] Allowing up to 100 client connections per host.
I [10/Jun/2007:15:48:48 +0200] Full reload is required.
I [10/Jun/2007:15:48:49 +0200] Full reload complete.
I [10/Jun/2007:15:48:49 +0200] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
I [10/Jun/2007:15:58:37 +0200] Listening to 7f000001:631
I [10/Jun/2007:15:58:37 +0200] Listening to 300f50:0
I [10/Jun/2007:15:58:37 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [10/Jun/2007:15:58:37 +0200] Configured for up to 100 clients.
I [10/Jun/2007:15:58:37 +0200] Allowing up to 100 client connections per host.
I [10/Jun/2007:15:58:37 +0200] Full reload is required.
I [10/Jun/2007:15:58:37 +0200] Full reload complete.
I [10/Jun/2007:15:58:37 +0200] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
I [11/Jun/2007:13:39:32 +0200] Listening to 7f000001:631
I [11/Jun/2007:13:39:32 +0200] Listening to 300f50:0
I [11/Jun/2007:13:39:32 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [11/Jun/2007:13:39:32 +0200] Configured for up to 100 clients.
I [11/Jun/2007:13:39:32 +0200] Allowing up to 100 client connections per host.
I [11/Jun/2007:13:39:32 +0200] Full reload is required.
I [11/Jun/2007:13:39:32 +0200] Full reload complete.
I [11/Jun/2007:13:39:32 +0200] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
I [11/Jun/2007:13:52:34 +0200] Listening to 7f000001:631
I [11/Jun/2007:13:52:34 +0200] Listening to 300f50:0
I [11/Jun/2007:13:52:34 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [11/Jun/2007:13:52:34 +0200] Configured for up to 100 clients.
I [11/Jun/2007:13:52:34 +0200] Allowing up to 100 client connections per host.
I [11/Jun/2007:13:52:34 +0200] Full reload is required.
I [11/Jun/2007:13:52:34 +0200] Full reload complete.
E [11/Jun/2007:13:52:34 +0200] get_printer_attrs: resource name '/printers/ ' no good!
E [11/Jun/2007:13:52:37 +0200] get_printer_attrs: resource name '/printers/ ' no good!
I [11/Jun/2007:14:11:26 +0200] Listening to 7f000001:631
I [11/Jun/2007:14:11:26 +0200] Listening to 300f50:0
I [11/Jun/2007:14:11:26 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [11/Jun/2007:14:11:26 +0200] Configured for up to 100 clients.
I [11/Jun/2007:14:11:26 +0200] Allowing up to 100 client connections per host.
I [11/Jun/2007:14:11:26 +0200] Full reload is required.
I [11/Jun/2007:14:11:27 +0200] Full reload complete.
I [11/Jun/2007:14:11:27 +0200] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
I [11/Jun/2007:14:24:27 +0200] Listening to 7f000001:631
I [11/Jun/2007:14:24:27 +0200] Listening to 300f50:0
I [11/Jun/2007:14:24:27 +0200] Loaded configuration file "/private/etc/cups/cupsd.conf"
I [11/Jun/2007:14:24:27 +0200] Configured for up to 100 clients.
I [11/Jun/2007:14:24:27 +0200] Allowing up to 100 client connections per host.
I [11/Jun/2007:14:24:27 +0200] Full reload is required.
I [11/Jun/2007:14:24:27 +0200] Full reload complete.
I [11/Jun/2007:14:24:27 +0200] Printer sharing is off and there are no jobs pending, will restart on demand. Exiting.
panic.log:
Description: Panic (system crashes) log
Recent Contents: Sun Jun 10 15:58:36 2007
Unresolved kernel trap(cpu 0): 0x300 - Data access DAR=0x0000000002FFF9E8 PC=0x000000000027C8F4
Latest crash info for cpu 0:
Exception state (sv=0x28010780)
PC=0x0027C8F4; MSR=0x00009030; DAR=0x02FFF9E8; DSISR=0x40000000; LR=0x0027C940; R1=0x17E7BD10; XCP=0x0000000C (0x300 - Data access)
Backtrace:
0x0027C910 0x0027C560 0x002715E0 0x000A9654
Proceeding back via exception chain:
previously dumped8as "Latest" stare. skipping...
8 Exception stare (sv=0x30406280)
PC=0x9001EFCC; MSR=0x0000D030; DAR=0x2207E044; DSISR=0x40000000; LR=0x9075CE4C; R1=0xF0294C90; XCP=0x00000030 (0xC00 - ystem call)
Kenel version:
D yin Kernel Verenn 8.0.0: Sat ri26 14:15:22 eTn2005; root: -i92.obj~1/RE eSn_PPC
panic(cpu 0 caller 0xFFFF0003): 0x300 - Data access
Latest stack backtrace for cpu 0:
Backtrace:
0x00095564 0x00095A7C 0x00026838 0x000A8184 0x000AB880
kmod scan stopped due to missing kmod page: 00000000
Backtrace:
Exception state (sv=0x30406280)
PC=0x9001EFCC; MSR=0x0000D030; DAR=0x2207E044; DSISR=0x40000000; LR=0x9075CE4C; R1=0xF0294C90; XCP=0x00000030 (0xC00 - System call)
Kernel version:
Darwin Kernel Version 8.0.0: Sat Mar 26 14:15:22 PST 2005; root:xnu-792.obj~1/RELEASE_PPC
Mon Jun 11 14:24:26 2007
panic(cpu 0 caller 0x00220034): hfs_getnewvnode: orphaned rsrc fork
Backtrace:
0x00095564 0x00095A7C 0x00026838 0x00220034 0x00239DE0 0x00235934 0x000FABF4 0x000F987C
0x000F4890 0x0025AC18 0x002A8174 0x000ABA30 0x01F53A40
Exception state (sv=0x2FC55A00)
PC=0x9000512C; MSR=0x0000D030; DAR=0xE0ABE638; DSISR=0x40000000; LR=0x90A8ADB0; R1=0xBFFFE600; XCP=0x00000030 (0xC00 - System call)
Kernel version:
system.log:
Description: System events log
Last Modified: 07/06/07 03:44
Jun 11 14:24:13 localhost lookupd[92]: lookupd (version 365) starting - Mon Jun 11 14:24:13 2007
Jun 11 14:24:14 localhost kernel[0]: jnl: replay_journal: from: 94720 to: 275968 (joffset 0x265000)
Jun 11 14:24:14 localhost diskarbitrationd[57]: disk1s5 hfs 0EF5F1B8-BE4B-349C-B364-9B608ACEE01C Rupert /Volumes/Rupert
Jun 11 14:24:14 localhost kernel[0]: NVDA,Display-A: vram [98000000:08000000]
Jun 11 14:24:15 localhost kernel[0]: NVDA,Display-B: vram [00000000:01000000]
Jun 11 14:24:15 localhost /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow: Login Window Application Started
Jun 11 14:24:15 localhost loginwindow[98]: Login Window Started Security Agent
Jun 11 14:24:16 localhost mDNSResponder: Adding browse domain local.
Jun 11 14:24:22 Macintosh configd[55]: setting hostname to "Macintosh.local"
Jun 11 14:24:34 Macintosh kernel[0]: AppleSMU::PMU vers = 0x000d004f, SPU vers = 0x18, SDB vers = 0x01,
Jun 7 03:43:41 localhost kernel[0]: standard timeslicing quantum is 10000 us
Jun 7 03:43:40 localhost mDNSResponder-107 (Mar 20 2005 20: 31:47)[49]: starting
Jun 7 03:43:42 localhost kernel[0]: vm_page_bootstrap: 250731 free pages
Jun 7 03:43:40 localhost DirectoryService[46]: Launched version 1.8 (v346)
Jun 7 03:43:42 localhost kernel[0]: mig_table_max_displ = 70
Jun 7 03:43:42 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Jun 7 03:43:42 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Jun 7 03:43:42 localhost kernel[0]: using 2621 buffer headers and 2621 cluster IO buffer headers
Jun 7 03:43:42 localhost kernel[0]: DART enabled
Jun 7 03:43:42 localhost kernel[0]: AppleKauaiATA shasta-ata features enabled
Jun 7 03:43:42 localhost kernel[0]: MacRISC4CPU: publishing BootCPU
Jun 7 03:43:41 localhost lookupd[47]: lookupd (version 365) starting - Thu Jun 7 03:43:41 2007
Jun 7 03:43:42 localhost kernel[0]: WARNING: ATA Drive claims FLUSH CACHE EXT feature support but does not claim Extended LBA feature support
Jun 7 03:43:42 localhost kernel[0]: FireWire (OHCI) Apple ID 52 built-in now active, GUID 000d93ff fe39c442; max speed s800.
Jun 7 03:43:42 localhost kernel[0]: Extension "com.apple.driver.PioneerSuperDrive" has no kernel dependency.
Jun 7 03:43:42 localhost kernel[0]: Security auditing service present
Jun 7 03:43:42 localhost kernel[0]: BSM auditing present
Jun 7 03:43:42 localhost kernel[0]: disabled
Jun 7 03:43:42 localhost kernel[0]: rooting via boot-uuid from /chosen: 364082C0-D7D8-3053-8746-3B1939C6B2E5
Jun 7 03:43:42 localhost kernel[0]: Waiting on IOProviderClassIOResourcesIOResourceMatchboot-uuid-media
Jun 7 03:43:42 localhost kernel[0]: Got boot device = IOService:/MacRISC4PE/ht@0,f2000000/AppleMacRiscHT/pci@3/IOPCI2PCIBridge/k2-sata-root@C/AppleK2SATARoot/k2-sata@0/AppleK2SATA/ATADeviceNub@0/IOATABlockStorageDriver/IOATABlockStorageDevice/IOBlockStorageDriver/Maxtor 6Y120M0 Media/IOApplePartitionScheme/Apple_HFS_Untitled_1@3
Jun 7 03:43:42 localhost kernel[0]: BSD root: disk0s3, major 14, minor 2
Jun 7 03:43:42 localhost kernel[0]: jnl: replay_journal: from: 14953472 to: 12950016 (joffset 0x395000)
Jun 7 03:43:42 localhost kernel[0]: AppleSMU -- shutdown cause = 3
Jun 7 03:43:42 localhost kernel[0]: Jettisoning kernel linker.
Jun 7 03:43:42 localhost kernel[0]: Resetting IOCatalogue.
Jun 7 03:43:42 localhost kernel[0]: Matching service count = 1
Jun 7 03:43:42 localhost kernel[0]: NVDANV30HAL loaded and registered.
Jun 7 03:43:42 localhost kernel[0]: AppleSMU:: getProperty partitionAddress or length zero on partition number 0x05
Jun 7 03:43:42 localhost diskarbitrationd[41]: disk0s3 hfs 364082C0-D7D8-3053-8746-3B1939C6B2E5 Manuel /
Jun 7 03:43:43 localhost kernel[0]: UniNEnet: Ethernet address 00:0d:93:39:c4:42
Jun 7 03:43:43 localhost launchd: Server 270b in bootstrap 1103 uid 0: "/usr/sbin/lookupd"[47]: exited abnormally: Hangup
Jun 7 03:43:43 localhost lookupd[61]: lookupd (version 365) starting - Thu Jun 7 03:43:43 2007
Jun 7 03:43:45 localhost kernel[0]: NVDA,Display-A: vram [98000000:08000000]
Jun 7 03:43:45 localhost kernel[0]: NVDA,Display-B: vram [00000000:01000000]
Jun 7 03:43:46 localhost mDNSResponder: Adding browse domain local.
Jun 7 03:43:48 localhost /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow: Login Window Application Started
Jun 7 03:43:50 Macintosh configd[39]: setting hostname to "Macintosh.local"
Jun 7 03:43:52 Macintosh loginwindow[68]: Login Window Started Security Agent
Jun 7 03:44:00 Macintosh /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer: (-3230) Cannot use ATS Persistent Store - switching to old FODB cache code
Jun 7 03:44:04 Macintosh kernel[0]: AppleSMU::PMU vers = 0x000d004f, SPU vers = 0x18, SDB vers = 0x01,
Jun 7 03:44:33 Macintosh /Applications/Utilities/System Profiler.app/Contents/MacOS/System Profiler: cupsd's bootstrap server port not found
