Aggiornamento: coconutBattery dice quanto segue e veramente mi chiedo come possa aver contato 192 cicli in 17 mesi
. Purtroppo non sono così paranoico da aver fatto statistiche nel tempo.
Fosse pure la batteria in forma non smagliante per qualche suo motivo, che magari provo a far risolvere o sostituire ad un Apple Store
, qualcuno ha interpretazioni particolari per il resoconto della Console prima dello spengimento e dopo il riavvio?
Mar 3 23:31:48 gm loginwindow[5239]: loginwindow SleepWakeCallback WILL sleep
Mar 3 23:31:48 gm configd[14]: PMConnection mDNSResponder com.apple.powermanagement.applicationresponse.slowresponse 493 ms
Mar 4 18:41:56 localhost com.apple.kextd[10]: Can't create kext cache under / - owner not root.
Mar 4 18:41:50 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Mar 4 18:41:58 localhost com.apple.kextd[10]: Can't create kext cache under / - owner not root.
Mar 4 18:42:02 localhost bootlog[41]: BOOT_TIME: 1299260508 0
Mar 4 18:42:03 localhost fseventsd[33]: event logs in /.fseventsd out of sync with volume. destroying old logs. (173319 15 242304)
Mar 4 18:42:03 localhost fseventsd[33]: log dir: /.fseventsd getting new uuid: AA537CBB-111C-42DC-B293-31EBF18AC1F7
Mar 4 18:42:07 localhost DirectoryService[15]: Improper shutdown detected
Mar 4 18:42:08 localhost blued[16]: Apple Bluetooth daemon started
Mar 4 18:42:11 localhost mDNSResponder[28]: mDNSResponder mDNSResponder-258.14 (Nov 18 2010 14:18:32) starting
Mar 4 18:42:11 localhost com.apple.kextd[10]: Can't create kext cache under / - owner not root.
Mar 4 18:42:11: --- last message repeated 1 time ---
Mar 4 18:42:11 localhost defaults[66]: \nThe domain/default pair of (com.apple.print.FaxPrefs, FaxNumber) does not exist
Mar 4 18:42:11 localhost com.apple.efax[35]: 2011-03-04 18:42:11.637 defaults[66:903]
Mar 4 18:42:11 localhost com.apple.efax[35]: The domain/default pair of (com.apple.print.FaxPrefs, FaxNumber) does not exist
Mar 4 18:42:11 localhost com.apple.efax[35]: /usr/bin/fax: can't read FaxPrefs FaxNumber
Mar 4 18:42:11 localhost com.apple.usbmuxd[21]: usbmuxd-207 built for iTunesTenOne on Oct 19 2010 at 13:50:35, running 64 bit
Mar 4 18:42:12 localhost com.cleverfiles.cfbackd[46]: partition offset c805000
Mar 4 18:42:13 localhost configd[14]: network configuration changed.
Oltre le linee dello spengimento, mi chiedo soprattutto di quelle "
localhost com.apple.kextd[10]: Can't create kext cache under / - owner not root." oltre a quelle con il "fax"...
Grazie,
Giulio
AGGIUNGO: passato all'Apple Store, hanno fatto i controlli del caso e rilevato che effettivamente la batteria ha un malfunzionamento ovvero riconosce male la vera carica. Essendo il tutto abbondantemente fuori garanzia ed in mancanza di Apple Care, il costo sarebbe stato di 149 EUR + IVA... ovvero me lo tengo così, nella speranza che le future calibrazioni portino la batteria alla ragione o quasi.
Intanto se qualcuno avesse comunque commenti da fare sulla Console...
Grazie,
Giulio
