Salve a tutti ho un iMac "Late 2012" con processore da 2,7 Ghz i5 e 8 gb di ram lo uso tanto per via del lavoro, da quando ho aggiornato ad high sierra sono aumentati i rallentamenti in modo snervante.
Vi giro il reporto di EtreCheck. grazie per l'aiuto
EtreCheck version: 4.3.2 (4D034)
Report generated: 2018-06-14 19:36:12
Runtime: 5:14
Performance: Below Average
Problem: Computer is too slow
Major Issues:
Anything that appears on this list needs immediate attention.
No Time Machine backup - Time Machine backup not found.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems.
Apps crashing - There have been numerous app crashes.
Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage.
Unsigned files - There is unsigned software installed. They appear to be legitimate but should be reviewed.
System modifications - There are a large number of system modifications running in the background.
Low performance - EtreCheck report took over 5 minutes to run. This is unusual.
Hardware Information:
iMac (21.5-inch, Late 2012)
iMac Model: iMac13,1
1 2,7 GHz Intel Core i5 (i5-3330S) CPU: 4-core
8 GB RAM - Upgradeable
BANK 0/DIMM0 - 4 GB DDR3 1600 ok
BANK 1/DIMM0 - 4 GB DDR3 1600 ok
Video Information:
NVIDIA GeForce GT 640M - VRAM: 512 MB
iMac 1920 x 1080
Drives:
disk0 - APPLE HDD ST1000LM024 1.00 TB (Mechanical)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 - Macintosh HD (Journaled HFS+) 999.35 GB
disk0s3 - Recovery HD [Recovery] 650 MB
Mounted Volumes:
disk0s2 - Macintosh HD 999.35 GB (697.86 GB free)
Journaled HFS+
Mount point: /
Network:
Interface usbmodem1a122: BCM21553-Thunderbird
Interface en0: Ethernet
One IPv4 address
Proxy Auto Discovery
Interface en1: Wi-Fi
802.11 a/b/g/n
Interface en4: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
iCloud Quota: 1.79 GB available
System Software:
macOS High Sierra 10.13.4 (17E202)
Time since boot: About 11 hours
System Load: 1.57 (1 min ago) 1.22 (5 min ago) 1.17 (15 min ago)
Configuration Files:
File /etc/sysctl.conf exists but not expected
Security:
System Status
Gatekeeper Mac App Store and identified developers
System Integrity Protection Enabled
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.efi.lmgr.plist
Executable: /Applications/EFI/EFILM/lmgrd_wrapper.sh /Applications/EFI/EFILM
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/LaunchDaemons/fr.caldera.install_launcher.plist
Executable: /opt/caldera/bin/install_launcher /opt/caldera/lib/calserver.cfg
Launchd: /Library/LaunchAgents/com.efi.cws.analytics.plist
Executable: /Library/Application Support/efiLINQ/efiLINQ -n=CWSServer
Launchd: /Library/LaunchDaemons/com.efi.fieryd.plist
Executable: /usr/local/fieryd
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Launchd: /Library/LaunchDaemons/com.adobe.SwitchBoard.plist
Executable: /Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app/Contents/MacOS/launch.switchboard
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Launchd: /Library/LaunchAgents/com.efi.analytic.wxwidgets.plist
Executable: /Library/Application Support/efiLINQ/efiLINQ -n=wxWidgets
Launchd: /Library/LaunchDaemons/fr.caldera.verifications.plist
Executable: /opt/caldera/bin/osx_verifications
Launchd: /Library/LaunchDaemons/fr.caldera.bridge.plist
Executable: /opt/caldera/bin/calbridge
Launchd: /Library/LaunchDaemons/fr.caldera.calserver.plist
Executable: /opt/caldera/bin/calserver /opt/caldera/lib/calserver.cfg -nobackground
Launchd: /Library/LaunchDaemons/fr.caldera.keyserver.plist
Executable: /opt/caldera/bin/keyserver /opt/caldera/lib/Caldera.licenses -nobackground
Launchd: ~/Library/LaunchAgents/com.adobe.ARM.***.plist
Executable: /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater Helper.app/Contents/MacOS/Adobe Acrobat Updater Helper
Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Kernel Extensions:
/Library/Application Support/HASP/kexts
[Not Loaded] aksfridge_signed.kext (SFNT Germany GmbH, 1.0.16332)
Startup Items:
FlowplusMounts Path: /Library/StartupItems/FlowplusMounts
MySQLCOM Path: /Library/StartupItems/MySQLCOM
System Launch Agents:
[Not Loaded] 9 Apple tasks
[Loaded] 160 Apple tasks
[Running] 121 Apple tasks
[Other] 3 Apple tasks
System Launch Daemons:
[Not Loaded] 33 Apple tasks
[Loaded] 177 Apple tasks
[Running] 123 Apple tasks
Launch Agents:
[Running] com.efi.fpdu.plist (? 8d653d1f - installed 2017-07-07)
[Loaded] com.xrite.device.softwareupdate.plist (? 2f2d6b43 - installed 2015-08-19)
[Loaded] com.efi.cws.analytics.plist (? 860f03c2 - installed 2018-06-14)
[Other] com.efi.analytic.wxwidgets.plist (? d2d90fee - installed 2018-06-14)
[Not Loaded] com.teamviewer.teamviewer_desktop.plist (? 5984e04 - installed 2016-09-19)
[Not Loaded] com.teamviewer.teamviewer.plist (? bb938493 - installed 2016-09-19)
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installed 2014-05-14)
[Loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2016-05-05)
[Loaded] com.oracle.java.Java-Updater.plist (? 9e1f3bbe - installed 2016-12-13)
[Not Loaded] com.efi.FolderMapDockAgent.plist (EFI Inc - installed 2018-05-08)
[Loaded] com.efi.FSMAgent.plist (EFI Inc - installed 2018-04-23)
Launch Daemons:
[Running] com.efi.FRSMailboxSyncServiceDaemon.plist (EFI Inc - installed 2018-05-08)
[Not Loaded] com.teamviewer.teamviewer_service.plist (? e6c7921e - installed 2016-09-19)
[Not Loaded] fr.caldera.verifications.plist (? e8c97501 - installed 2017-09-22)
[Loaded] com.teamviewer.Helper.plist (? 7f4bf3e7 - installed 2016-09-19)
[Loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2018-01-25)
[Other] com.efi.es1000service.plist (Electronics for Imaging - installed 2018-03-19)
[Loaded] com.adobe.SwitchBoard.plist (? 856489a3 - installed 2013-03-29)
[Loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-06-02)
[Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2010-08-25)
[Not Loaded] com.efi.packageversion.plist (? 0 - installed )
[Loaded] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installed 2016-12-13)
[Loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2016-05-05)
[Running] com.efi.ofasq.plist (EFI Inc - installed 2018-06-14)
[Running] fr.caldera.install_launcher.plist (? 1e934720 - installed 2018-02-05)
[Running] fr.caldera.calserver.plist (? 94ddddf3 - installed 2018-06-05)
[Running] com.aladdin.aksusbd.plist (SFNT Germany GmbH - installed 2017-07-03)
[Running] com.xrite.device.xrdd.plist (? 28f4ae75 - installed 2015-08-19)
[Running] com.efi.fieryd.plist (? f793c348 - installed 2017-07-07)
[Running] fr.caldera.bridge.plist (? 4d25651a - installed 2018-06-05)
[Running] com.efi.lmgr.plist (? 8d2637a0 - installed 2018-06-14)
[Running] fr.caldera.keyserver.plist (? 3326efee - installed 2018-02-05)
User Launch Agents:
[Loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2018-04-13)
[Loaded] com.adobe.ARM.***.plist (? 0 - installed 2014-05-08)
[Loaded] com.adobe.AAM.Updater-1.0.plist (? 0 - installed 2013-03-29)
User Login Items:
iTunesHelper Applicazione (Apple - installed 2018-05-30)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
PopChar Applicazione (? - installed 2013-06-21)
(/Applications/PopChar.app)
imac Cartella (?)
(/Users/***)
Dropbox Applicazione (Dropbox, Inc. - installed 2018-06-07)
(/Applications/Dropbox.app)
Internet Plug-ins:
AdobeExManDetect: AdobeExManDetect 1.1.0.0 (installed 2013-04-03)
FlashPlayer-10.6: 30.0.0.113 (installed 2018-06-07)
QuickTime Plugin: 7.7.3 (installed 2018-04-10)
Flash Player: 30.0.0.113 (installed 2018-06-07)
AdobeAAMDetect: AdobeAAMDetect 1.0.0.0 (installed 2012-08-09)
SharePointBrowserPlugin: 14.1.0 (installed 2013-06-20)
JavaAppletPlugin: Java 8 Update 121 build 13 (installed 2017-02-22)
3rd Party Preference Panes:
Flash Player (installed 2018-06-02)
Java (installed 2017-02-22)
MySQL (installed 2018-02-20)
Time Machine:
Time Machine Not Configured!
Top Processes by CPU:
Process (count) Source % of CPU Location
sandboxd Apple 12
WindowServer Apple 7
Mail Apple 5
kernel_task Apple 3
mds_stores Apple 3
Top Processes by Memory:
Process (count) Source RAM usage Location
kernel_task Apple 879 MB
com.apple.WebKit.WebContent (3) Apple 466 MB
mdworker (10) Apple 194 MB
Finder Apple 191 MB
Safari Apple 115 MB
Top Processes by Network Use:
Process Source Input Output Location
Dropbox Dropbox, Inc. 965 KB 681 KB
mDNSResponder Apple 1 MB 239 KB
netbiosd Apple 174 KB 24 KB
com.apple.WebKit.Networking Apple 60 KB 1 KB
apsd Apple 29 KB 24 KB
Top Processes by Energy Use:
Process (count) Source Energy (0-100) Location
WindowServer Apple 4
com.apple.WebKit.WebContent (3) Apple 3
Safari Apple 1
sandboxd Apple 1
cloudd Apple 1
Virtual Memory Information:
Available RAM 3.11 GB
Free RAM 18 MB
Used RAM 4.89 GB
Cached files 3.09 GB
Swap Used 26 MB
Software Installs (past 30 days):
Name Version Install Date
The Unarchiver 3.11.6 2018-05-28
iTunes 12.7.5 2018-05-30
Gatekeeper Configuration Data 140 2018-06-01
Adobe Flash Player 30.0.0.113 2018-06-07
Fiery Remote Scan 6.6.0.04 2018-06-14
ES1000 installer 5.0.0.41 2018-06-14
FieryMeasure 5.0.00.47 2018-06-14
Fiery XF 7.0.0.33 2018-06-14
hasp_driver 7.60.703.1 2018-06-14
FieryConfigure 4.0.0.10 2018-06-14
Image Enhance Visual Editor 2.2.0.00a 2018-06-14
Fiery Hot Folders 3.11.0.12 2018-06-14
HF3_filters 3.11.0.09 2018-06-14
versioning_installer 1.2.0.018 2018-06-14
Calibrator3 3.0.0.41 2018-06-14
ClientAPI 1.0.0.45a 2018-06-14
CustomViewer 1.0.0.05a 2018-06-14
EFILM 11.14.1.1.0 2018-06-14
EFI License Activation 1.5.1.2 2018-06-14
CWS Wrapper 6.2.0.14 2018-06-14
DeviceManager 6.2.00.28 2018-06-14
Harmony installer 3.5.049a 2018-06-14
Diagnostics Information (past 7 days):
2018-06-14 19:30:00 Adobe Photoshop CS6.app Crash
/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app
abort() called
2018-06-14 19:29:34 Dropbox.app Crash
2018-06-14 19:25:10 fierybidi Crash (14 times)
/Library/Printers/Xerox/PDEs/EF526740/fierybidi
2018-06-14 17:14:56 WindowServer CPU
/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
2018-06-14 08:33:51 mkfontscale Crash (3 times)
/opt/X11/*/mkfontscale
2018-06-11 12:59:01 Adobe Illustrator.app CPU (6 times)
/Applications/Adobe Illustrator CS6/Adobe Illustrator.app
2018-06-11 10:05:59 Adobe Acrobat Pro.app Crash
Performing @selector(doClick:) from sender UIT_NSTableView 0x125c65f0
End of report
