driver stampante
MARIO ROSI
ciao a tutti ho una stampante hp 5740 purtroppo i driver richiedono lion 10.7 io ho snow leopard qualcusa sa dirmi come fare per risconoscere anche lo scanner....grazie a tutti
Stato: Connesso
Pe ala stampa non c'è molto da fare, per lo scanner invece puoi provare VueScan.
Hai provato virtualizzando Winzozz?
MARIO ROSI
vuescan non si attiva..qualche altra applicazione?
Hai scaricato la versione a 32 bit?
https://www.hamrick.com/files/vuex3295.dmg" onclick="window.open(this.href);return false;
http://www.hamrick.com/vuescan/vuescan.htm#macosx" onclick="window.open(this.href);return false;
If VueScan doesn't see your scanner on Mac OS X, first make sure that "About This Mac" (in the Apple menu) in the USB devices section can see the scanner. If it doesn't, try powering off the computer, powering off the scanner, powering on the scanner and then powering on the computer.
If VueScan is crashing, try a newer USB cable and/or a different USB port.
If you're using a scanner that isn't supported by VueScan and you're using Mac OS X 10.10 or earlier, try installing TWAINBridge.app.
If you're using a Ratoc Firewire-SCSI adapter, you may need to configure one of the options. Try setting the time between the power on and the SCSI bus reset to 40.
If you're using the Ratoc USB->SCSI adapter, set up the adapter with the Ratoc utility to "Mass Storage" mode.
If VueScan still doesn't see your scanner, go into "System Preferences", "Accounts", then "Startup Items". Make sure nothing is being started that might be accessing the scanner (i.e. "Epson Scanner Monitor").
If you've installed the Umax software for a Firewire scanner on Mac OS X, you need to remove (or rename):
/System/Library/Extensions/UmaxFireWire.kext
(the name begins with Umax but might have a slightly different name)
http://www.hamrick.com/vuescan/vuescan.htm#hp" onclick="window.open(this.href);return false;
