Aggiornamento XLD (X Lossless Decoder)
X Lossless Decoder - 20191004
Fixed a problem that the AAC encoder plugin is not loaded on macOS Catalina
Fixed a problem that external plugins are not loaded on macOS Catalina when they have com.apple.quarantine metadata
Fixed a problem that PREGAP command in a cue sheet is ignored when it appears before the first FILE command
Fixed a problem that sometimes a modifier key is not recognized when opening a folder with drag & drop operation
Added ReplayGain scanning feature to the command-line interface
Added option to specify a character encoding (IANA charset name) of a cue sheet to the command-line interface
Updated FLAC to version 1.3.3
Updated Opus to version 1.3.1
Applied the latest bug & security fixes to LAME encoder.
>>> https://tmkk.undo.jp/xld/index_e.html
X Lossless Decoder - 20201123
This version does not run natively on Apple Silicon, but a test version for ARM64 is available here. XLD will eventually be 4-architecture universal binary.
"Add encoded files to iTunes" now works with Music.app
Switched a default FreeDB server to gnudb.org due to termination of freedb.org
Fixed a problem that caused crash on some FreeDB servers
Updated WavPack to version 5.3.0.
X Lossless Decoder - 20210101
XLD now runs natively on Apple Silicon
Note that external plugins should be updated to use with the ARM64 version.
Updated app icon to fit in with Big Sur style icons (thanks to Finn Davies)
X Lossless Decoder - 20211018
Improved a ripping engine to avoid unnecessary disc spin down/up between tracks on some drives
Fixed a crash on macOS Monterey beta
Fixed a problem that an app icon is not displayed properly on older Mac OS X
Fixed a memory leak when playing a file which doesn't exist on a disk anymore
Fixed a problem that some generated ALAC files are not accepted in other decoders and/or XLD itself
Updated WavPack to version 5.4.0
X Lossless Decoder - 20220910
Fixed a problem that ripping started unexpectedly before unmounting a disc on some drives
Updated FLAC to version 1.4.0
Updated WavPack to version 5.5.0
X Lossless Decoder - 20220917
Fixed a problem when "Overwrite" exiting files and "Delete original file" options were enabled at the same time
Fixed a problem that "no compression" mode on FLAC encoder actually generated compressed files.
X Lossless Decoder - 20230416
• Fixed a problem that automatically add to Music.app option did not work on Apple Silicon Macs
• Fixed a crash when scanning many (>100) files ato once on 64-bit environment
• Fixed an issue that unnecessary delimiter was inserted to year/date field when editing tags
• Fixed an infinite loop when getting cover arts on systems which do not support TLS 1.2
• XLD now do not block user interface when AccurateRip server is not responding
• CLI: added --keep-timestamp switch
• CLI: fixed an issue when giving a relative path on recent systems
• Updated FLAC to version 1.4.2
• Updated WavPack to version 5.6.0
X Lossless Decoder ha scritto: It works on Mac OS X 10.4 and later
Ossia da Mac OS X Tiger in poi...
Compatibile con 15 diverse versioni di macOS!! 😍 Applauso!👏
X Lossless Decoder - 20240310
• Conversion progress is now displayed in Finder icon (or list view)
• Fixed a problem that drive informations (vendor, name and revision) in the log file were shown as (null) on some environments
• Updated Opus to version 1.5.1
• Updated WavPack to version 5.7.0, including multithreaded encoding support
• Updated libsndfile to version 1.2.2
• Various small bug fixes
Torna a “Aggiornamenti”
