Safari Autorefresh
Scialla ha scritto:La combo update non lo reinstalla
Ho detto una cavolata, la reinstalla
Che strano però, mi mantiene i preferiti.. boh
In ogni caso non risolve il problema che si ripresenta
Devo provare a spulciare il log...
funziona solo se, prima di tornare alla pagina precedente, svuoto la cache... ogni volta
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/02EB6B7B-AB51-481B-ACDE-CF03889B8CE7 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/1A798305-57F5-41FB-A19F-5887ACBE80DE failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/26EE0B18-3E82-4917-A99F-8290B656E635 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/2E8AFFDA-C942-4DEC-A897-B6D4D29CDBD9 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/42E2A306-C50F-4321-85A3-88C50988ACC7 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/5A9B7867-9F21-4259-A117-C379CEEFC3E2 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/615FF6D9-60B3-4DF1-81FF-ED0160DFFFA9 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/6229A667-1535-4CE6-8DCC-C155589BDAE2 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/67E1597A-0CFF-40D3-9773-FAAB5E2E7310 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/7CE2F5E9-CF5E-49C3-A4E0-1F4F7D05DBC5 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/8665BD41-22DC-40E1-850A-DA5262707438 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/8C520120-8B1A-474A-A8D5-31A7D4BC4592 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/8FDEDD00-1057-46AC-8407-DD0AF8682877 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/AB5B6622-5045-4240-8779-F72FD5A70F27 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/C0816D84-6AAD-456D-A0DF-83CA2D90E799 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/C7514505-7302-45C1-9D0B-4F82BE56EF84 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/D8DE857E-32A5-4EC3-A138-77FC7E8550DE failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/D93F0008-CA19-46ED-9B6F-AFE2AB927101 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/D94EB058-E3AB-4F24-A09E-9A8D1CBD683E failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/F2F26C61-2ED4-4E33-B1F3-0076E4ADF914 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/F68BCD3D-04C8-4340-82B7-5233F7975738 failed. Errno=2
Oct 9 22:08:46 iMacScialla.local Safari[508]: unlink of file /Users/scialla/Library/Caches/com.apple.Safari/fsCachedData/F7409F4E-BECD-433D-8624-C891B7D50A30 failed. Errno=2
Oct 9 22:09:04 iMacScialla com.apple.launchd[1] (com.apple.WebKit.WebContent.B1031FDD-F53B-411F-8D49-4B757FCF76A1[549]): Could not terminate job: 3: No such process
Oct 9 22:09:04 iMacScialla com.apple.launchd[1] (com.apple.WebKit.WebContent.B1031FDD-F53B-411F-8D49-4B757FCF76A1[549]): Using fallback option to terminate job...
Oct 9 22:09:04 iMacScialla com.apple.launchd[1] (com.apple.WebKit.Networking.198429F7-90B1-47D2-AB5B-CF39CC4F77EF[511]): Exited with code: 1
Oct 9 22:09:07 iMacScialla.local com.apple.IconServicesAgent[248]: main Failed to composit image for binding VariantBinding [0x17f] flags: 0x8 binding: FileInfoBinding [0x603] - extension: png, UTI: public.png, fileType: ????.
Oct 9 22:09:07 iMacScialla.local quicklookd[554]: Warning: Cache image returned by the server has size range covering all valid image sizes. Binding: VariantBinding [0x403] flags: 0x8 binding: FileInfoBinding [0x303] - extension: png, UTI: public.png, fileType: ???? request size:16 scale: 1
Oct 9 22:09:07 iMacScialla.local com.apple.IconServicesAgent[248]: main Failed to composit image for binding VariantBinding [0x4cd] flags: 0x8 binding: FileInfoBinding [0x5cb] - extension: jpg, UTI: public.jpeg, fileType: ????.
Oct 9 22:09:07 iMacScialla.local quicklookd[554]: Warning: Cache image returned by the server has size range covering all valid image sizes. Binding: VariantBinding [0x603] flags: 0x8 binding: FileInfoBinding [0x503] - extension: jpg, UTI: public.jpeg, fileType: ???? request size:128 scale: 1
Oct 9 22:09:07 iMacScialla.local com.apple.IconServicesAgent[248]: main Failed to composit image for binding VariantBinding [0xabf] flags: 0x8 binding: FileInfoBinding [0x7c5] - extension: tga, UTI: com.truevision.tga-image, fileType: TPIC.
Oct 9 22:09:07 iMacScialla.local quicklookd[554]: Warning: Cache image returned by the server has size range covering all valid image sizes. Binding: VariantBinding [0x803] flags: 0x8 binding: FileInfoBinding [0x703] - extension: tga, UTI: com.truevision.tga-image, fileType: TPIC request size:16 scale: 1
Oct 9 22:09:07 iMacScialla.local com.apple.SecurityServer[14]: Session 100021 created
Oct 9 22:09:09 iMacScialla.local com.apple.SecurityServer[14]: Killing auth hosts
Oct 9 22:09:09 iMacScialla.local com.apple.SecurityServer[14]: Session 100020 destroyed
Oct 9 22:09:18 iMacScialla.local sandboxd[137] ([560]): com.apple.WebKit(560) deny file-read-data /Library/Preferences/com.apple.security-common.plist
Da un sacco di errori sulla cache...
Terminale
defaults read -app Safari WebKitDNSPrefetchingEnabled
Esegue o non lo trova?
Chiedi le info sui permessi di ~/Library/Preferences/com.apple.Safari.plist
Mi puzza tanto di un errore o corruzione delle librerie webkit.
Sarebbe bene reinstallare.
Oppure tienitelo, Yosemite è alle porte
faxus ha scritto:Terminale
Stasera, oppure nel pomeriggio, eseguo...l
faxus ha scritto:Mi puzza tanto di un errore o corruzione delle librerie webkit.
Opto per la seconda, sempre che con un aggiornamento si risolva; mi dispiacerebbe reinstallare da zero, mi porto dietro il sistema da Tiger...
kato
Scialla ha scritto:mi porto dietro il sistema da Tiger...
Ormai è uno di famiglia.
Scialla ha scritto:... mi dispiacerebbe reinstallare da zero, mi porto dietro il sistema da Tiger...
Solo da Snow Leopard.
È il mio dramma esistenziale.
Qualcuno conosce una sibilla?
Forse farò a testa o croce...
Aggiornato, il bug resta.. :(
Da zero non reinstallo, troppi caxxi da rimettere.
Già solo pensare di reinserire tutte le regole di LS mi fa desistere
kato
Scialla ha scritto:Già solo pensare di reinserire tutte le regole di LS mi fa desistere
Ma quelle non si possono esportare e reimportare? Ora non posso verificare.
Era per dirne una... non é neanche più compatibile la versione che ho installata
Uffa, devo cominciare a sistemare un po di cose, infatti sono l'1:30 e sono ancora qui :(
Neanche Safari 8.0.2 risolve.... che due balls
Neanche con El Capitan si è risolta la cosa....
Visitano il forum: Google [Bot], Yandex [Bot] e 5 ospiti
