help tor
zagormario
scusate ragazzi se sto postando a go go..da quando ho reinstallato el capitan, tor non ha mai funzionato al 100% fino ad oggi che non si avvia proprio piu, vi posto il log:
13/09/16, 14:50:40.800 [NOTICE] Bootstrapped 5%: Connecting to directory server
13/09/16, 14:50:40.800 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
13/09/16, 14:50:41.300 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
13/09/16, 14:50:41.300 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
13/09/16, 14:50:41.400 [NOTICE] Bootstrapped 25%: Loading networkstatus consensus
13/09/16, 14:50:43.800 [WARN] Our clock is 14 hours, 9 minutes behind the time published in the consensus network status document (2016-09-14 12:00:00 UTC). Tor needs an accurate clock to work correctly. Please check your time and date settings!
13/09/16, 14:50:43.800 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no recent usable consensus.
13/09/16, 14:50:57.500 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:9150
13/09/16, 14:50:57.500 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/09/16, 14:50:57.500 [NOTICE] Closing old Socks listener on 127.0.0.1:9150
13/09/16, 14:50:58.300 [NOTICE] Delaying directory fetches: DisableNetwork is set.
13/09/16, 14:51:23.200 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/09/16, 14:51:23.200 [NOTICE] Opening Socks listener on 127.0.0.1:9150
13/09/16, 15:01:21.000 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:9150
13/09/16, 15:01:21.000 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/09/16, 15:01:21.000 [NOTICE] Closing old Socks listener on 127.0.0.1:9150
13/09/16, 15:01:21.300 [NOTICE] Delaying directory fetches: DisableNetwork is set.
13/09/16, 15:01:44.300 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/09/16, 15:01:44.300 [NOTICE] Opening Socks listener on 127.0.0.1:9150
13/09/16, 15:02:18.200 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:9150
13/09/16, 15:02:18.200 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/09/16, 15:02:18.200 [NOTICE] Closing old Socks listener on 127.0.0.1:9150
io non ci capisco nulla, posso solo dirvi che non ho toccato nessuna impostazione, quindi non capisco proprio il motivo di questo malfunzionamento
Posso fare a meno di tutto tranne del mio Mac......
Hai configurato Tor o usi TorBrowser?
Sembrerebbe, anche da riscontri sul web, che usi una connessione con l'ISP che sonda i pacchetti.
Se la tua versione non è perfettamente aggiornata potresti non avere i pluggabletransports.
Probabile siano bloccate alcuni bridges di default
https://www.torproject.org/docs/bridges.html.en" onclick="window.open(this.href);return false;
zagormario
ho canchellato il wi fi da 'network' poi lo reinstallato, ho cancellato tor, l'ho reinstallato e ora va tutto bene... non so cosa sia successo, pero l'importante che abbia risolto, anche perche tor lo uso abbastanza spesso,quindi sarebbe stato un bel guaio, ma si è risolto tutto, grazie cmq :wink:
utente eliminato
Oggetto del messaggio: Re: help tor
Messaggio da utente eliminato »
Uno dei problemi piú grandi di questo mondo é proprio Tor.
Dovrebbe sparire, o meglio essere risucchiato da un buco nero.
xChApPiR ha scritto:Uno dei problemi piú grandi di questo mondo é proprio Tor...
Forse non hai idea dell'unità di misura dei problemi...
Io credo che un problema abbastanza rilevante di questo mondo sia il fatto che qualcuno sia costretto ad usarlo
utente eliminato
In quel senso non ci sta problema.
Io non sono costretto da nessuno.
L'ultima volta che ho provato ad us are Tor, andando su Google, mi hanno disintegrato un Acer Aspire.
Avevo dimenticato di attivare I firewall.
xChApPiR ha scritto:... mi hanno disintegrato un Acer Aspire...
Hanno fatto bene...
zagormario
io uso un firewall, hands off, e mi trovo molto bene, riguardo Tor basta usarlo con attenzione, alla fine è un browser come un altro
utente eliminato
Hanno fatto bene...
Se lo dici tu, intanto è ripartito, per fortuna non hanno mangiato il mio hard disk.
Lo avevo scaricato solo per curiosità, meglio Mozilla.
xChApPiR ha scritto:... intanto è ripartito, per fortuna ...
Acc...
Gli Acer sono buoni solo per fare hackintosh
xChApPiR ha scritto:... per fortuna non hanno mangiato il mio hard disk...
Gli zombi mangiano solo carne fresca.
Se fossero stati vegani avresti rischiato...
xChApPiR ha scritto:... Lo avevo scaricato solo per curiosità, meglio Mozilla.
Dipende.
Disossare e cucinare Firefox con contorno di cipolla è un'arte per evoluti ed esperti.
C'è chi non capisce la differenza tra rendersi invisibile e nascondere la testa nella sabbia.
Tipico di tutti gli struzzi (scusate, non funziona il tasto n).
C'è molta gente che pensa di essere brava perché non è mai stata scoperta.
Ma non considera che semplicemente a nessuno interessa quali ragazzate fa.
Per tutti gli altri è meglio TorBrowser.
Almeno è sicuro al 95%, che è un ottimo risultato.
Per farci cosa è un altro paio di maniche...
xChApPiR ha scritto: ....... L'ultima volta che ho provato ad us are Tor, andando su Google, mi hanno disintegrato un Acer Aspire.
Ci puoi spiegare esattamente come hanno fatto a danneggiare il tuo Acer?
E soprattutto perchè ti hanno preso di mira?
In qualche modo li avevi provocati?
Kernel Panic ha scritto:... Ci puoi spiegare esattamente come hanno fatto a danneggiare il tuo Acer?...
Lo hanno sputazzato
Solo all'Acer?
kext
Acc...
Come dicesti tu, molto meglio gli Asus..
MacAlbe
@Chappy
Ma capitano tutte a te??
Uso Tor ogni tanto, mai avuto problemi e mai andato a cercarmeli.
Non ti preoccupare..... Al massimo muoio!!!
