- Software Expert Gold
Vivaldi - 2.6.1566.40
What's New in Vivaldi:
New:
• Add support for blocking ‘abusive’ Ads
Accessibility:
• Allow to open "Find in Page" result with keyboard via Ctrl+Enter if it is a link
Profiles:
• Update the avatars
• Add support for adding and deleting in the popup
• Allow editing of avatar within the popup
Panels:
• Add unread tab counter to the Window panel
Razer Chroma:
• Add support for headset devices
Settings:
• Search Field - show favicon for active engine
• Provide a way to filter saved passwords
• Show context menu on double click
UI:
• Update images for error pages
Address Bar:
• Delete button in dropdown broken on bookmarks
• Drag & drop text, pressing Enter empties the address bar
• Deleting bookmark folders from the URL bar doesn’t work
• Should support drag-and-drop editing
• Typed History saving full URL instead of search nickname + term combination
• Undo does not work correctly
• Return all nickname results, from first entered character
Bookmarks:
• Imported bookmarks lack folder name
• Internal page can not be added to bookmark folder from bookmark bar
Extensions:
• "Allow in Incognito" makes the extension icon appear at the end
History:
• Ctrl+A and Del deletes whole day
Image inspector:
• Long exposure is displayed incorrectly
Keyboard:
• Blacklist system reserved shortcuts
• Esc can close both Find-in-Page and Quick Commands
• Tab (key) focus cycling gets stuck halfway on some websites
• Dev Tools - Ctrl+Shift+J should launch the console
• Extensions - shortcuts don’t work
• ⌘N does not simply open a new window when all windows are minimized
Linux:
• Add support for chromium-codecs-ffmpeg-extra 74, 75 and 76
Panels:
• Wrongly displayed decimal separator in Downloads
• Last used Web Panel loads on startup even if the side panel is collapsed
• Performance - Make the sidebar toggle animation smoother
Profiles:
• Add separator between icon and extensions
Quick Commands:
• Tab key should autocomplete
• Settings - Add setting to turn off calculator
Regression:
• Browser crashes when I close a tab
Screenshots:
• PNGs have an unnecessary alpha channel
Search Field:
• Typed history dropdown sometimes lacks keyboard focus
• Suggestions are cropped in popup window
Settings:
• Changes to domain expansion suffix not saved
• Unable to see complete password
• Misaligned Select Folder button
• Turn off "Always display navigation" by default
• Search - Too little space for nickname in Japanese UI
Speed Dial:
• Improve animation performance
• Multiple Speed Dial buttons can be active
Sync:
• Speed Dial - do not synchronize the columns and width
• Report to the user when sync initialization is stuck because of server issues
Tabs:
• Popup thumbnails are not displayed in Private/Guest mode
• Resize early when closing tabs with middle mouse button shortcut
• Minimize Pinned Tab option doesn't work if Minimize Tabs is disabled
• Moving UI button over tab activates it
• Releasing middle mouse button on a tab closes it, even when the actual click was somewhere else
• Crash on moving tabs between windows: particularly PDFs
• Occasional crash on closing tabs
• Performance - animation performance improvements
• Regressions:
◦ Tab Bar disappears and cannot be restored until restart of the browser
◦ Opening link in background tab does not trigger download save popup
◦ Vivaldi slows down when tiling or moving tabs
Tiling:
• Resize of tiled tabs is blocked if mouse moved too fast
Themes:
• Wrong format color crashes color picker
• Editor color picker misaligned
Touch:
• Long touch both opens context menu and executes default action
UI zoom:
• 60% causes minimize window button to disappear
UI:
• Clicks on modal dialogs can fail
• Notification permission dialog does not overlap icon in address field
General:
• Upgraded to Chromium 75.0.3770.94
>>> https://vivaldi.com
Vivaldi - 2.6.1566.44
• [Regression][Developer Tools] Changing theme causes crash (VB-48004)
• [Regression][Notifications] Chrome icon shown (VB-53887)
• [Regression][Profiles] Missing credits for avatar illustrations (VB-54603)
• [Regression][Quick Commands] Right arrow defunct after paste (VB-54665)
• [Speed Dial] Create a default SD for Vivaldi Web Mail (VB-54036)
• Updated translations
• Upgraded Chromium to 75.0.3770.102
>>> https://vivaldi.com
Vivaldi - 2.6.1566.49
• Upgraded Chromium to 75.0.3770.145
• Updated Translations
>>> https://vivaldi.com
Vivaldi - 2.7.1628.33
What's new in Vivaldi
Version 2.7.1628.33:
[Regression] Window panel goes blank when changing the sorting order
[Regression][Hang] After using find-in-page on a page tiled/lined with PDF
[Regression][Hang] During find-in-page
[Regression][Crash] When closing tabs with PDF in iframe
[Crash] When closing window
[Crash] Closing popup window when downloads are active
Session manager breaks after 20 sessions
Upgraded Chromium to 76.0.3809.137
>>> https://vivaldi.com
Vivaldi - 2.8.1664.35
Version 2.8.1664.35:
New - Bookmarks:
Add keyboard navigation to bookmark menu bar
Manager columns width should be resizable
Add support for hovering across horizontal menu or the bookmarks bar
New - Keyboard:
Toggle images via keyboard: Ctrl+Alt+Shift+I / ⌥⌘I
Address bar:
Can not remove items from the typed history
Colon and a space in a search string would trigger navigation
Dot and a space in a search string would trigger navigation
Field contents not aligned
Pressing Esc doesn't select the original URL
Searching for http(s) was not possible
Del on drop down not working reliably
Names inbyte characters don't get autocompleted
Bookmarks:
Can't tell folders and bookmarks apart when bar is set to "text only"
Cannot create bookmark with Enter key
Custom folder images set in Speed Dial are not visible in panel and manager
Editor doesn't update when data changes externally
Freeze on creating bookmark with invalid URL
The spacing on the bar is too wide
Crash:
Ticking 'Block ads on abusive sites' with private window open crashes
History:
Bad header highlight when holding mouse button on Date column
The number of selected files are not shown with select "All" option
View search field not focused
IME:
Pressing Space and Delete evokes autocomplete
Keyboard:
Shift + F3 + hold Cycle broken
macOS:
⌥Clicking window does not minimize all windows
Reduce spacing in bookmark bar context menu
Fullscreen - Top part gets hidden by showing menu in Native Window mode
IME - Pressing Delete after a space selects the whole text
Quick Commands - Nothing happens when you try to quit
Reader:
Often removes author and date
Sounds:
Manually muted tab becomes unmuted when it becomes active
Spatial Navigation:
Use Shift+Arrows with the Chromium/Blink implementation
Speed Dial:
New default bookmarks replace user defined folder
Sync - Notes:
Duplication: To benefit from the change, all synced clients must include this fix
User Profiles:
Chromium logo in the management dialog
Warn when deleting active profile
Welcome page:
Sync subpage in Private window stuck at "Getting current status…"
Zoom:
Page zoom rate doesn't always follow your default setting
Controls inactive after tab reloads
Other:
Prevent restart loop if UI dies quickly
Simpler UI for crash recovery
Upgraded Chromium to 77.0.3865.78
>>> https://vivaldi.com
Vivaldi - 2.8.1664.44
Version 2.8.1664.44:
Upgraded Chromium to 77.0.3865.121
>>> https://vivaldi.com
Vivaldi - 2.10.1745.21
No "strings" attached: Better site compatibility with User Agent changes:
Being a Chromium-based browser, Vivaldi should work on any website that works on Chrome. Yet, we have faced the issue of "incompatible websites" far too often
This is because many websites that work perfectly in Vivaldi, actively block us when we "announce" our true name. Vivaldi is often blocked by competitors, rivals and tech companies in positions of power. Blocking browsers has no technical merit in 2019, nor has it ever had
Our users regularly encounter messages that they have to upgrade their browser or the site will not work. Although we have made workarounds for a few of these issues, this is happening on too many sites and some are hard to fix
From this update onwards, you’ll be able to browse smoothly all those websites that claim to be incompatible with Vivaldi. This is because we’ve changed Vivaldi’s user agent string. Basically, the word ‘Vivaldi’ is being dropped from the user agent string
For the uninitiated, a browser sends its "user agent" to every website you connect to. A user agent is a string - that is, a line of text - identifying the browser to the web server, including the version number and operating system
Over time, the browser "user agent" system has been abused with the practice of "browser sniffing" and a lot of ink has already been spilled on the reasons why the user agent string should not be used for such bad practices. In short, instead of making the Web accessible to everyone, regardless of which browser or device they are using, this has worked the opposite way
The primary reason to show Vivaldi in the user agent is a level of pride. That pride, however, is hurting us, as our competitors and others are using this to block us from their services. That is why with today’s update, we’ve drawn a line in the sand so that you can browse more websites without a glitch
Colour-coordinated: Match your themes with your operating system:
Vivaldi already allowed you to schedule the ultra-customizable Vivaldi themes to change at your preferred time(s) - a unique feature that gives your browser a look that’s exclusively yours
Now you’ll find a new quirky option so that Vivaldi can work in concert with the themes of your operating system - to match light or dark theme (the latter being all the rage these days). Vivaldi can now follow the theme of your OS too
To match the themes according to your OS, go to Settings → Themes → Scheduled Themes → Use Operating System Theme. You may pick any pre-installed or custom theme to be used in light and dark mode
Or you can always set up your own time schedule, regardless of OS, using as many themes you want
Other Improvements:
Our focus on improving your overall browsing experience is an integral process of building Vivaldi.
Here’s more on the offer:
Improvements in the Address Bar layout along with some tweaks in keyboard handling
If you are a heavy user of Extensions in Vivaldi, there have been improvements in the toggle to show or hide hidden extensions
Significant performance improvements to Quick Commands
New:
User Agent: Only set Vivaldi/Version for duckduckgo.com, ecosia.org|com, qwant.com, startpage.com and vivaldi.com|net
Themes - Settings: Add a theme scheduling option to follow operating system light/dark theme
Quick Commands: Keep text in input field if command not executed: Settings → Quick Commands → Keep Last Entered Value
Keyboard - Bookmarks: Support for focusing the bookmark bar: can be mapped as a shortcut
Extensions: Horizontal extension-popup instead of vertical extension-popup
Accessibility:
Focus does not go to password popup
Address Bar:
Context menu is delayed on right click with lots of notes
Hidden bottom address bar is on top (when focused)
Hostname with an appended slash is not recognized as URL
Nickname search requires two spaces to show nicknamed icon
Progress bar goes from right to left when adding content to existing page
URL is not focused when "Settings → Tabs → New Tab page → Specific Page" is set
Unsafe script references in the blocked content dialog are misleading
Mac: Right-click selects text in Vivaldi
Regression: Focus not in the address bar in private windows
Regression: Should support drag-and-drop editing
Audio: It is impossible to unmute an inactive tab playing a video (music on YouTube)
Bookmarks:
No "Date added" column/ "Sort by Date Added": it can be toggled from title row context menu
Panel toolbar displays ‘needs upgrade’
Tree sorting button tab stops should follow Full Key Access
Dev Tools:
Audit is broken
Undocked dev tools should have the URL of the inspected page in the title bar
History:
Manager says 0:00:00 in List and Day Views when OS language is Japanese
Week number in manager should be locale aware
Bookmarks: Sorting arrows are the opposite of what they should be
Regression: Popup buttons move to left after hitting Delete
Keyboard:
Accessibility - Panels: Allow use of use arrow keys to navigate the buttons on the toolbar
Notes:
Themes: "Go to address" button has incorrect colors in dark theme
Popup: Title bar is blurred
Quick Commands:
Enabling both "Keep last entered value" and "open on nickname match" makes QC otherwise unusable
History search can be very slow
Text is kept after a command is executed
Settings:
Gesture mapping column can collapse
Search: It is not obvious how to save the default
Speed Dial:
No immediate feedback after a link is clicked
The border of the highlighted thumbnail is cut off when using rounded corners
Unable to open an entry in a new private window using the context menu
Sync - Regression: Loss of user-defined thumbnails
Sync:
Settings: Sync button does not go to the sync section if settings is closed
Tabs:
Add "Alt-click to reopen last closed tab" tooltip to Trash button: middle click also works
Unable to clone multiple selected tabs
Regression: Can’t close tab stack from the windows panel, not with the button, nor the right-click menu.
Themes:
Scheduled themes UI selection issue
macOS:
Too many window-tiling options displayed in window menu under Catalina
Others:
Sound:
Permissions to allow microphone access aren’t being saved
Reopening tab results in incorrect muting
"Ask" is invisible in the sound permission popup
Start page: Focus stolen from before unload dialog opener
Crash Crash on startup with old prefs/profile
Regression: Changing UI zoom while having undocked dev tools for UI open causes crash
Hang opening a background tab from a pinned tab when action would create a Tab Stack
Popup window doesn’t close by window.close
Tab thumbnail doesn’t get updated until you visit/open/close another tab
Tabs don’t get detached when dropped inside the window
getDisplayMedia doesn’t work
Panels: Floating panel + tabs positioned on the left side causes issues
Other:
A new tab opened from with "no images" set should inherit "no images"
Long file names make save dialog unreadable
No warning before closing a window if exit confirm is off
Upgraded Chromium to 79.0.3945.94
>>> https://vivaldi.com
Visitano il forum: Bing [Bot] e 7 ospiti
