faxus ha scritto:Potevi postare l'ultimo, dovresti aver capito cosa voglio sapere dal log.
Cosa succede nel sistema pochi attimi prima che si spenga.
Vabbè farò quel che si può.
Due cose, per favore:
1) Posta un EtreCheck,
Come fare ad eseguirlo e postarlo:
http://www.imaccanici.org/article.php/EtreCheck" onclick="window.open(this.href);return false;
2) Dimmi che mouse usi.
Se hai una tastiera non Apple, trackpad, joystick ecc
Dimmi anche quali periferiche hai collegate, hub ecc
EtreCheck version: 2.9.12 (265)
Report generated 2016-06-12 22:53:02
Runtime 2:08
Performance: Excellent
Problem: Other problem
Description:
random shutdown
Hardware Information: ⓘ
MacBook Air (11-inch, Early 2014)
MacBook Air - model: MacBookAir6,1
1 1,4 GHz Intel Core i5 CPU: 2-core
4 GB RAM Not upgradeable
BANK 0/DIMM0
2 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Bluetooth: Good - Handoff/Airdrop2 supported
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 105
Video Information: ⓘ
Intel HD Graphics 5000
SyncMaster 1680 x 1050 @ 60 Hz
System Software: ⓘ
OS X El Capitan 10.11.5 (15F34) - Time since boot: less than an hour
Disk Information: ⓘ
APPLE SSD TS0128F disk0 : (121,33 GB) (Solid State - TRIM: Yes)
Macintosh (disk1) / : 120.10 GB (73.24 GB free)
Core Storage: disk0s2 120.47 GB Online
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
Texas Instruments TI-GRAPH LINK USB
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Gatekeeper: ⓘ
Anywhere
System Launch Agents: ⓘ
[not loaded] 7 Apple tasks
[loaded] 160 Apple tasks
[running] 71 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 45 Apple tasks
[loaded] 157 Apple tasks
[running] 88 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (2016-06-10) [Support]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (2016-05-10) [Support]
User Launch Agents: ⓘ
[loaded] com.adobe.ARM.[...].plist (2016-06-10) [Support]
User Login Items: ⓘ
Macs Fan Control Applicazione (/Applications/Macs Fan Control.app)
iTunesHelper Applicazione (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Caffeine Applicazione (/Applications/Caffeine.app)
Other Apps: ⓘ
[running] com.appgeneration.iTunerOSxFree.86432
[running] com.crystalidea.MacsFanControl.102112
[running] com.lightheadsw.caffeine.86752
[running] com.ti.eps.TIConnectX.CommManager.131872
[running] com.ti.eps.TIConnectX.Device-Explorer.128672
[running] com.ti.eps.TIConnectX.OS-Restore.130912
[loaded] 391 Apple tasks
[running] 185 Apple tasks
Internet Plug-ins: ⓘ
AdobeAAMDetect: AdobeAAMDetect 1.0.0.0 - SDK 10.6 (2012-08-09) [Support]
FlashPlayer-10.6: 21.0.0.242 - SDK 10.6 (2016-06-06) [Support]
QuickTime Plugin: 7.7.3 (2016-05-05)
AdobePDFViewerNPAPI: 11.0.0 - SDK 10.6 (2012-09-24) [Support]
AdobePDFViewer: 11.0.0 - SDK 10.6 (2012-09-24) [Support]
Flash Player: 21.0.0.242 - SDK 10.6 (2016-06-06) [Support]
Default Browser: 601 - SDK 10.11 (2016-05-05)
Safari Extensions: ⓘ
Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (2016-06-07)
3rd Party Preference Panes: ⓘ
Flash Player (2016-05-10) [Support]
Time Machine: ⓘ
Mobile backups: ON
Auto backup: YES
Volumes being backed up:
Macintosh : Disk size: 120.10 GB Disk used: 46.86 GB
Destinations:
Elements [Local]
Total size: 800.06 GB
Total number of backups: 2
Oldest backup: 11/06/16, 10:30
Last backup: 12/06/16, 22:24
Backup size 800.06 GB > (Disk size 120.10 GB X 3)
Top Processes by CPU: ⓘ
5% WindowServer
2% fontd
2% kernel_task
2% myTuner Radio Free
1% com.apple.WebKit.WebContent(8)
Top Processes by Memory: ⓘ
680 MB com.apple.WebKit.WebContent(8)
591 MB kernel_task
242 MB Safari
184 MB mdworker(11)
90 MB WindowServer
Virtual Memory Information: ⓘ
89 MB Free RAM
3.91 GB Used RAM (986 MB Cached)
0 B Swap Used
Diagnostics Information: ⓘ
Jun 12, 2016, 10:48:08 PM ~/Library/Logs/DiagnosticReports/TI Connect Manager X_2016-06-12-224808_[redacted].crash
com.ti.eps.TIConnectX.CommManager - /Library/Services/TI Connect Manager X.app/Contents/MacOS/TI Connect Manager X
Jun 12, 2016, 10:38:22 PM Self test - passed
Jun 11, 2016, 09:33:48 AM ~/Library/Logs/DiagnosticReports/amule_2016-06-11-093348_[redacted].crash
org.amule.aMule - /Applications/aMule.app/Contents/MacOS/amule
Jun 10, 2016, 12:57:08 AM /Library/Logs/DiagnosticReports/com.apple.AmbientDisplayAgent_2016-06-10-005708_[redacted].crash
/System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
il problema é che quando ci sono questi spegnimenti nel log non c'é traccia di uno shutdown ma solo del previous shutdown che viene scritto alla riaccensione. Nel caso in cui possa essere utile ti posto dal previous shutdown a qualche secondo prima che si sia spento il pc avendo tenuto d occhio l orologio! spero che possa tornare utile nel caso perdonami se ti ho fatto perdere tempo!faxus ha scritto:Quante volte sono che ti chiedo un log dello spegnimento?
Senza quello tutto è nella divinazione...
Jun 13 19:07:11 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:07:11 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:07:46 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:07:46 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:08:40 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:08:40 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:09:00 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:09:00 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:09:10 MacBook-Air-di-Matteo syslogd[40]: ASL Sender Statistics
Jun 13 19:09:34 MacBook-Air-di-Matteo launchservicesd[75]: SecTaskLoadEntitlements failed error=22
Jun 13 19:09:35 --- last message repeated 1 time ---
Jun 13 19:09:35 MacBook-Air-di-Matteo appleeventsd[48]: SecTaskLoadEntitlements failed error=22
Jun 13 19:09:39 MacBook-Air-di-Matteo launchservicesd[75]: SecTaskLoadEntitlements failed error=22
Jun 13 19:09:40 --- last message repeated 1 time ---
Jun 13 19:09:40 MacBook-Air-di-Matteo loginwindow[91]: ERROR | -[PersistentAppsSupport saveLogoutPersistentState:finalSnapshot:] | Attempt to insert app with NULL bundle ID
Jun 13 19:09:48 MacBook-Air-di-Matteo kernel[0]: ignored is_io_service_close(0x1000003b7,IOHIDParamUserClient)
Jun 13 19:09:55 --- last message repeated 3 times ---
Jun 13 19:09:55 MacBook-Air-di-Matteo launchservicesd[75]: SecTaskLoadEntitlements failed error=22
Jun 13 19:10:29 --- last message repeated 2 times ---
Jun 13 19:10:29 MacBook-Air-di-Matteo launchservicesd[75]: SecTaskLoadEntitlements failed error=22
Jun 13 19:12:18 MacBook-Air-di-Matteo sharedfilelistd[384]: SecTaskLoadEntitlements failed error=22
Jun 13 19:12:18 MacBook-Air-di-Matteo pkd[385]: SecTaskLoadEntitlements failed error=22
Jun 13 19:12:18 MacBook-Air-di-Matteo EAGLE[1384]: assertion failed: 15F34: libxpc.dylib + 78286 [54D1328E-054E-3DAA-89E2-375722F9D18F]: 0x89
Jun 13 19:12:22 MacBook-Air-di-Matteo launchservicesd[75]: SecTaskLoadEntitlements failed error=22
Jun 13 19:13:03 MacBook-Air-di-Matteo com.apple.xpc.launchd[1] (com.apple.WebKit.WebContent.871579E5-10B9-4025-8694-7EA83537B5BD[1534]): Service exited with abnormal code: 1
Jun 13 19:13:06 MacBook-Air-di-Matteo WindowServer[142]: _CGXRemoveWindowFromWindowMovementGroup: window 0x69 is not attached to window 0x6e
Jun 13 19:13:07 MacBook-Air-di-Matteo Safari[538]: tcp_connection_tls_session_error_callback_imp 49 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22
Jun 13 19:13:19 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:13:19 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:14:01 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:14:01 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:14:16 MacBook-Air-di-Matteo WindowServer[142]: _CGXRemoveWindowFromWindowMovementGroup: window 0x69 is not attached to window 0x6e
Jun 13 19:14:16 MacBook-Air-di-Matteo Safari[538]: tcp_connection_tls_session_error_callback_imp 56 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22
Jun 13 19:14:31 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:14:31 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:14:40 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:14:40 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:15:10 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:15:10 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:15:29 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:15:29 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:16:34 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:16:34 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:16:43 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:16:43 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:17:10 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: keychain: -25300
Jun 13 19:17:10 MacBook-Air-di-Matteo Safari[538]: KeychainGetICDPStatus: status: off
Jun 13 19:17:46 localhost bootlog[0]: BOOT_TIME 1465838266 0
Jun 13 19:17:48 localhost syslogd[41]: Configuration Notice:
ASL Module "com.apple.AccountPolicyHelper" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.Accounts" claims selected messages.
Jun 13 19:17:48 --- last message repeated 1 time ---
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.authkit.osx.asl" sharing output destination "/var/log/Accounts" with ASL Module "com.apple.Accounts".
Output parameters from ASL Module "com.apple.Accounts" override any specified in ASL Module "com.apple.authkit.osx.asl".
ASL Module "com.apple.authkit.osx.asl" claims selected messages.
ASL Module "com.apple.awdd" claims selected messages.
ASL Module "com.apple.callhistory.asl.conf" claims selected messages.
ASL Module "com.apple.cdscheduler" claims selected messages.
ASL Module "com.apple.cloudd" claims selected messages.
ASL Module "com.apple.clouddocs" claims selected messages.
ASL Module "com.apple.commerce.asl" claims selected messages.
ASL Module "com.apple.contacts.ContactsAutocomplete" claims selected messages.
ASL Module "com.apple.corecdp.osx.asl" sharing output destination "/var/log/Accounts" with ASL Module "com.apple.Accounts".
Output parameters from ASL Module "com.apple.Accounts" override any specified in ASL Module "com.apple.corecdp.osx.asl".
ASL Module "com.apple.corecdp.osx.asl" claims selected messages.
ASL Module "com.apple.CoreDuetAdmissionControl" claims selected messages.
ASL Module "com.apple.corespotlight" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.family.asl" claims selected messages.
ASL Module "com.apple.ical" claims selected messages.
ASL Module "com.apple.icloud.FindMyDevice" claims selected messages.
ASL Module "com.apple.icloud.fmfd" claims selected messages.
Jun 13 19:17:48 --- last message repeated 2 times ---
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.mobileme.fmf1" claims selected messages.
ASL Module "com.apple.mobileme.fmf1.internal" sharing output destination "/var/log/FindMyFriendsApp/FindMyFriendsApp.asl" with ASL Module "com.apple.mobileme.fmf1".
Output parameters from ASL Module "com.apple.mobileme.fmf1" override any specified in ASL Module "com.apple.mobileme.fmf1.internal".
ASL Module "com.apple.mobileme.fmf1.internal" sharing output destination "/var/log/FindMyFriendsApp" with ASL Module "com.apple.mobileme.fmf1".
ASL Module "com.apple.mobileme.fmf1.internal" claims selected messages.
ASL Module "com.apple.networking.symptoms" claims selected messages.
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.secinitd" claims selected messages.
ASL Module "com.apple.securityd" claims selected messages.
Jun 13 19:17:48 --- last message repeated 7 times ---
ASL Module "com.apple.xpc.activity" claims selected messages.
Jun 13 19:17:48 localhost kernel[0]: Longterm timer threshold: 1000 ms
Jun 13 19:17:48 localhost kernel[0]: PMAP: PCID enabled
Jun 13 19:17:48 localhost kernel[0]: PMAP: Supervisor Mode Execute Protection enabled
Jun 13 19:17:48 localhost kernel[0]: Darwin Kernel Version 15.5.0: Tue Apr 19 18:36:36 PDT 2016; root:xnu-3248.50.21~8/RELEASE_X86_64
Jun 13 19:17:48 localhost kernel[0]: vm_page_bootstrap: 904912 free pages and 135472 wired pages
Jun 13 19:17:48 localhost kernel[0]: kext submap [0x<ptr> - 0x<ptr>], kernel text [0x<ptr> - 0x<ptr>]
Jun 13 19:17:48 localhost kernel[0]: zone leak detection enabled
Jun 13 19:17:48 localhost kernel[0]: "vm_compressor_mode" is 4
Jun 13 19:17:48 localhost kernel[0]: multiq scheduler config: deep-drain 0, ceiling 47, depth limit 4, band limit 127, sanity check 0
Jun 13 19:17:48 localhost kernel[0]: standard timeslicing quantum is 10000 us
Jun 13 19:17:48 localhost kernel[0]: standard background quantum is 2500 us
Jun 13 19:17:48 localhost kernel[0]: WQ[lt_init]: init linktable with max:262144 elements (8388608 bytes)
Jun 13 19:17:48 localhost kernel[0]: WQ[wqp_init]: init prepost table with max:262144 elements (8388608 bytes)
Jun 13 19:17:48 localhost kernel[0]: mig_table_max_displ = 16
Jun 13 19:17:48 localhost kernel[0]: TSC Deadline Timer supported and enabled
Jun 13 19:17:48 localhost kernel[0]: kdp_core zlib memory 0x7000
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=1 Enabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=3 Enabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=255 Disabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=255 Disabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=255 Disabled
Jun 13 19:17:48 localhost kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=255 Disabled
Jun 13 19:17:48 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
Jun 13 19:17:48 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Jun 13 19:17:48 localhost kernel[0]: calling mpo_policy_init for AMFI
Jun 13 19:17:48 localhost kernel[0]: Security policy loaded: Apple Mobile File Integrity (AMFI)
Jun 13 19:17:48 localhost kernel[0]: calling mpo_policy_init for Sandbox
Jun 13 19:17:48 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
Jun 13 19:17:48 localhost kernel[0]: calling mpo_policy_init for Quarantine
Jun 13 19:17:48 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
Jun 13 19:17:48 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Jun 13 19:17:48 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Jun 13 19:17:48 localhost kernel[0]: MAC Framework successfully initialized
Jun 13 19:17:48 localhost kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
Jun 13 19:17:48 localhost kernel[0]: AppleCredentialManager::start called
Jun 13 19:17:48 localhost kernel[0]: AssertMacros: tmpData (value: 0x0), file: /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleCredentialManager/AppleCredentialManager-83.40.3/AppleCredentialManager/AppleCredentialManager.cpp, line: 785
Jun 13 19:17:48 localhost kernel[0]: AppleKeyStore starting (BUILT: Apr 19 2016 21:25:04)
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1]: assertion failed: 15F34: launchd + 180050 [48362449-4519-317E-9A8B-7524036DE5EA]: 0x1
Jun 13 19:17:48 localhost kernel[0]: IOAPIC: Version 0x20 Vectors 64:103
Jun 13 19:17:48 localhost kernel[0]: ACPI: sleep states S0 S3 S4 S5
Jun 13 19:17:48 localhost kernel[0]: pci (build 19:40:46 Apr 19 2016), flags 0xe3400, pfm64 (39 cpu) 0x7f80000000, 0x80000000
Jun 13 19:17:48 localhost kernel[0]: [ PCI configuration begin ]
Jun 13 19:17:48 localhost kernel[0]: console relocated to 0x7f90000000
Jun 13 19:17:48 localhost kernel[0]: [ PCI configuration end, bridges 12, devices 14 ]
Jun 13 19:17:48 localhost kernel[0]: 000000.938242 AppleUSBLegacyRoot@: AppleUSBLegacyRoot::init: enabling legacy matching
Jun 13 19:17:48 localhost kernel[0]: AppleIntelLpssGspi1::initFixedDMA: FixedDMA not found in _CRS
Jun 13 19:17:48 localhost kernel[0]: AppleIntelLpssGspi1::calcSpiClockParams: fSysClockPeriodPsec 10000, spiClockPeriodNsec 125
Jun 13 19:17:48 localhost kernel[0]: AirPort_Brcm4360::init AirPortFamily_kexts-1110.28 "AirPortFamily_kexts-1110.28" Apr 19 2016 21:16:56
Jun 13 19:17:48 localhost kernel[0]: AppleHSSPIController::start Start Succeeded
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1]: Failed to remove file or directory: name = dyld_shared_cache_x86_64h, error = 1: Operation not permitted. Further logging suppressed.
Jun 13 19:17:48 localhost kernel[0]: AppleThunderboltNHIType2::setupPowerSavings - GPE based runtime power management
Jun 13 19:17:48 localhost kernel[0]: AppleHSSPIController::HandleMessage Device Wake by Host
Jun 13 19:17:48 localhost kernel[0]: [HID] [MT] AppleMultitouchDevice::start entered
Jun 13 19:17:48 localhost kernel[0]: Apple Internal Keyboard / Trackpad::start Start Succeeded
Jun 13 19:17:48 localhost kernel[0]: mcache: 4 CPU(s), 64 bytes CPU cache line size
Jun 13 19:17:48 localhost kernel[0]: mbinit: done [64 MB total pool size, (42/21) split]
Jun 13 19:17:48 localhost kernel[0]: rooting via boot-uuid from /chosen: 2D57B1DB-7601-335B-A0F9-01BACCB25F74
Jun 13 19:17:48 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Jun 13 19:17:48 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
Jun 13 19:17:48 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
Jun 13 19:17:48 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.alf): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Jun 13 19:17:48 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
Jun 13 19:17:48 localhost kernel[0]: IO80211Controller::createIOReporters 0x96f0e5f3b5c40561
Jun 13 19:17:48 localhost kernel[0]: CCFlags: 0x0, CCLevel: 5 ConsoleFlags: 0x0, ConsoleLevel: -1
Jun 13 19:17:48 localhost kernel[0]: No Service found 10000025b
Jun 13 19:17:48 localhost kernel[0]: configureInterests - nElements <= 0!Failed to addSubscription for group Chip subgroup Bytes Transferred driver 0x96f0e5f3b5c40561 - data underrun
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.airplaydiagnostics.server): Unrecognized MachService property: ResetAtClose
Jun 13 19:17:48 localhost kernel[0]: IO80211ControllerMonitor::configureSubscriptions() failed to add subscriptionIO80211Controller::start _controller is 0x96f0e5f3b5c40561, provider is 0x96f0e5f356990961
Jun 13 19:17:48 localhost kernel[0]: CoreStorage: fsck_cs has finished for group "BD3B3973-8588-47F7-BEA4-CD11D7620890" with status 0x00
Jun 13 19:17:48 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/RP06@1C,5/IOPP/SSD0@0/AppleAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/APPLE SSD TS0128F Media/IOGUIDPartitionScheme/Macintosh @2/CoreStoragePhysical/Macintosh /Macintosh
Jun 13 19:17:48 localhost kernel[0]: BSD root: disk1, major 1, minor 4
Jun 13 19:17:48 localhost kernel[0]: jnl: b(1, 4): replay_journal: from: 924672 to: 6981120 (joffset 0x388000)
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.396372: srom rev:11
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.397236: ChangeVCO => vco:960, xtalF:40, frac: 98, ndivMode: 3, ndivint: 24
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.397262: Data written into the PLL_CNTRL_ADDR2: 00000c31
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.AirPlayXPCHelper): This service is defined to be constantly running and is inherently inefficient.
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.397325: Data written into the PLL_CNTRL_ADDR3 (Fractional): 0000100e
Jun 13 19:17:48 localhost kernel[0]: init: error getting PHY_MODE; using MODE_UNKNOWN
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.411159: BRCM tunables:
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.411168: pullmode[1] txringsize[ 256] txsendqsize[1024] reapmin[ 32] reapcount[ 128]
Jun 13 19:17:48 localhost kernel[0]: ARPT: 1.412128: wl0: Broadcom BCM43a0, vendorID[0x14e4] BAR0[0xb0600004]
Jun 13 19:17:48 localhost kernel[0]: 7.21.95.175 (r622517)
Jun 13 19:17:48 localhost kernel[0]: IOBluetoothUSBDFU::probe
Jun 13 19:17:48 localhost kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x828F FirmwareVersion - 0x0118
Jun 13 19:17:48 localhost kernel[0]: jnl: b(1, 4): journal replay done.
Jun 13 19:17:48 localhost kernel[0]: hfs: mounted Macintosh on device root_device
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.auditd): The TimeOut key is no longer respected. It never did anything anyway.
Jun 13 19:17:48 localhost kernel[0]: XCPM: registered
Jun 13 19:17:48 localhost kernel[0]: VM Swap Subsystem is ON
Jun 13 19:17:48 localhost kernel[0]: hfs: Removed 85 orphaned / unlinked files and 405 directories
Jun 13 19:17:48 localhost kernel[0]: Sandbox: launchd(1) System Policy: deny(1) file-write-flags /private/var/run/dyld_shared_cache_x86_64h
Jun 13 19:17:48 localhost kernel[0]: Sandbox: launchd(1) System Policy: deny(1) file-write-unlink /private/var/run/dyld_shared_cache_x86_64h
Jun 13 19:17:48 localhost kernel[0]: Sandbox: launchd(1) System Policy: deny(1) file-write-flags /private/var/run/dyld_shared_cache_x86_64h.map
Jun 13 19:17:48 localhost kernel[0]: Sandbox: launchd(1) System Policy: deny(1) file-write-unlink /private/var/run/dyld_shared_cache_x86_64h.map
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.autofsd): This service is defined to be constantly running and is inherently inefficient.
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.backupd-status): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.backupd.status.xpc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.bsd.dirhelper): The TimeOut key is no longer respected. It never did anything anyway.
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.cmio.IIDCVideoAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.cmio.AVCAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Jun 13 19:17:47 localhost com.apple.xpc.launchd[1] (com.apple.cmio.VDCAssistant): ThrottleInterval set to zero. You're not that important. Ignoring.
Jun 13 19:17:48 localhost fseventsd[44]: event logs in /.fseventsd out of sync with volume. destroying old logs. (12507 2 12538)
Jun 13 19:17:48 localhost watchdogd[58]: [watchdog_daemon] @( wd_watchdog_open) - IOIteratorNext failed (kr=0)
Jun 13 19:17:48 localhost watchdogd[58]: [watchdog_daemon] @( wd_daemon_init) - could not open connection with the kernel watchdog
Jun 13 19:17:48 localhost watchdogd[58]: [watchdog_daemon] @( main) - cannot initialize the watchdog service
Jun 13 19:17:48 localhost fseventsd[44]: log dir: /.fseventsd getting new uuid: 5CDA7C9A-B0D2-4813-B47B-41F077B9E846
Jun 13 19:17:48 localhost hidd[94]: void __IOHIDPlugInLoadBundles(): Loaded 0 HID plugins
Jun 13 19:17:48 localhost hidd[94]: IOHIDService compatibility thread running at priority 63 and schedule 2.
Jun 13 19:17:48 localhost com.apple.SecurityServer[77]: Session 100000 created
Jun 13 19:17:48 localhost syslogd[41]: ASL Sender Statistics
Jun 13 19:17:48 localhost powerd[50]: Registering for UPS devices
Jun 13 19:17:48 localhost powerd[50]: UPSDeviceAdded. _alreadyRunningIOUPSD:0
Jun 13 19:17:48 localhost kernel[0]: IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
Jun 13 19:17:48 localhost kernel[0]: IO80211Interface::efiNVRAMPublished():
Jun 13 19:17:48 localhost kernel[0]: initting Scan Manager controller 0x96f0e5f3b5c40561 ioservice 0x96f0e5f356990961 interface 0x96f0e5f356bf7161 ioservce 0x96f0e5f3b5c40561
Jun 13 19:17:48 localhost kernel[0]: bpfAttach len 64 dlt 12
Jun 13 19:17:48 localhost kernel[0]: fInterfaceSnapshots is missing
Jun 13 19:17:48 --- last message repeated 9 times ---
Jun 13 19:17:48 localhost iconservicesagent[64]: iconservicesagent launched.
Jun 13 19:17:48 localhost kernel[0]: Waiting for DSMOS...
Jun 13 19:17:48 localhost diagnosticd[120]: ostraceutil returned error 18176 while linking caches
Jun 13 19:17:48 localhost com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Jun 13 19:17:48 localhost com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Jun 13 19:17:48 localhost com.apple.xpc.launchd[1] (com.apple.trustd.agent): This key does not do anything: OnDemand
Jun 13 19:17:48 localhost com.apple.xpc.launchd[1] (com.apple.trustd.agent): The ServiceIPC key is no longer respected. Please remove it.
Jun 13 19:17:48 localhost com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Jun 13 19:17:48 localhost distnoted[99]: # distnote server daemon absolute time: 3.963577093 civil time: Mon Jun 13 19:17:48 2016 pid: 99 uid: 241 root: yes
Jun 13 19:17:48 localhost hidd[94]: ____IOHIDSessionScheduleAsync_block_invoke: thread_id=0x700000081000
Jun 13 19:17:48 localhost hidd[94]: HID Session async scheduling initiated.
Jun 13 19:17:48 localhost hidd[94]: HID Session async root queue running at priority 63 and schedule 2.
Jun 13 19:17:48 localhost kernel[0]: Unrecognized reportID 0x02
Jun 13 19:17:48 localhost hidd[94]: HID Session async scheduling complete.
Jun 13 19:17:48 localhost hidd[94]: Successfully opened the IOHIDSession
Jun 13 19:17:48 localhost hidd[94]: [HID] [MT] MTSimpleHIDManager::deviceDidBootload device bootloaded
Jun 13 19:17:48 localhost com.apple.usbmuxd[76]: log filter changed from 4 to 6
Jun 13 19:17:48 localhost com.apple.SecurityServer[77]: Entering service
Jun 13 19:17:48 localhost blued[82]: Delete logs
Jun 13 19:17:48 localhost com.apple.usbmuxd[76]: usbmuxd-364 on Mar 2 2016 at 15:12:39, running 64 bit
Jun 13 19:17:48 localhost apsd[74]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
Jun 13 19:17:48 localhost com.apple.xpc.launchd[1] (com.apple.CoreRAID[45]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.CoreRAID
Jun 13 19:17:48 localhost kernel[0]: IOGraphics flags 0x43
Jun 13 19:17:48 localhost kernel[0]: **** [IOBluetoothHostControllerUSBTransport][start] -- completed -- result = TRUE -- 0x2800 ****
Jun 13 19:17:48 localhost kernel[0]: **** [BroadcomBluetoothHostControllerUSBTransport][start] -- Completed (matched on Device) -- 0x2800 ****
Jun 13 19:17:48 localhost kernel[0]: AppleCamIn::init
Jun 13 19:17:48 localhost kernel[0]: AppleCamIn::probe
Jun 13 19:17:48 localhost kernel[0]: AppleCamIn::start
Jun 13 19:17:48 localhost kernel[0]: virtual bool AppleCamIn::start(IOService *): about to configure DDR
Jun 13 19:17:48 localhost kernel[0]: AppleCamIn::start - S2 DDR Frequency set to 450 MHz (default)
Jun 13 19:17:48 localhost kernel[0]: [IOBluetoothFamily][staticBluetoothTransportShowsUp] -- Received Bluetooth Controller register service notification -- 0x2800
Jun 13 19:17:48 localhost kernel[0]: [IOBluetoothFamily][start] -- completed
Jun 13 19:17:48 localhost kernel[0]: [IOBluetoothHostController][start] -- completed
Jun 13 19:17:48 localhost kernel[0]: [IOBluetoothHostController::setConfigState] calling registerService
Jun 13 19:17:48 localhost kernel[0]: **** [IOBluetoothFamily][ProcessBluetoothTransportShowsUpActionWL] -- calling IOBluetoothFamily's registerService() -- 0x8100 -- 0x4000 -- 0x2800 ****
Jun 13 19:17:48 localhost kernel[0]: **** [IOBluetoothFamily][ProcessBluetoothTransportShowsUpActionWL] -- Connected to the transport successfully -- 0x8100 -- 0x4000 -- 0x2800 ****
Jun 13 19:17:48 localhost configd[49]: preference: no sharing preferences
Jun 13 19:17:48 localhost kernel[0]: AirPort: Link Down on en0. Reason 8 (Disassociated because station leaving).
Jun 13 19:17:48 localhost kernel[0]: Got incomplete channel sequence length 0, should be 16
Jun 13 19:17:48 localhost kernel[0]: en0: channel changed to 1
Jun 13 19:17:48 localhost kernel[0]: en0::IO80211Interface::postMessage bssid changed
Jun 13 19:17:48 localhost kernel[0]: bpfAttach len 94 dlt 163
Jun 13 19:17:48 localhost kernel[0]: bpfAttach len 30 dlt 105
Jun 13 19:17:48 localhost kernel[0]: bpfAttach len 52 dlt 127
Jun 13 19:17:48 localhost kernel[0]: bpfAttach len 38 dlt 192
Jun 13 19:17:48 localhost secinitd[140]: UID[0]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
Jun 13 19:17:48 localhost secinitd[140]: ctkd[139]: unable to get root path for bundle of main executable: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Jun 13 19:17:48 localhost configd[49]: dhcp_arp_router: en0 SSID unavailable
Jun 13 19:17:48 localhost UserEventAgent[40]: Captive: CNPluginHandler en0: Inactive
Jun 13 19:17:48 localhost mDNSResponder[87]: mDNSResponder mDNSResponder-625.50.5 (Mar 13 2016 17:24:47) starting OSXVers 15
Jun 13 19:17:48 localhost blued[82]: INIT -- Host controller is published
Jun 13 19:17:48 localhost blued[82]: [BluetoothHIDDeviceController] EventServiceConnectedCallback
Jun 13 19:17:48 localhost blued[82]: [BluetoothHIDDeviceController] EventServiceDisconnectedCallback
Jun 13 19:17:49 localhost kernel[0]: Previous shutdown cause: -128
Jun 13 19:17:49 localhost kernel[0]: DSMOS has arrived
Jun 13 19:17:49 localhost kernel[0]: IOPPF - IODeviceTree:/efi/platform/StartupPowerEvents: 0x0
Jun 13 19:17:49 localhost UserEventAgent[40]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Jun 13 19:17:49 localhost kernel[0]: hmm.. mismatch sizes: 3100 vs 20
Jun 13 19:17:49 localhost kernel[0]: PPGTT is enabled
Jun 13 19:17:49 localhost loginwindow[90]: Login Window Application Started
Jun 13 19:17:49 localhost kernel[0]: save_ddr_phy_regs: saving 127 DDR PHY shmoo-calibrated registers
Jun 13 19:17:49 localhost blued[82]: Successfully applied power change for regulatory requirement
Jun 13 19:17:49 localhost kernel[0]: AppleCamIn::start - link control offset in PCI bridge = 0x50
Jun 13 19:17:49 localhost kernel[0]: AppleCamIn::start - pmcsr offset in PCI bridge = 0xa4
Jun 13 19:17:49 localhost kernel[0]: AppleCamIn::power_off_hardware
Jun 13 19:17:49 localhost com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Jun 13 19:17:49 MacBook-Air-di-Matteo configd[49]: setting hostname to "MacBook-Air-di-Matteo.local"
Stamattina ci ha fatto tre volte e non ho attaccato nulla al mac, te lo scrivo affinché possa esserti utile per capire meglio! E' un qualcosa di aleatorio, non accade ne a temperature particolari ne con programmi e o periferiche particolari... Grazie ancora per l aiuto!faxus ha scritto:Va bene, più o meno, adesso
