Aggiornamento Pacifist
Phate
Grazie :thumbright:
Grande programma
:D
Nas DiskStation DS1513+
Apc Smart-Ups 1000Va Lcd 230V
canale y o u t u b e
j u z a photo
[/i]
pierecall
fragrua ha scritto:Immagine
Rilasciato Pacifist 3.0.6 che corregge solo un bug.
Fixed a bug that could cause loading distribution packages from non-file URLs not to work
http://www.charlessoft.com/" onclick="window.open(this.href);return false;
grazie franz :wink:
Pregate, pregate…
:D
Pacifist - 3.0.7
Fixed a bug that could cause Pacifist not to launch on Intel Macs running OS X 10.4.x
Pacifist - 3.0.8
Added support for OS X 10.8 Mountain Lion installer to "Open Apple Installers" button
Fixed a bug that could cause the "Show Software Update Packages" feature not to work on OS X 10.8 Mountain Lion.
Phate
Grazie Kernel
:D
j u z a photo
[/i]
Pacifist - 3.0.9
Fixed a crashing bug
Fixed a bug that could cause some items to be installed in the wrong place
Fixed a bug that caused the disclosure triangles not to work in the QuickLook plug-in on OS X 10.8 Mountain Lion
Other minor bug fixes.
Phate
Phate ha scritto:Grazie :thumbright:
Grande programma
:D
j u z a photo
[/i]
Pacifist - 3.0.10
Fixed a few crashing bugs
Fixed a few minor bugs that could cause some packages not to load properly
Fixed a bug that could cause RTFD files not to be viewable
http://www.charlessoft.com" onclick="window.open(this.href);return false;
Pacifist - 3.2
Compatibility with OS X 10.9 Mavericks and its packages
Updated graphics for Retina Display
Converted to Objective-C ARC for greater efficiency and reliability
Rewrite the helper tool code for greater security
Made better use of concurrency for greatly improved performance
Now uses Notification Center on Mac OS X 10.8 and higher
Added support for Zip archives using Method 1 (Shrink) and Method 6 (Implode)
Fixed a bug which could cause errors on loading some packages
Fixed a rare crash which could occur while extracting files from some archives
Fixed a bug which could cause some spurious buttons to appear when using VoiceOver
Fixed a bug which could cause certain packages to fail to load
Improved performance when installing a large number of files
Fixed a bug which caused the Finder not to automatically reveal extracted files
Other miscellaneous bug fixes.
Pacifist - 3.2.2
Fixed a bug in 3.2 that caused spurious "The update is improperly signed" errors on auto-update
Fixed a bug that could cause files not to be extracted from certain packages
Fixed a bug that could cause incorrect installations with administrator privileges checked, when a package contained a relative URL
Fixed a bug that caused the "Install" button to be greyed out when viewing DMG files containing .pkg packages.
Rilasciato per il download Pacifist 3.2.3
• Enabled full-screen mode on OS X 10.7 or later
• File viewer windows can now be closed via the space bar
• Fixed a bug that caused the splash screen to be drawn incorrectly on machines with Intel Iris graphics
• Fixed a crashing bug that could occur when trying to load an invalid .bom file
• Pacifist should hopefully not cause the discrete GPU to be switched on anymore in MacBook Pros with dual GPUs
Link diretto:
http://www.charlessoft.com/pacifist_dow ... _3.2.3.zip" onclick="window.open(this.href);return false;
Schermata 2013-12-10 alle 05.41.40.png (99.11 KiB) Visto 1540 volte
Schermata 2013-12-10 alle 05.40.36.png (57.66 KiB) Visto 1540 volte
Rilasciato per il download Pacifist 3.2.4
Enabled full-screen mode for a few more windows in the UI
Removed the URL from the Help Book so that Help Viewer should no longer access the Internet
Fixed a cosmetic issue involving the main window in the French and German localizations
Link diretto:
http://www.charlessoft.com/pacifist_dow ... _3.2.4.zip" onclick="window.open(this.href);return false;
Visitano il forum: Yandex [Bot] e 8 ospiti
