- Software Expert Gold
Cocktail -
15.0
We would like to inform you that Cocktail 15.0 (Monterey Edition) for users running macOS Monterey has been released.
Here are the release notes for this version:
• Added compatibility with macOS Monterey (12.0)
• Updated Automator actions
• Updated help files
• Many other improvements and enhancements
Download it from https://www.maintain.se/cocktail
Please note that Cocktail (Monterey Edition) requires macOS Monterey 12.0 to run. If you are running macOS Big Sur, please continue to use Cocktail (Big Sur Edition).
Cocktail (Big Sur Edition) for macOS 11.0, Cocktail (Catalina Edition) for macOS 10.15, Cocktail (Mojave Edition) for macOS 10.14 and Cocktail (High Sierra Edition) for macOS 10.13 are available for download from our website.
Cocktail is a general purpose utility for macOS that lets you clean, repair and optimize your Mac. It is a powerful digital toolset that helps hundreds of thousands of Mac users around the world get the most out of their computers every day. The application serves up a perfect mix of maintenance tools and tweaks, all accessible through a clean and easy to use interface.
Cocktail's features are arranged into five categories that helps you manage various aspects of your computer. It also comes with an automatic Pilot mode that allows you to simply press a button and relax, knowing that Cocktail will take care of the rest.
>>> http://www.maintain.se/cocktail/
Cocktail -
15.1
We would like to inform you that Cocktail 15.1 (Monterey Edition) for users running macOS Monterey has been released.
• Added ability to disable screenshot preview thumbnails (Interface - General)
• Fixed a number of bugs discovered in the previous release
• Fixed compatibility issues with Safari 15.1
• Added compatibility with macOS Monterey 12.0.1
Cocktail -
15.2
We would like to inform you that Cocktail 15.2 (Monterey Edition) for users running macOS Monterey has been released.
• Fixed compatibility issues with Adobe Photoshop 23
• Improvements on the "Perform essential system maintenance" procedure
• Added clearing of CVMS and Core symbolication daemon caches
• XPC Helper Agent cache is now forced to be rebuilt - this will fix many of the media plug-in issues
• Addresses an issue in which kernel cache could not be rebuilt, "Can't create kext cache under / - owner not root" error
• Added compatibility with macOS Monterey 12.1
• Resolves a number of other issues discovered in the previous release.
Cocktail -
15.2.1
We would like to inform you that Cocktail 15.2.1 (Monterey Edition) for users running macOS Monterey has been released.
• Addresses authentication issues for users who choose not to add their password to the Keychain
• Addresses minor issues with Full Disk Access
• Addresses an issue in which Cocktail may fail to scan Launch Daemons and Launch Agents
• Addresses an issue in which VoiceOver may stop working after clearing Audio components cache
• Addresses minor compatibility issues with macOS Server
• Improvements on the Uninstall procedure
• Fixed some minor compatibility issues with the first beta of macOS Monterey 12.2
Cocktail -
15.2.2
We would like to inform you that Cocktail 15.2.2 (Monterey Edition) for users running macOS Monterey has been released.
• Improvements on the "Delete local Time Machine snapshots" procedure
• Improvements on the "Clear iOS backups and software updates" procedure
• Improvements on the "Clear Internet caches" procedure
• Fixed minor issues with Safari 15
• Updated Launch Daemons
• Addresses an issue in which Cocktail may display incorrect list of disks in the System > Spotlight tab view
• Addresses an issue in which Cocktail may fail to delete locked items
• Speed improvements on the "Delete localization files" procedure
• Added support for macOS Monterey 12.2.1
• Other miscellaneous improvements and enhancements.
Cocktail -
15.3.1
We would like to inform you that Cocktail 15.3.1 (Monterey Edition) for users running macOS Monterey has been released..
• Addresses an issue in which clearing of the kernel caches may cause kernel panic
• Added compatibility with macOS Monterey 12.4
Cocktail -
15.3.2
We would like to inform you that Cocktail 15.3.2 (Monterey Edition) for users running macOS Monterey has been released..
• Fixed a crash on macOS 13 Ventura Beta when connecting a device in recovery mode
• Update to validate S.M.A.R.T data integrity for S.M.A.R.T check test
• Other minor improvements
• Fixed some compatibility issues with macOS 12.4 Monterey
• Updated Automator actions.
Cocktail -
15.3.4
We would like to inform you that Cocktail 15.3.4 (Monterey Edition) for users running macOS Monterey has been released.
• Addresses an issue in which Cocktail may fail to find corrupted preference files
• Miscellaneous improvements and enhancements
• Added compatibility with macOS Monterey 12.5
Cocktail -
15.3.7
We would like to inform you that Cocktail 15.3.7 (Monterey Edition) for users running macOS Monterey has been released.
• Addresses an issue in which Pilot would not run at the scheduled time
• Improvements on the "Clear Applications caches" procedure
• Fixed an issue when inactive memory was not purged
• Cocktail now clears .tracev3 files when clearing Apple System logs and diagnostic messages
• Addresses compatibility issues with System Integrity Protection
• Various improvements to Pilot
• Interface improvements
Cocktail -
16.1.1
We would like to inform you that Cocktail 16.1.1 (Ventura Edition) for users running macOS Ventura has been released.
• Addresses an issue which Cocktail (Ventura Edition) could launch on macOS Monterey
• Improvements to the "Check for update" procedure
• Fixed compatibility issues with macOS Ventura 13.1
• Improvements on the Pilot
Please note that Cocktail (Ventura Edition) requires macOS Ventura 13.0 to run. If you are running macOS Monterey, please continue to use Cocktail (Monterey Edition).
Cocktail -
16.2
We would like to inform you that Cocktail 16.2 (Ventura Edition) for users running macOS Ventura has been released.
• Added ability to disable all animations in Finder (Interface > Finder)
• Added ability to add small spacers to the Dock (Interface > Dock)
• Added ability to enable Info menu in the login window (Interface > Login)
• Added Display Calibrator to the Utilities menu
• Added compatibility with macOS Ventura 13.2
• Fixed minor compatibility issues with Parallels Desktop 18
• Updated Help files
Cocktail -
16.2.1
We would like to inform you that Cocktail 16.2.1 (Ventura Edition) for users running macOS Ventura has been released..
• Added ability to change Launchpad layout (Interface > Misc)
• Added ability to allow half-star ratings in Music (Interface - Misc)
• Addresses an issue in which Cocktail may unexpectedly quit when running on macOS Ventura 13.2
• Addresses an issue that could cause volumes with HFS+ format not to be offered for specific features of the Disks and System panes
• Addresses an issue where communication with external processes could fail if they have been called in rapid succession
• Addresses an issue where Cocktail could not detect that it was already approved for full disk access
• Improvements on the Check for Updates procedure
Cocktail -
16.2.2
We would like to inform you that Cocktail 16.2.2 (Ventura Edition) for users running macOS Ventura has been released. This is a small but important update, all users should install it before updating to the upcoming Cocktail 16.3 (Ventura Edition) that will be released in February 2023.
• Address an issue in which Cocktail may not work properly on systems that were running macOS Monterey and were (instead of a clean install) upgraded to macOS Ventura
• Resolves a number of compatibility issues with macOS Ventura discovered in the previous release of Cocktail
• Made clean-up of environment variables more reliable
• Added a workaround for a technical issue in macOS which could cause some sandbox-protected applications to revert modified preference settings if they were restarted to soon after changing the setting
• In order to avoid unintentional selection of some options by mouse clicks resulting from window reordering, the empty spaces behind option texts have been made unsensitive to clicks.
Cocktail -
16.3
We would like to inform you that Cocktail 16.3 (Ventura Edition) for users running macOS Ventura has been released.
• Added ability to speed up Time Machine backups by disabling the low priority throttle (System > Time Machine)
• Added ability to reset Software Update (System > Misc)
• Added ability to disable text dragging in applications (Interface > General)
• Added ability to display "Unexpectedly Quit" notices in the Notification Center (Interface > General)
• Fixed a rare issue where Cocktail showed the message “Interrupted operation” instead of the true error message when trying to delete specific files shielded by System Integrity Protection
• Updated Help files.
Cocktail -
16.3.1
We would like to inform you that Cocktail 16.3.1 (Ventura Edition) for users running macOS Ventura has been released.
• The "Perform essential system maintenance" feature has been completely rewritten
• Fixes an issue which could result in unexpected program termination after thinning or deleting Time Machine snapshot
• This version detects additional situations in the operating environment that can cause communication with system services to fail
• Added compatibility with macOS Ventura 13.2.1
