ciao capo.fragrua ha scritto:Pazzesco. Peggio dei 2011?
Peppiniello, non colgo l'anomalia. Ci puoi spiegare?Peppiniello ha scritto:Penso che a queste schermate tratte dal video su Macrumors non debba aggiungere altro...
if you are trying to find out if you are affected by this particular issue here are a couple checks:
1. The freeze occurs absolutely random, and when it happens it completely freezes everything, there's no moving cursor, there's no movement on the screen, there's no beachball, the trackpad on the new rMBP doesn't "click" anymore, if you try to close the lid it never goes to sleep and it never creates a crash report, the computer sits like that forever and never recovers until you restart it manually, please see the video bellow for a demonstration.
2. The issue is only affecting 10.11.4, if you had it earlier, it's not the issue discussed in this thread.
3. Using Chrome/Firefox/Opera does not fix the issue, if it does, you weren't affected by this specific issue.
4. If you have an older machine (non-2015) you are most likely not affected by this issue(the insanely lag caused by the hard drive cable failure in the macbook pro 2012 comes to mind or the gpu 2011-2013 macbook failure which happened to my old macbook as well).
5. Reinstalling the OS doesn't help.
6. Disabling flash doesn't help, stop blaming it.
Finally I believe this issue has been solved in the latest 10.11.5 beta 4 (15F31a)
lordbye ha scritto:E' capitato anche a me 3 o 4 volte....
in attesa di aggiornamento....non avevo però temperature così alte al momento del blocco..
Da come dice lordbye, allora mi sono sbagliato ed ha ragione cicciopasticcio perché la temperatura raffigurata sarebbe in Fahreneit... Chissà...?cicciopasticcio ha scritto:......La temperatura immagino sia in Fahreneit, che in Celsius significa 38°. Bassa. .....
