Eh, era il pacchetto sicurezza del buon faxus. Mica mi ero accorto di quest'altra palata di roba tua nella pagina precedente... Grazie.
Jan 16 17:17:09 gm BlockBlock[97]: BLOCKBLOCK(97) alert: /bin/ln installed a launch daemon or agent (/Library/LaunchDaemons/org.virtualbox.startup.plist -> /Library/Application Support/VirtualBox/LaunchDaemons/VirtualBoxStartup.sh)
Gentilmente, mi sento confuso (semicit.), cosa consigli qui? Dubitando fosse qualcosa di profondo, ieri ho anche ripassato il sistema su sé stesso da chiavetta e poi aggiornato tutto. A latere, ma forse manco troppo, sia prima che dopo questo trattamento la combo 10.13.6 diceva e dice
Jan 16 21:52:11 gm com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.quicklookd.877): Path not allowed in target domain: type = pid, path = /Applications/Suspicious Package.app/Contents/Frameworks/SuspiciousPackageCore.framework/Versions/A/XPCServices/com.mothersruin.XPCService.UpdateChecker.xpc error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app
Jan 16 21:52:11 gm com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.QuickLookSatellite.918): Path not allowed in target domain: type = pid, path = /Applications/Suspicious Package.app/Contents/Frameworks/SuspiciousPackageCore.framework/Versions/A/XPCServices/com.mothersruin.XPCService.UpdateChecker.xpc error = 147: The specified service did not ship in the requestor's bundle, origin = /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/XPCServices/QuickLookSatellite.xpc
Jan 16 21:52:34 gm com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Jan 16 21:52:37 gm com.apple.xpc.launchd[1] (com.apple.mdworker.shared.02000000-0000-0000-0000-000000000000[880]): Service exited due to signal: Killed: 9 sent by mds[86]
Jan 16 21:52:43 gm com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Jan 16 21:52:44 gm com.apple.xpc.launchd[1] (com.apple.mdworker.shared.04000000-0000-0000-0000-000000000000[905]): Service exited due to signal: Killed: 9 sent by mds[86]
Jan 16 21:52:45 gm com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Jan 16 21:52:45 gm com.apple.preference.security.remoteservice[1014]: objc[1014]: Class AWDSecurityPrefAutoUnlockSetup is implemented in both /System/Library/PreferencePanes/Security.prefPane/Contents/XPCServices/com.apple.preference.security.remoteservice.xpc/Contents/MacOS/com.apple.preference.security.remoteservice (0x1012148e0) and /System/Library/PreferencePanes/Security.prefPane/Contents/MacOS/Security (0x102e7ef18). One of the two will be used. Which one is undefined.
Jan 16 21:52:46 gm spindump_agent[987]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
Jan 16 21:52:55 gm filecoordinationd[437]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Jan 16 21:52:56 gm parsecd[453]: libcoreservices: _dirhelper: 666: mkdir: path=/var/folders/t4/_n2p_2114r319x7pz97yg_gw0000gn/0/com.apple.parsecd/ modes[0]=0755: Operation not permitted
Jan 16 21:52:56 gm com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Jan 16 21:52:56 gm com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.501): Attempt to re-bootstrap service from different path, will use existing: service = com.apple.Safari.History, existing = /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc, conflicting = /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc
Jan 16 21:52:56 gm Spotlight[447]: assertion failed: 17G14042: libxpc.dylib + 74985 [26D99819-B813-320E-9E8F-9D57AD2DA63B]: 0x89
Jan 16 21:52:57 gm diagnosticd[1041]: no EOS device present
Jan 16 21:52:57 gm diagnosticd[1041]: System mode client started - Console (1040) - mode: 0xb
Jan 16 21:52:59 gm Console[1040]: BUG in libdispatch client: kevent[vnode] monitored resource vanished before the source cancel handler was invoked
Jan 16 21:53:02 gm parsecd[453]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
Jan 16 21:53:03 gm Dock[406]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
Jan 16 21:53:07 gm com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
sudo spctl kext-consent list
Allowed Team Identifiers:
VB5E2TV963
VB5E2TV963
Sì sì lo so
Vero! Avevo pensato a ripassare l'installer da chiavetta più aggiornamenti dopo aver rimosso quelle protezioni ma in effetti un'altra prova sarebbe avviare da un sistema pulito esterno...
Alla fine si è preso un anno e mezzo, ma è stato bravissimo!
