diskutil list
diskutil cs list
diskutil info disk5
iMac-di-Claudio:~ Claudio-LP$ diskutil list
/dev/disk0
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *1.0 TB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_CoreStorage 999.3 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
/dev/disk1
0: Apple_HFS Macintosh HD *999.0 GB disk1
Logical Volume on disk0s2
4CD7A75E-D963-4C30-BC6A-38B1971EF879
Unencrypted
/dev/disk2
0: Apple_partition_scheme *90.2 MB disk2
1: Apple_partition_map 32.3 KB disk2s1
2: Apple_HFS DriveGenius_5.0.2 [sn] 90.1 MB disk2s2
/dev/disk3
0: GUID_partition_scheme *21.0 MB disk3
1: Apple_HFS Installer 20.9 MB disk3s1
/dev/disk4
0: GUID_partition_scheme *250.1 GB disk4
1: EFI EFI 209.7 MB disk4s1
2: Apple_CoreStorage 249.2 GB disk4s2
3: Apple_Boot Recovery HD 650.0 MB disk4s3
/dev/disk5
0: Apple_HFS Macintosh HD *248.8 GB disk5
Logical Volume on disk4s2
A35BB0F1-BCED-438A-BECE-91E99158AB82
Unlocked Encrypted
/dev/disk6
0: Data Rescue 4 *28.4 MB disk6
/dev/disk7
0: Data Rescue 4 *29.8 MB disk7
/dev/disk8
0: GUID_partition_scheme *2.1 GB disk8
1: Apple_HFS DW 67.6 MB disk8s1
2: Apple_HFS DiskWarrior Recovery 1.8 GB disk8s2
iMac-di-Claudio:~ Claudio-LP$ diskutil info -plist disk5
diskutil repairDisk<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Bootable</key>
<false/>
<key>BusProtocol</key>
<string>USB</string>
<key>CanBeMadeBootable</key>
<false/>
<key>CanBeMadeBootableRequiresDestroy</key>
<false/>
<key>Content</key>
<string>Apple_HFS</string>
<key>CoreStorageCompositeDisk</key>
<false/>
<key>CoreStorageEncrypted</key>
<true/>
<key>CoreStorageLVFUUID</key>
<string>2AE64C42-4713-4C51-A150-BB86FD11D1CC</string>
<key>CoreStorageLVGUUID</key>
<string>CA6691F3-8037-4D9A-BB0F-FADB4EB53629</string>
<key>CoreStorageLVUUID</key>
<string>A35BB0F1-BCED-438A-BECE-91E99158AB82</string>
<key>DeviceBlockSize</key>
<integer>512</integer>
<key>DeviceIdentifier</key>
<string>disk5</string>
<key>DeviceNode</key>
<string>/dev/disk5</string>
<key>DeviceTreePath</key>
<string>IODeviceTree:/PCI0@0/XHC1@14</string>
<key>DiskUUID</key>
<key>Ejectable</key>
<true/>
<key>FilesystemName</key>
<string>HFS+</string>
<key>FilesystemType</key>
<string>hfs</string>
<key>FilesystemUserVisibleName</key>
<string>Mac OS Extended</string>
<key>FreeSpace</key>
<integer>0</integer>
<key>GlobalPermissionsEnabled</key>
<false/>
<key>IOKitSize</key>
<integer>248828264448</integer>
<key>Internal</key>
<false/>
<key>LowLevelFormatSupported</key>
<false/>
<key>MediaName</key>
<string>Macintosh HD</string>
<key>MediaType</key>
<string>Generic</string>
<key>MountPoint</key>
<string></string>
<key>OS9DriversInstalled</key>
<false/>
<key>ParentWholeDisk</key>
<key>RAIDMaster</key>
<false/>
<key>RAIDSlice</key>
<false/>
<key>SMARTStatus</key>
<string>Not Supported</string>
<key>SupportsGlobalPermissionsDisable</key>
<true/>
<key>SystemImage</key>
<false/>
<key>TotalSize</key>
<key>VolumeName</key>
<key>VolumeUUID</key>
<string>01643E33-D5D1-3241-B101-55E81ABC8036</string>
<key>WholeDisk</key>
<true/>
<key>Writable</key>
<true/>
<key>WritableMedia</key>
<true/>
<key>WritableVolume</key>
<false/>
</dict>
</plist>
iMac-di-Claudio:~ Claudio-LP$ diskutil repairDisk /dev/disk5
You cannot specify a CoreStorage logical volume (and a logical volume should not have a partition map)
/dev/disk0
/dev/disk1
Unencrypted
/dev/disk2
0: DW *67.6 MB disk2
/dev/disk3
0: Apple_partition_scheme *11.7 MB disk3
1: Apple_partition_map 32.3 KB disk3s1
2: Apple_HFS DiskWarrior v5 KG | ... 11.7 MB disk3s2
/dev/disk4
/dev/disk5
Unlocked Encrypted/code]
[code]+-- Logical Volume Group CA6691F3-8037-4D9A-BB0F-FADB4EB53629
Status: Online
Size: 249199591424 B (249.2 GB)
Free Space: 19005440 B (19.0 MB)
+-< Physical Volume EFF125E0-664F-450F-8884-D456604EE75A
| Index: 0
| Disk: disk4s2
| Status: Online
+-> Logical Volume Family 2AE64C42-4713-4C51-A150-BB86FD11D1CC
Encryption Status: Unlocked
Encryption Type: AES-XTS
Conversion Status: Complete
Conversion Direction: -none-
Has Encrypted Extents: Yes
Fully Secure: Yes
Passphrase Required: Yes
+-> Logical Volume A35BB0F1-BCED-438A-BECE-91E99158AB82
Disk: disk5
Status: Online
Size (Total): 248828264448 B (248.8 GB)
Conversion Progress: -none-
Revertible: No
LV Name: Macintosh HD
Volume Name: Macintosh HD
Content Hint: Apple_HFS
iMac-di-Claudio:~ Claudio-LP$ diskutil info disk5
Device Identifier: disk5
Device Node: /dev/disk5
Part of Whole: disk5
Device / Media Name: Macintosh HD
Mounted: Yes
Mount Point: /Volumes/Macintosh HD 1
File System Personality: Journaled HFS+
Type (Bundle): hfs
Name (User Visible): Mac OS Extended (Journaled)
Journal: Journal size 24576 KB at offset 0x15502000
Owners: Disabled
Content (IOContent): Apple_HFS
OS Can Be Installed: No
Non avevo letto.Claudio00 ha scritto:... adesso ci sta di nuovo la cartella su finder
diskutil repairDisk A35BB0F1-BCED-438A-BECE-91E99158AB82
iMac-di-Claudio:~ Claudio-LP$ diskutil repairDisk A35BB0F1-BCED-438A-BECE-91E99158AB82
You cannot specify a CoreStorage logical volume (and a logical volume should not have a partition map)/code]
HELP PLEASE
DataRescue è uno dei migliori, va bene se funziona.Claudio00 ha scritto:... cosa mi consigli ? sto provando con data rescue ma non riesco.
e poi come tolgo password?
quindi devo dimenticare il mio caro portachiavi a meno che non copi i dati...faxus ha scritto:DataRescue è uno dei migliori, va bene se funziona.Claudio00 ha scritto:... cosa mi consigli ? sto provando con data rescue ma non riesco.
Non occorre togliere la criptazione, adesso, non puoi farlo.
Non so cosa succederà, ma la criptazione è un problema.
DataRescue copierà per bit una serie di file sparsi che sono collegati da link crittografati.
Poi li ricovera anonimi.
Non so proprio come tu possa fare a riunirli.
La password si poteva togliere con Terminale.
Ma sul disco riparando con l'utilità diskutil.
A me non piace mai dare notizie funeree.
Anche perché non è mai detto...
Però un disco fisicamente e logicamente rotto, per di più criptato...
È una situazione con remote speranze di soluzione
no su iCloud non ho condiviso il portachiavi.faxus ha scritto:In che senso, copi i dati?
Due domande:
- non avevi sincronizzato il portachiavi con iCloud fra i due Mac?
- il portachiavi che hai sull'iMac contiene le password che ti servono?
In entrambe questi casi puoi ricostruire il portachiavi ovunque vuoi.
Hai perso le password (e discendenti) solo se erano diversi e non sincronizzati.
Infine, anche Safari o altro browser sincronizzabile non aveva le stesse password?
Dato che la maggior parte delle password sono usate su browser si può recuperare un bel po'
Visitano il forum: Google [Bot] e 4 ospiti
