faxus ha scritto:Macbio, esegui un EtreCheck.
C'è da cancellare un file d'installazione.
Ma non mi ricordo quale.
EtreCheck lo evidenzia
EtreCheck version: 3.4.6 (460)
Report generated 2018-01-11 22:36:23
Download EtreCheck from
https://etrecheck.com" onclick="window.open(this.href);return false;
Runtime: 1:59
Performance: Excellent
Click the [Clean up] link to delete unused files.
Problem: Other problem
Hardware Information: ⓘ
iMac (Retina 5K, 27-inch, Late 2015)
iMac - model: iMac17,1
1 4 GHz Intel Core i7 (i7-6700K) CPU: 4-core
24 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 0/DIMM1
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 1/DIMM1
Handoff/Airdrop2: supported
Wireless: en1: Unknown
iCloud Quota: 3.59 GB available
Video Information: ⓘ
AMD Radeon R9 M395X - VRAM: 4 GB
iMac 5120 x 2880
Disk Information: ⓘ
APPLE SSD SM0512G disk0: (500,28 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 500.07 GB
USB Information: ⓘ
USB30Bus
VIA Labs, Inc. USB3.0 Hub
TOSHIBA External USB 3.0
External USB 3.0 disk2: (3 TB)
EFI (disk2s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
TimeMachine (disk2s2 - Journaled HFS+) /Volumes/TimeMachine : 3.00 TB (2.72 TB free)
Broadcom Corp. Bluetooth USB Host Controller
VIA Labs, Inc. USB2.0 Hub
WACOM CTE-640-U V4.0-3
Sony USB 2.0 MultiCard R/W
WinTV HVR-900
Firewire Information: ⓘ
LaCie d2 quadra (button) 800mbit - 800mbit max
(disk3s1) <not mounted> : 210 MB
xx LaCie_1T_RecoveryMovie (disk3s2 - Journaled HFS+) /Volumes/xx LaCie_1T_RecoveryMovie : 999.86 GB (770.17 GB free)
(disk5s1) <not mounted> [partition_map]: 32 KB
LaCie 1T_immagini (disk5s3 - Journaled HFS+) /Volumes/LaCie 1T_immagini : 1.00 TB (367.71 GB free)
WD My Book 800mbit - 800mbit max
EFI (disk4s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
MyBook (disk4s2 - Journaled HFS+) /Volumes/MyBook : 2.00 TB (987.47 GB free)
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Apple Inc. Thunderbolt to FireWire Adapter
Virtual disks: ⓘ
Macintosh HD (disk1s1 - APFS) / [Startup]: 500.07 GB (192.62 GB free)
Physical disk: disk0s2 500.07 GB (192.62 GB free)
(disk1s2) <not mounted> [Preboot]: 500.07 GB
(disk1s3) <not mounted> [Recovery]: 500.07 GB
(disk1s4) /private/var/vm [VM]: 500.07 GB
System Software: ⓘ
macOS High Sierra 10.13.2 (17C88) - Time since boot: less than an hour
Gatekeeper: ⓘ
Clean up: ⓘ
/Library/LaunchAgents/com.paragon-software.ntfs.automount.plist
/Library/PreferencePanes/ParagonNTFS.prefPane/Contents/Resources/NTFSAutomountAgent
Executable not found!
/Library/LaunchDaemons/com.easeus.dataprotectbackup.plist
~/Desktop/EaseUS Data Recovery Wizard.app/Contents/MacOS/EaseUS Data Recovery Wizard.app/Contents/Resources/EUDataDaemon.app/Contents/MacOS/eudataback
com.adobe.ARM.[...].plist
/Volumes/Macintosh HD 1T/Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater Helper.app/Contents/MacOS/Adobe Acrobat Updater Helper
3 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Applications/MOVIES/MacX Video Converter Pro.app
[not loaded] com.macxdvd.driver.goodSysAudioCapture (1.0 - SDK 10.10) [Lookup]
/Applications/MUSICA/Apowersoft Mac Audio Recorder/Apowersoft Mac Audio Recorder.app
[not loaded] com.Cycling74.driver.SAVD (1.0.0d1 - SDK 10.6) [Lookup]
/Applications/Rowmote Helper.app
[loaded] com.regularrateandrhythm.driver.RowmoteIREmu (1.2 - SDK 10.11) [Lookup]
/Applications/Toast 11 Titanium/Spin Doctor.app
[not loaded] com.hzsystems.terminus.driver (4) [Lookup]
/Applications/Toast 11 Titanium/Toast Titanium.app
[not loaded] com.roxio.BluRaySupport (1.1.6) [Lookup]
/Applications/iSkysoft_prova/Wondershare Filmora.app
[loaded] com.Perfect.Driver.SystemAudioRecorder (1.1.0 - SDK 10.6) [Lookup]
/Library/Application Support/HASP/kexts
[not loaded] com.aladdin.kext.aksfridge (1.0.16332) [Lookup]
/Library/Extensions
[loaded] com.sony.driver.dsccamDeviceInfo00 (1.3.0.07310 - SDK 10.7) [Lookup]
/System/Library/Extensions
[not loaded] com.LaCie.ScsiType00 (1.2.13 - SDK 10.5) [Lookup]
[not loaded] com.elgato.driver.DontMatchAfaTech (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergy450 (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergyXS (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchEmpia (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchVoyager (1.1) [Lookup]
[not loaded] com.hzsystems.driver.CDSDAudioCaptureSupport (1.5) [Lookup]
[not loaded] com.wacom.kext.pentablet (Pen Tablet 5.3.0-3 - SDK 10.
[Lookup]
[not loaded] net.telestream.driver.TelestreamAudio (1.1.0 - SDK 10.
[Lookup]
~/Library/Services/ToastIt.service/Contents/MacOS
[not loaded] com.roxio.TDIXController (2.0) [Lookup]
/Users/[redacted]/Apowersoft/Mac Online Launcher/Mac Online Launcher.app
[loaded] com.Apowersoft.driver.AudioDevice (1.6.7 - SDK 10.11) [Lookup]
[not loaded] com.Cycling74.driver.Soundflower (1.0.0 - SDK 10.
[Lookup]
Startup Items: ⓘ
ChmodBPF: Path: /Library/StartupItems/ChmodBPF
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[not loaded] 8 Apple tasks
[loaded] 176 Apple tasks
[running] 106 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 35 Apple tasks
[loaded] 192 Apple tasks
[running] 104 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-01-06) [Lookup]
[running] com.canon.MFManager.plist (? 8a8296d7 ec1bc3f3 - installed 2015-04-04) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-09-28) [Lookup]
[loaded] com.paragon-software.facebook.agent.plist (? 95fb0bd4 e9648c48 - installed 2017-01-22) [Lookup]
[failed] com.paragon-software.ntfs.automount.plist (? 23af1e7e 0 - installed 2016-11-29) [Lookup] - /Library/PreferencePanes/ParagonNTFS.prefPane/Contents/Resources/NTFSAutomountAgent: Executable not found!
[loaded] com.paragon.updater.plist (Paragon Software GmbH - installed 2017-01-22) [Lookup]
[running] com.sony.SonyAutoLauncher.agent.plist (? a756a1bd e59786f6 - installed 2015-03-15) [Lookup]
[not loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2016-06-17) [Lookup]
[not loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2016-05-02) [Lookup]
[running] com.wacom.pentablet.plist (? ? ? - installed 2012-10-29) [Lookup]
[loaded] com.xrite.device.softwareupdate.plist (X-Rite, Incorporated - installed 2018-01-02) [Lookup]
[loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2014-08-12) [Lookup]
Launch Daemons: ⓘ
[loaded] com.BlueStacks.AppPlayer.bstservice_helper.plist (BlueStack Systems, Inc. - installed 2016-11-20) [Lookup]
[running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2017-09-30) [Lookup]
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2017-12-15) [Lookup]
[running] com.aladdin.aksusbd.plist (? 882ffbab db34749b - installed 2018-01-11) [Lookup]
[running] com.aladdin.hasplmd.plist (? c5d97ee2 5b17585 - installed 2018-01-11) [Lookup]
[running] com.bombich.ccchelper.plist (Bombich Software, Inc. - installed 2017-02-20) [Lookup]
[failed] com.easeus.dataprotectbackup.plist (? 29faf71b 0 - installed 2017-03-04) [Lookup] - ~/Desktop/EaseUS Data Recovery Wizard.app/Contents/MacOS/EaseUS Data Recovery Wizard.app/Contents/Resources/EUDataDaemon.app/Contents/MacOS/eudataback: Executable not found!
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-10-13) [Lookup]
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-03-04) [Lookup]
[loaded] com.malwarebytes.MBAMHelperTool.plist (Malwarebytes Corporation - installed 2016-06-21) [Lookup]
[running] com.nalpeiron.netpro.plist (? caaeb67 637338d2 - installed 2015-01-12) [Lookup]
[loaded] com.paragon-software.installer.plist (Paragon Software GmbH - installed 2017-01-22) [Lookup]
[running] com.regularrateandrhythm.rowmotehelperaide.plist (Evan Schoenberg, M.D. - installed 2017-03-19) [Lookup]
[loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2016-05-02) [Lookup]
[not loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2016-06-17) [Lookup]
[running] com.xrite.device.xrdd.plist (X-Rite, Incorporated - installed 2017-11-28) [Lookup]
[loaded] com.xrite.hasp.drivers.plist (? e1f82b3d 906c775d - installed 2017-04-29) [Lookup]
[loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2014-08-12) [Lookup]
User Launch Agents: ⓘ
[loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2016-10-18) [Lookup]
[failed] com.adobe.ARM.[...].plist (? eb99ec05 0 - installed 2014-11-17) [Lookup] - /Volumes/Macintosh HD 1T/Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater Helper.app/Contents/MacOS/Adobe Acrobat Updater Helper: Executable not found!
[loaded] com.adobe.ARM.[...].plist (? 5c76f5f6 89ba1614 - installed 2015-10-15) [Lookup]
[running] com.spotify.webhelper.plist (Spotify - installed 2017-09-29) [Lookup]
User Login Items: ⓘ
EyeTV Helper Applicazione
(/Library/Application Support/EyeTV/EyeTV Helper.app)
Rowmote Helper Applicazione
(/Applications/Rowmote Helper.app)
com.coppertino.voxcloud SMLoginItem - Hidden (Coppertino Inc. - installed 2017-09-29)
(/Applications/VOX.app/Contents/Library/LoginItems/Loop.app)
VOXAgent SMLoginItem - Hidden (Coppertino Inc. - installed 2017-09-29)
(/Applications/VOX.app/Contents/Library/LoginItems/VOXAgent.app)
Internet Plug-ins: ⓘ
WacomNetscape: 2.1.0-1 (installed 2012-10-29) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-01-05)
AdobePDFViewerNPAPI: 10.1.16 (installed 2015-10-15) [Lookup]
AdobePDFViewer: 10.1.16 (installed 2015-10-15) [Lookup]
Flash Player: 28.0.0.137 (installed 2018-01-09) [Lookup]
EPPEX Plugin: 10.0 (installed 2013-09-26) [Lookup]
FlashPlayer-10.6: 28.0.0.137 (installed 2018-01-09) [Lookup]
PepperFlashPlayer: 28.0.0.137 (installed 2018-01-09) [Lookup]
Silverlight: 5.1.50901.0 (installed 2017-02-13) [Lookup]
WacomTabletPlugin: WacomTabletPlugin 2.1.0.2 (installed 2012-10-29) [Lookup]
JavaAppletPlugin: 15.0.1 (installed 2014-11-01) Check version
Safari Extensions: ⓘ
[enabled] Ghostery - GHOSTERY, Inc. -
https://www.ghostery.com/" onclick="window.open(this.href);return false; (installed 2017-06-27)
[enabled] Ixquick Toolbar - Ixquick.com -
http://www.ixquick.com" onclick="window.open(this.href);return false; (installed 2015-06-20)
[not loaded] Video Converter - Wondershare -
http://www.wondershare.com" onclick="window.open(this.href);return false; (installed 2014-09-26)
[not loaded] Pin It Button - Pinterest, Inc. -
http://www.pinterest.com/" onclick="window.open(this.href);return false; (installed 2016-01-30)
[not loaded] Adblock Plus - Eyeo GmbH -
https://adblockplus.org/" onclick="window.open(this.href);return false; (installed 2016-06-29)
[not loaded] Ixquick HTTPS - Surfboard B.V. -
https://ixquick.com" onclick="window.open(this.href);return false; (installed 2016-06-24)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-12-15) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 500.07 GB Disk used: 307.45 GB
Destinations:
TimeMachine [Local]
Total size: 3.00 TB
Total number of backups: 10
Oldest backup: 10/01/18, 07:42
Last backup: 11/01/18, 21:42
Size of backup disk: Excellent
Backup size 3.00 TB > (Disk size 500.07 GB X 3)
Top Processes by CPU: ⓘ
5% WindowServer
4% Safari
3% com.apple.WebKit.WebContent
2% kernel_task
1% launchd
Top Processes by Memory: ⓘ
1.43 GB kernel_task
304 MB mds_stores
251 MB PenTabletDriver
216 MB com.apple.WebKit.WebContent
212 MB WindowServer
Input Output Process name
1 MB 90 KB com.apple.WebKit.Networking
67 KB 60 KB mDNSResponder
15 KB 3 KB cloudd
5 KB 7 KB apsd
8 KB 1 KB com.apple.Safari.SafeBrowsing.Service
8.38 xrdd
6.18 WindowServer
2.58 com.apple.WebKit.WebContent
1.90 Safari
Virtual Memory Information: ⓘ
19.17 GB Available RAM
16.41 GB Free RAM
4.83 GB Used RAM
2.75 GB Cached files
0 B Swap Used
Adobe Pepper Flash Player: (installed 2017-12-13)
Blackmagic DaVinci Resolve: 14.2 (installed 2018-01-01)
i1Profiler: (installed 2018-01-02)
TomTom HOME: (installed 2018-01-02)
MyDrive Connect: (installed 2018-01-02)
Adobe Flash Player: (installed 2018-01-09)
Adobe Pepper Flash Player: (installed 2018-01-09)
2018-01-11 00:09:07 com.apple.WebKit.Plugin.32 High CPU use [Open] [Details]
2018-01-08 23:11:55 hasplmd Crash [Open]
Cause: dyld: launch, loading dependent libraries
grazie e buon divertimento!!!
