Dec 3 00:30:01 host23-194-dynamic newsyslog[28922]: logfile turned over
Dec 3 01:08:18 host23-194-dynamic hdiejectd[36040]: running
Dec 3 01:08:36 host23-194-dynamic hdiejectd[36040]: quitCheck: calling exit(0)
Dec 3 02:02:06 host23-194-dynamic [0x0-0x26026].org.mozilla.firefox[280]: Debugger() was called!
Dec 3 02:25:17 host23-194-dynamic pppd[139]: Connection terminated.
Dec 3 02:25:17 host23-194-dynamic configd[15]: network configuration changed.
Dec 3 02:25:17 host23-194-dynamic pppd[139]: PPPoE disconnecting...
Dec 3 02:25:17 host23-194-dynamic pppd[139]: PPPoE disconnected
Dec 3 02:25:17 host23-194-dynamic configd[15]: SCNCController: Disconnecting. (Connection was up for, 25747 seconds).
Dec 3 02:25:27 host23-194-dynamic com.apple.launchd.peruser.501[90] ([0x0-0x1e01e].com.apple.TextEdit[211]): Exited: Killed
Dec 3 02:25:27 host23-194-dynamic com.apple.launchd.peruser.501[90] ([0x0-0x24024].com.apple.Preview[244]): Exited: Killed
Dec 3 02:25:27 host23-194-dynamic loginwindow[39]: DEAD_PROCESS: 39 console
Dec 3 02:25:27 host23-194-dynamic loginwindow[39]: CGSShutdownServerConnections: Detaching application from window server
Dec 3 02:25:27 host23-194-dynamic loginwindow[39]: CGSDisplayServerShutdown: Detaching display subsystem from window server
Dec 3 02:25:27 host23-194-dynamic com.apple.loginwindow[39]: Thu Dec 3 02:25:27 host23-194-dynamic.52-79-r.retail.telecomitalia.it loginwindow[39] <Warning>: CGSShutdownServerConnections: Detaching application from window server
Dec 3 02:25:27 host23-194-dynamic com.apple.loginwindow[39]: Thu Dec 3 02:25:27 host23-194-dynamic.52-79-r.retail.telecomitalia.it loginwindow[39] <Warning>: CGSDisplayServerShutdown: Detaching display subsystem from window server
Dec 3 02:25:27 host23-194-dynamic ManagedClient[43278]: ManagedClient- must run as root
Dec 3 02:25:27 host23-194-dynamic com.apple.loginwindow[39]: 2009-12-03 02:25:27.877 ManagedClient[43278:903] ManagedClient- must run as root
Dec 3 02:25:29 host23-194-dynamic loginwindow[39]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 02:25:29 host23-194-dynamic com.apple.loginwindow[39]: Thu Dec 3 02:25:29 host23-194-dynamic.52-79-r.retail.telecomitalia.it loginwindow[39] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 02:25:29 host23-194-dynamic /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[43279]: Login Window Application Started
Dec 3 02:25:31 host23-194-dynamic loginwindow[43279]: Login Window Started Security Agent
Dec 3 02:25:31 host23-194-dynamic WindowServer[43280]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 02:25:31 host23-194-dynamic com.apple.WindowServer[43280]: Thu Dec 3 02:25:31 host23-194-dynamic.52-79-r.retail.telecomitalia.it WindowServer[43280] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 02:25:47 iMac configd[15]: setting hostname to "iMac.local"
Dec 3 02:26:17 iMac loginwindow[43279]: Login Window - Returned from Security Agent
Dec 3 02:26:17 iMac shutdown[43301]: halt by _spotlight:
Dec 3 02:26:17 iMac shutdown[43301]: SHUTDOWN_TIME: 1259803577 318628
Dec 3 02:26:37 iMac mDNSResponder[18]: mDNSResponder mDNSResponder-214 (Oct 16 2009 06:09:30) stopping
Dec 3 02:26:37 iMac SecurityAgent[43290]: CGSShutdownServerConnections: Detaching application from window server
Dec 3 02:26:37 iMac WindowServer[43280]: hidd died. Reestablishing connection.
Dec 3 02:26:37 iMac WindowServer[43280]: bootstrap_look_ip failed: Unknown service name
Dec 3 02:26:37 iMac /usr/sbin/qmasterd[71]: dnssd_clientstub read_all(9) failed 0/28 0
Dec 3 02:26:37 iMac SecurityAgent[43290]: MIG: server died: CGSReleaseShmem : Cannot release shared memory
Dec 3 02:26:37 iMac SecurityAgent[43290]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 02:26:37 iMac SecurityAgent[43290]: CGSDisplayServerShutdown: Detaching display subsystem from window server
Dec 3 02:26:37 iMac SecurityAgent[43290]: kCGErrorRangeCheck: On-demand launch of the Window Server is allowed for root user only.
Dec 3 02:26:37 iMac SecurityAgent[43290]: HIToolbox: received notification of WindowServer event port death.
Dec 3 02:26:37 iMac SecurityAgent[43290]: port matched the WindowServer port created in BindCGSToRunLoop
Dec 3 19:54:56 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Dec 3 19:55:01 localhost mDNSResponder[18]: mDNSResponder mDNSResponder-214 (Oct 16 2009 06:09:30) starting
Dec 3 19:55:02 localhost configd[15]: BUG in libdispatch: 10C540 - 1678 - 0x9b07
Dec 3 19:55:09 localhost bootlog[47]: BOOT_TIME: 1259866496 0
Dec 3 19:55:12 localhost configd[15]: network configuration changed.
Dec 3 19:55:12 iMac configd[15]: setting hostname to "iMac.local"
Dec 3 19:55:12 iMac com.apple.usbmuxd[30]: usbmuxd-176 built for iTunesNineDot on Sep 24 2009 at 16:11:05, running 32 bit
Dec 3 19:55:13 iMac org.apache.httpd[27]: httpd: Could not reliably determine the server's fully qualified domain name, using iMac.local for ServerName
Dec 3 19:55:15 iMac blued[48]: Apple Bluetooth daemon started
Dec 3 19:55:15 iMac /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[37]: Login Window Application Started
Dec 3 19:55:16 iMac configd[15]: network configuration changed.
Dec 3 19:55:19 iMac com.apple.SystemStarter[31]: Starting Qmaster services
Dec 3 19:55:22 iMac loginwindow[37]: Login Window Started Security Agent
Dec 3 19:55:23 iMac loginwindow[37]: Login Window - Returned from Security Agent
Dec 3 19:55:23 iMac loginwindow[37]: USER_PROCESS: 37 console
Dec 3 19:55:23 iMac com.apple.launchctl.Aqua[89]: launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/com.adobe.versioncueCS4.monitor.plist
Dec 3 19:55:23 iMac com.apple.launchctl.Aqua[89]: launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/trial_expired_NTFS.plist
Dec 3 19:55:23 iMac com.apple.launchd.peruser.501[87] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Dec 3 19:55:26 iMac com.apple.launchd.peruser.501[87] (com.apple.Kerberos.renew.plist[108]): Exited with exit code: 1
Dec 3 19:55:26 iMac com.apple.launchd.peruser.501[87] (0x1001040a0.mach_init.NTFS for Mac OS X): Failed to check-in!
Dec 3 19:55:26 iMac com.apple.launchd.peruser.501[87] ([0x0-0xb00b].com.linotype.FontExplorerX.Autoload[120]): Exited with exit code: 255
Dec 3 19:55:29 iMac WindowServer[60]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 19:55:29 iMac com.apple.WindowServer[60]: Thu Dec 3 19:55:29 iMac.local WindowServer[60] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Dec 3 19:55:29 iMac com.apple.launchd.peruser.501[87] (0x100103dd0.mach_init.VersionCueCS4monitor): Failed to check-in!
Dec 3 19:55:30 iMac OpenTerminal[118]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
Dec 3 19:55:30 iMac OpenTerminal[118]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/QXPScriptingAdditions.osax"
Dec 3 19:55:31 iMac _mdnsresponder[126]: sntp options: a=2 v=1 e=0.100 E=5.000 P=2147483647.000
Dec 3 19:55:31 iMac _mdnsresponder[126]: d=15 c=5 x=0 op=1 l=/var/run/sntp.pid f= time.euro.apple.com
Dec 3 19:55:31 iMac _mdnsresponder[126]: sntp: unable to set up access to NTP server time.euro.apple.com
Dec 3 19:55:41 iMac pppd[129]: pppd 2.4.2 (Apple version 412) started by Fabio, uid 501
Dec 3 19:55:41 iMac pppd[129]: PPPoE connecting to service 'Alice' [access concentrator '']...
Dec 3 19:55:41 iMac pppd[129]: PPPoE connection established.
Dec 3 19:55:41 iMac pppd[129]: Connect: ppp0 <--> socket[34:16]
Dec 3 19:55:42 iMac pppd[129]: PAP authentication succeeded
Dec 3 19:55:42 iMac pppd[129]: local IP address 79.36.197.9
Dec 3 19:55:42 iMac pppd[129]: remote IP address 80.21.255.161
Dec 3 19:55:42 iMac pppd[129]: primary DNS address 85.37.17.16
Dec 3 19:55:42 iMac pppd[129]: secondary DNS address 85.38.28.68
Dec 3 19:55:42 iMac configd[15]: network configuration changed.
Dec 3 19:55:42 iMac configd[15]: SCNCController: Connected.
Dec 3 19:55:46 iMac ntpd[25]: Cannot find existing interface for address 17.72.255.12
Dec 3 19:55:46 iMac ntpd[25]: configuration of 17.72.255.12 failed
Dec 3 19:55:46 host9-197-dynamic configd[15]: setting hostname to "host9-197-dynamic.36-79-r.retail.telecomitalia.it"
Dec 3 19:56:41 host9-197-dynamic [0x0-0x14014].org.mozilla.thunderbird[155]: Warning: unrecognized command line flag -psn_0_81940
Dec 3 20:01:26 host9-197-dynamic [0x0-0x15015].org.mozilla.firefox[159]: Debugger() was called!
Dec 3 20:02:32 host9-197-dynamic [0x0-0x15015].org.mozilla.firefox[159]: Debugger() was called!
Dec 3 20:05:26: --- last message repeated 1 time ---
Dec 3 20:05:26 host9-197-dynamic /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[117]: No valid tickets, timing out
Dec 3 20:08:17 host9-197-dynamic [0x0-0x15015].org.mozilla.firefox[159]: Debugger() was called!
Dec 3 20:29:41: --- last message repeated 2 times ---
Dec 3 20:29:41 host9-197-dynamic [0x0-0x15015].org.mozilla.firefox[159]: Debugger() was called!
Dec 3 20:32:49 host9-197-dynamic [0x0-0x15015].org.mozilla.firefox[159]: Debugger() was called!
Dec 3 20:33:31 host9-197-dynamic [0x0-0x15015].org.mozilla.firefox[159]: Debugger() was called!
Dec 3 20:34:27 host9-197-dynamic loginwindow[37]: DEAD_PROCESS: 37 console
Dec 3 20:34:28 host9-197-dynamic pppd[129]: Connection terminated.
Dec 3 20:34:28 host9-197-dynamic configd[15]: network configuration changed.
Dec 3 20:34:28 host9-197-dynamic pppd[129]: PPPoE disconnecting...
Dec 3 20:34:28 host9-197-dynamic pppd[129]: PPPoE disconnected
Dec 3 20:34:28 host9-197-dynamic configd[15]: SCNCController: Disconnecting. (Connection was up for, 2326 seconds).
Dec 3 20:34:28 host9-197-dynamic shutdown[4361]: halt by Fabio:
Dec 3 20:34:28 host9-197-dynamic shutdown[4361]: SHUTDOWN_TIME: 1259868868 359839
Dec 3 20:34:48 host9-197-dynamic mDNSResponder[18]: mDNSResponder mDNSResponder-214 (Oct 16 2009 06:09:30) stopping
Dec 3 20:34:48 host9-197-dynamic WindowServer[60]: hidd died. Reestablishing connection.
Dec 3 20:34:48 host9-197-dynamic WindowServer[60]: bootstrap_look_ip failed: Unknown service name
Dec 3 20:34:48 host9-197-dynamic /usr/sbin/qmasterd[69]: dnssd_clientstub read_all(9) failed 0/28 0
Dec 3 20:35:39 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Dec 3 20:35:44 localhost mDNSResponder[18]: mDNSResponder mDNSResponder-214 (Oct 16 2009 06:09:30) starting
Dec 3 20:35:52 localhost bootlog[47]: BOOT_TIME: 1259868939 0
Dec 3 20:35:55 localhost configd[15]: network configuration changed.
Dec 3 20:35:55 iMac configd[15]: setting hostname to "iMac.local"
Dec 3 20:35:55 iMac com.apple.usbmuxd[30]: usbmuxd-176 built for iTunesNineDot on Sep 24 2009 at 16:11:05, running 32 bit
Dec 3 20:35:56 iMac org.apache.httpd[27]: httpd: Could not reliably determine the server's fully qualified domain name, using iMac.local for ServerName
Dec 3 20:35:57 iMac /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[37]: Login Window Application Started
Dec 3 20:35:57 iMac blued[48]: Apple Bluetooth daemon started
Dec 3 20:35:58 iMac configd[15]: network configuration changed.
Dec 3 20:36:01 iMac com.apple.SystemStarter[31]: Starting Qmaster services
Dec 3 20:36:05 iMac loginwindow[37]: Login Window Started Security Agent
Dec 3 20:36:05 iMac loginwindow[37]: Login Window - Returned from Security Agent
Dec 3 20:36:05 iMac loginwindow[37]: USER_PROCESS: 37 console
Dec 3 20:36:05 iMac com.apple.launchctl.Aqua[89]: launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/com.adobe.versioncueCS4.monitor.plist
Dec 3 20:36:05 iMac com.apple.launchctl.Aqua[89]: launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/trial_expired_NTFS.plist
Dec 3 20:36:05 iMac com.apple.launchd.peruser.501[87] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Dec 3 20:36:07 iMac com.apple.launchd.peruser.501[87] (com.apple.Kerberos.renew.plist[108]): Exited with exit code: 1
Dec 3 20:36:08 iMac com.apple.launchd.peruser.501[87] ([0x0-0xb00b].com.linotype.FontExplorerX.Autoload[121]): Exited with exit code: 255
Dec 3 20:36:08 iMac com.apple.launchd.peruser.501[87] (0x100203da0.mach_init.NTFS for Mac OS X): Failed to check-in!
Dec 3 20:36:09 iMac OpenTerminal[119]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/Adobe Unit Types.osax"
Dec 3 20:36:09 iMac OpenTerminal[119]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/QXPScriptingAdditions.osax"
Dec 3 20:36:09 iMac com.apple.launchd.peruser.501[87] (0x100100c10.mach_init.VersionCueCS4monitor): Failed to check-in!
Dec 3 20:36:13 iMac _mdnsresponder[127]: sntp options: a=2 v=1 e=0.100 E=5.000 P=2147483647.000
Dec 3 20:36:13 iMac _mdnsresponder[127]: d=15 c=5 x=0 op=1 l=/var/run/sntp.pid f= time.euro.apple.com
Dec 3 20:36:13 iMac _mdnsresponder[127]: sntp: unable to set up access to NTP server time.euro.apple.com
c...hai capito, intendevo attaccati forte perché si spegne tanto in fretta che ti scaraventa giù dalla sediaMatleega: attàccati tu!
