- Software Expert Gold
Cocktail -
16.3.2
We would like to inform you that Cocktail 16.3.2 (Ventura Edition) for users running macOS Ventura has been released.
Here are the release notes for this version:
• Fixed some issues with the "Perform essential system maintenance" feature discovered in the previous version
• Fixed a problem where cleaning of the kernel caches failed with an "Invalid arguments" message
• Addresses the "Can't create kext cache under / - owner not root" error
• Improvements on the "Verify boot volume" procedure
• Communication with miscellaneous system services was improved, especially regarding possible error situations, which could result in memory leaks or unexpected program termination
• Resolves a number of other issues discovered in the previous release
Download it from https://www.maintain.se/cocktail
Please note that Cocktail (Ventura Edition) requires macOS Ventura 13.0 to run. If you are running macOS Monterey, please continue to use Cocktail (Monterey Edition).
Cocktail (Big Sur Edition) for macOS 11.0, Cocktail (Catalina Edition) for macOS 10.15, Cocktail (Mojave Edition) for macOS 10.14 and Cocktail (High Sierra Edition) for macOS 10.13 are available for download from our website.
Cocktail is a general purpose utility for macOS that lets you clean, repair and optimize your Mac. It is a powerful digital toolset that helps hundreds of thousands of Mac users around the world get the most out of their computers every day. The application serves up a perfect mix of maintenance tools and tweaks, all accessible through a clean and easy to use interface.
Cocktail's features are arranged into five categories that helps you manage various aspects of your computer. It also comes with an automatic Pilot mode that allows you to simply press a button and relax, knowing that Cocktail will take care of the rest.
>>> http://www.maintain.se/cocktail/
Cocktail -
16.3.3
We would like to inform you that Cocktail 16.3.3 (Ventura Edition) for users running macOS Ventura has been released.
• Addresses an issue in which the application may crash when clearing CVMS and core symbolication daemon caches
• Addresses an issue in which VoiceOver may stop working after clearing Audio components cache
• Fixed an issue where the application displayed the "Interrupted system calls" message
• Fixed a problem where some lines of the Activity Log could be damaged
• The "Perform essential system maintenance" feature and Pilot now prevents sleep mode while running
• Added compatibility with macOS Ventura 13.3
Cocktail -
16.3.4
We would like to inform you that Cocktail 16.3.4 (Ventura Edition) for users running macOS Ventura has been released.
• XPC Helper Agent cache is now forced to be rebuilt even if System Integrity Protection is enabled
• Communication with some components of macOS could sometimes be misinterpreted as alleged hang of the application. To avoid this, some user interface elements have been changed over to asynchronous behavior
• Fixed a problem where the application could quit unexpectedly when communication with an external utility was stopped while that utility was sending data
• Fixed an issue which could result in unexpected program termination after thinning or deleting local Time Machine snapshots
• Improvements on the "Search for corrupted preference files" procedure
• Added compatibility with macOS Ventura 13.3.1
Cocktail -
16.3.6
We would like to inform you that Cocktail 16.3.6 (Ventura Edition) for users running macOS Ventura has been released.
• Addresses an issue in which Cocktail may crash when clearing kernel caches in macOS Ventura
• Improvements on the "Perform essential system maintenance" procedure and Pilot
• Addresses an issue where communication with external processes could fail if they have been called in rapid succession
• Fixed compatibility issues with Parallels Desktop 18
• Improvements on the "Clear System caches" procedure
• Addresses authentication issues for users who choose not to add their password to the Keychain
• Updated Launch Daemons
• Made clean-up of environment variables more reliable
• Updated Automator actions
• Added compatibility with macOS Ventura 13.4.1
