Crash macbook dopo caduta
france0314
Salve a tutti ho un macbook pro early 2015 e dopo essere caduto lo schermo non si accende più nonostante il computer si accende tranquillamente. Ho collegato il macbook con il monitor esterno e mi ha dato questo resoconto del problema. Potete dirmi se è legato in qualche modo al monitor o se c'è qualcosa da cambiare grazie.
panic(cpu 0 caller 0xffffff8015ccf860): nvme: "Fatal error occurred. CSTS=0x9 US[1]=0x0 US[0]=0x20e VID=0x144d DID=0xa802
. FW Revision=7L0QBXX7\n"@/System/Volumes/Data/SWE/macOS/BuildRoots/220e8a1b79/Library/Caches/com.apple.xbs/Sources/IONVMeFamily/IONVMeFamily-557.120.1/Common/IONVMeController.cpp:5499
Backtrace (CPU 0), Frame : Return Address
0xffffffa08b003960 : 0xffffff801348d25d
0xffffffa08b0039b0 : 0xffffff80135d49d3
0xffffffa08b0039f0 : 0xffffff80135c4fca
0xffffffa08b003a40 : 0xffffff8013431a2f
0xffffffa08b003a60 : 0xffffff801348ca7d
0xffffffa08b003b80 : 0xffffff801348cd73
0xffffffa08b003bf0 : 0xffffff8013c9d8fa
0xffffffa08b003c60 : 0xffffff8015ccf860
0xffffffa08b003c80 : 0xffffff8015cb445b
0xffffffa08b003de0 : 0xffffff8013bf44d5
0xffffffa08b003e50 : 0xffffff8013bf43d6
0xffffffa08b003e80 : 0xffffff80134d3975
0xffffffa08b003ef0 : 0xffffff80134d48e4
0xffffffa08b003fa0 : 0xffffff801343113e
Kernel Extensions in backtrace:
com.apple.iokit.IONVMeFamily(2.1)[A345061F-96C6-39B7-9334-7771D1EF7FEF]@0xffffff8015cad000->0xffffff8015cd6fff
dependency: com.apple.driver.AppleEFINVRAM(2.1)[511FC3DC-D63F-3993-9C5C-613AF51D837C]@0xffffff80148fe000->0xffffff8014907fff
dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[61A199C8-BE3B-3351-84B8-266A6A43632F]@0xffffff8014ac0000->0xffffff8014ad5fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[85F4689A-E48F-32A7-B55D-AD02BAB2DEE6]@0xffffff8015f6b000->0xffffff8015f93fff
dependency: com.apple.iokit.IOReportFamily(47)[E6A1E6F1-DA86-37C0-91F1-33FFF823A85B]@0xffffff8015fa2000->0xffffff8015fa4fff
dependency: com.apple.iokit.IOStorageFamily(2.1)[AEB16297-5950-3E23-84C4-2E9928878BA1]@0xffffff801606e000->0xffffff801607ffff
Process name corresponding to current thread: kernel_task
Mac OS version:
20G224
Kernel version:
Darwin Kernel Version 20.6.0: Tue Oct 12 18:33:42 PDT 2021; root:xnu-7195.141.8~1/RELEASE_X86_64
Kernel UUID: ABC69550-60C2-34FE-B307-C24A8C39309C
KernelCache slide: 0x0000000013200000
KernelCache base: 0xffffff8013400000
Kernel slide: 0x0000000013210000
Kernel text base: 0xffffff8013410000
__HIB text base: 0xffffff8013300000
System model name: MacBookPro12,1 (Mac-E43C1C25D4880AD6)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 873898421349
Last Sleep: absolute base_tsc base_nano
Uptime : 0x000000cb7867b684
Sleep : 0x000000ba2cb51d67 0x00000d0cee2e80b4 0x000000aeaa7152dc
Wake : 0x000000ba392e3173 0x00000d2e7216a570 0x000000ba3847f952
last started kext at 489117323538: >!UAudio 405.39 (addr 0xffffff7fadfb2000, size 315392)
last stopped kext at 254375871334: >IOPlatformPluginLegacy 1.0.0 (addr 0xffffff7fae3a4000, size 36864)
loaded kexts:
org.virtualbox.kext.VBoxNetAdp 6.1.16
org.virtualbox.kext.VBoxNetFlt 6.1.16
org.virtualbox.kext.VBoxUSB 6.1.16
org.virtualbox.kext.VBoxDrv 6.1.16
com.dolby.DolbyAudioBridge 1.0.0
>!AHDAHardwareConfigDriver 283.15
>!AUpstreamUserClient 3.6.8
@filesystems.autofs 3.0
@fileutil 20.036.15
>X86PlatformShim 1.0.0
>AGPM 122.1
>!APlatformEnabler 2.7.0d0
>AudioAUUC 1.70
>!AGraphicsDevicePolicy 6.3.5
@AGDCPluginDisplayMetrics 6.3.5
>pmtelemetry 1
|IOUserEthernet 1.0.1
>usb.!UUserHCI 1
|IO!BSerialManager 8.0.5d7
@Dont_Steal_Mac_OS_X 7.0.0
>!AHV 1
>!AHDA 283.15
>!ADiskImages2 1
>!ACameraInterface 7.6.0
>eficheck 1
|Broadcom!B20703USBTransport 8.0.5d7
>!A!IBDWGraphics 16.0.5
>!ALPC 3.1
>!A!ISlowAdaptiveClocking 4.0.0
>!ABacklight 180.3
>!AThunderboltIP 4.0.3
>!ASMCLMU 212
>!AMCCSControl 1.14
>!A!IBDWGraphicsFramebuffer 16.0.5
|IO!BUSBDFU 8.0.5d7
|SCSITaskUserClient 436.140.1
>!UCardReader 511.141.1
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.hfs.kext 556.100.11
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
>!ATopCaseHIDEventDriver 4050.1
@filesystems.apfs 1677.141.2
>AirPort.BrcmNIC 1400.1.1
@private.KextAudit 1.0
>!ASmartBatteryManager 161.0.0
>!ARTC 2.0
>!AACPIButtons 6.1
>!AHPET 1.8
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 311
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
>!UAudio 405.39
|IOUSBUserClient 900.4.2
@kext.triggers 1.0
>!AGraphicsControl 6.3.5
|IOSerial!F 11
|IOAVB!F 940.4
|IOEthernetAVB!C 1.1.0
>DspFuncLib 283.15
@kext.OSvKernDSPLib 529
@!AGPUWrangler 6.3.5
@plugin.IOgPTPPlugin 985.2
|Broadcom!BHost!CUSBTransport 8.0.5d7
|IO!BHost!CUSBTransport 8.0.5d7
|IO!BHost!CTransport 8.0.5d7
>!AHDA!C 283.15
|IOHDA!F 283.15
|IOAudio!F 300.6.1
@vecLib.kext 1.2.0
|IOSlowAdaptiveClocking!F 1.0.0
>!ABacklightExpert 1.1.0
|IONDRVSupport 585.2
>!AThunderboltDPOutAdapter 8.1.4
>!ASMBus!C 1.0.18d1
|IOAccelerator!F2 442.9
@!AGraphicsDeviceControl 6.3.5
|IOGraphics!F 585.2
>X86PlatformPlugin 1.0.0
>IOPlatformPlugin!F 6.0.0d8
>usb.IOUSBHostHIDDevice 1.2
>usb.cdc 5.0.0
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>!AThunderboltDPInAdapter 8.1.4
>!AThunderboltDPAdapter!F 8.1.4
>!AThunderboltPCIDownAdapter 4.1.1
>!ABSDKextStarter 3
|IOSurface 290.8.1
@filesystems.hfs.encodings.kext 1
>!AActuatorDriver 4440.3
>!AHIDKeyboard 224
>!AMultitouchDriver 4440.3
>!AInputDeviceSupport 4400.35
>!AHS!BDriver 4050.1
>IO!BHIDDriver 8.0.5d7
>!AXsanScheme 3
>!AHSSPIHIDDriver 61
|IONVMe!F 2.1.0
>!AThunderboltNHI 7.2.8
|IOThunderbolt!F 9.3.2
|IO80211!F 1200.12.2b1
|IOSkywalk!F 1
>mDNSOffloadUserClient 1.0.1b8
>corecapture 1.0.4
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>!AHSSPISupport 61
>!A!ILpssSpi!C 3.0.60
>!A!ILpssI2C 3.0.60
>!A!ILpssGspi 3.0.60
>!A!ILpssDmac 3.0.60
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
$!AImage4 3.0.0
|IOTimeSync!F 985.2
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 8.0.5d7
|IOReport!F 47
|IO!BPacketLogger 8.0.5d7
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 511.141.1
|IOUSBMass!SDriver 184.140.2
|IOSCSIBlockCommandsDevice 436.140.1
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 436.140.1
>!AMobileFileIntegrity 1.0.5
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.corecrypto 11.1
@kec.Libm 1
Sicuramente è un danno hardware, andrebbe smontato e testato con un altro display, ma avendo già 8 anni non so se ne vale la pena.
Benvenuto intanto france0314, e se vuoi presentarti a tutti puoi farlo qui creando un nuovo topic:
Alberto.G
Il resoconto del kernel panic che hai avuto dice che “Si è verificato un errore irreversibile al disco nvme”.
E’ probabile che questo panic sia proprio in relazione alla caduta del MacBook Pro che ha causato un danno al disco nvme installato.
Parli di un disco nvme, domanda:
è il disco originale di fabbrica, cioè un disco flash PCIe oppure, nel corso degli anni, lo hai sostituito con un nvme?
Comunque sia, come detto, la caduta può aver provocato danni sia al disco che allo schermo e, forse, anche ad altri componenti.
Ritengo che il Mac debba essere ora visionato da un centro di assistenza Apple e sottoposto anche ai test di routine per accertare i danni di caduta.
Attendi comunque altri interventi.
P.S.- vedo ora che hai già ricevuto una risposta.
Torna a “macOS Big Sur 11”
