allora il problema ce l'ho anche senza mixer attaccato quindi dipende solo dal programma...ho copiato qui i dettagli dell'errore che mi da il computer
se ci capite qualcosa....
Process: Traktor 3 LE [573]
Path: /Users/claudiorossi/Desktop/Traktor 3 LE.app/Contents/MacOS/Traktor 3 LE
Identifier: com.native-instruments.Traktor 3 LE
Version: 3.3.2.010 (3.3.2, Copyright © 2007 Native Instruments)
Code Type: X86 (Native)
Parent Process: launchd [78]
Date/Time: 2009-12-06 17:53:13.205 +0100
OS Version: Mac OS X 10.6.2 (10C540)
Report Version: 6
Interval Since Last Report: 84072 sec
Crashes Since Last Report: 7
Per-App Interval Since Last Report: 2119 sec
Per-App Crashes Since Last Report: 8
Anonymous UUID: 9F2ABF5D-1622-4A59-9C48-DE032F7B201E
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000003f7ffffc
Crashed Thread: 5
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x91e648da mach_msg_trap + 10
1 libSystem.B.dylib 0x91e65047 mach_msg + 68
2 com.apple.CoreFoundation 0x938f677f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x938f5864 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x938f5691 CFRunLoopRunInMode + 97
5 com.apple.HIToolbox 0x94374f0c RunCurrentEventLoopInMode + 392
6 com.apple.HIToolbox 0x94374cc3 ReceiveNextEventCommon + 354
7 com.apple.HIToolbox 0x944fcc02 _AcquireNextEvent + 54
8 com.apple.HIToolbox 0x944f2944 RunApplicationEventLoop + 228
9 ...ve-instruments.Traktor 3 LE 0x003870a4 NI::UIA::Application::run() + 36
10 ...ve-instruments.Traktor 3 LE 0x00396303 NI::UIA::DETAIL::AppModuleStartup::run() + 99
11 ...ve-instruments.Traktor 3 LE 0x0028613b main + 59
12 ...ve-instruments.Traktor 3 LE 0x00002582 _start + 216
13 ...ve-instruments.Traktor 3 LE 0x000024a9 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x91e8b0ea kevent + 10
1 libSystem.B.dylib 0x91e8b804 _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x91e8acc3 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x91e8aa68 _dispatch_worker_thread2 + 234
4 libSystem.B.dylib 0x91e8a4f1 _pthread_wqthread + 390
5 libSystem.B.dylib 0x91e8a336 start_wqthread + 30
Thread 2:
2 com.apple.audio.midi.CoreMIDI 0x011b8f21 XServerMachPort::ReceiveMessage(int&, void*, int&) + 155
3 com.apple.audio.midi.CoreMIDI 0x011d78ee MIDIProcess::RunMIDIInThread() + 150
4 com.apple.audio.midi.CoreMIDI 0x011ba139 XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x011b9b06 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x91e91fbd _pthread_start + 345
7 libSystem.B.dylib 0x91e91e42 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x91e64916 semaphore_wait_trap + 10
1 ...ve-instruments.Traktor 3 LE 0x003017b3 NI::GP::HEvent::wait() + 19
2 ...ve-instruments.Traktor 3 LE 0x0060af47 NI::UIA::AsyncNameServices::run() + 103
3 ...ve-instruments.Traktor 3 LE 0x00301127 NI::GP::Thread::execute(void*) + 71
4 libSystem.B.dylib 0x91e91fbd _pthread_start + 345
5 libSystem.B.dylib 0x91e91e42 thread_start + 34
Thread 4:
2 ...ve-instruments.Traktor 3 LE 0x005443a3 NI::UIA::DETAIL::SocketImplPOSIXBase::run() + 99
Thread 5 Crashed:
0 ...ve-instruments.Traktor 3 LE 0x0052a7b9 PVDeleteInstanceAltiVec(void*) + 25 (mm_malloc.h:74)
1 ...ve-instruments.Traktor 3 LE 0x003dd385 CElastique::~CElastique() + 119 (elastiqueAPI.h:124)
2 ...ve-instruments.Traktor 3 LE 0x0034b981 CElastiqueIf::DestroyInstance(CElastiqueIf*) + 21 (elastiqueAPI.cpp:97)
3 ...ve-instruments.Traktor 3 LE 0x0013d13c AudioDeck::load(char const*, TrackID const*) + 908
4 ...ve-instruments.Traktor 3 LE 0x000670cc MixerDeck::LoadThread::run() + 1340
5 ...ve-instruments.Traktor 3 LE 0x00301127 NI::GP::Thread::execute(void*) + 71
Thread 6:
0 libSystem.B.dylib 0x91e649ee mach_wait_until + 10
1 libSystem.B.dylib 0x91eec9e5 nanosleep + 345
2 libSystem.B.dylib 0x91eec886 usleep + 61
3 ...ve-instruments.Traktor 3 LE 0x00300f65 NI::GP::HThread::sleepCurrentThread(int) + 21
4 ...ve-instruments.Traktor 3 LE 0x00062ebb MixerDeck::RefreshThread::run() + 139
Thread 7:
0 libSystem.B.dylib 0x91eb583b cos$fenv_access_off + 75
1 libvDSP.dylib 0x9701ba8c vDSP_vmma + 26618
Thread 8:
4 ...ve-instruments.Traktor 3 LE 0x001ba60c TraktorApp::RecorderThread::run() + 44
Thread 9:
0 libSystem.B.dylib 0x91e6493a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x91e92445 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x91ec1028 pthread_cond_timedwait_relative_np + 47
3 com.apple.audio.CoreAudio 0x97093965 CAGuard::WaitFor(unsigned long long) + 219
4 com.apple.audio.CoreAudio 0x97096997 CAGuard::WaitUntil(unsigned long long) + 289
5 com.apple.audio.CoreAudio 0x97094294 HP_IOThread::WorkLoop() + 1892
6 com.apple.audio.CoreAudio 0x97093b2b HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7 com.apple.audio.CoreAudio 0x97093a42 CAPThread::Entry(CAPThread*) + 140
8 libSystem.B.dylib 0x91e91fbd _pthread_start + 345
9 libSystem.B.dylib 0x91e91e42 thread_start + 34
Thread 5 crashed with X86 Thread State (32-bit):
eax: 0x3f800000 ebx: 0x003dd31c ecx: 0x000ddec0 edx: 0x0242ea00
edi: 0x015bb090 esi: 0x015bb098 ebp: 0xb030ace8 esp: 0xb030acc0
ss: 0x0000001f efl: 0x00010206 eip: 0x0052a7b9 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x3f7ffffc
Binary Images:
0x1000 - 0x9b2fef +com.native-instruments.Traktor 3 LE 3.3.2.010 (3.3.2, Copyright © 2007 Native Instruments) /Users/claudiorossi/Desktop/Traktor 3 LE.app/Contents/MacOS/Traktor 3 LE
0x11a9000 - 0x11f5ff3 com.apple.audio.midi.CoreMIDI 1.7 (42) <7DB334D3-C8AD-8AA1-3B44-C91F69AAC49C> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x19903000 - 0x19907ff3 com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <C36F9194-6DB6-0AA8-4839-71191EEBAC65> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1990c000 - 0x19912ffb com.apple.audio.AppleHDAHALPlugIn 1.7.9 (1.7.9a4) <A686EC36-C3D5-131F-46D2-F174F5477C77> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <226BF7A0-94E0-2F4C-6D6B-9189C952331C> /usr/lib/dyld
0x90003000 - 0x90029fff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x90034000 - 0x90081feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <2F84B032-B7C8-848B-2035-5AEC565F7712> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x901e2000 - 0x90228ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x90229000 - 0x90229ff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9022a000 - 0x90273fe7 libTIFF.dylib ??? (???) <5864AE5B-EAEB-F8B6-18FB-3D27B7895A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x902a8000 - 0x902bcffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <8D562874-9298-9939-DAEE-7D1648F80C46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x902bd000 - 0x90624ff7 com.apple.QuartzCore 1.6.1 (227.
![Cool 8)](./images/smilies/icon_cool.gif)
<8B90AB08-46A4-1C5C-4E71-C6AB652477B9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90625000 - 0x90669ff3 com.apple.coreui 2 (113) <D0FA9B36-3708-D5BF-0CC3-6CC1909BC8E6> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9066a000 - 0x9071dfff libFontParser.dylib ??? (???) <FAD5E96D-CF93-CC86-6B30-A6594B930772> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9078f000 - 0x90792ffb com.apple.help 1.3.1 (41) <27544F8D-B795-E33B-7EB5-6EA3AB6F6B79> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91763000 - 0x919c5ff7 com.apple.security 6.0 (36910) <32B8FA26-CD73-4C45-C15A-EF8406D51FCC> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91a00000 - 0x91a00ff7 com.apple.Carbon 150 (152) <A94B072C-2897-61D3-FE37-A89FB52DD81B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91a42000 - 0x91a4cfe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x91a4d000 - 0x91e63ff7 libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91e64000 - 0x92008feb libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
0x92009000 - 0x9202dff7 libJPEG.dylib ??? (???) <649E1974-A527-AC0B-B3F4-B4DC30484070> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x924a6000 - 0x92515ff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x92635000 - 0x92636ff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x92637000 - 0x9264bfe7 libbsm.0.dylib ??? (???) <0476BD2A-BF85-4DDF-3CBC-00B690284B93> /usr/lib/libbsm.0.dylib
0x9264c000 - 0x92729ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9272a000 - 0x92731fff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92732000 - 0x927cefe7 com.apple.ApplicationServices.ATS 4.1 (???) <EA26375D-8276-9671-645D-D28CAEC95292> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
[/list]
