- Software Expert Gold
Cocktail -
13.2.1
Cocktail 13.2.1 (Catalina Edition) for users running macOS Catalina has been released.
Here are the release notes for this version:
• Added ability to generate the checksum value of a file (supported algorithms: CRC32, GOST MAC, MD4, MD5, MD5 SHA1, MD GOST-94, RIPEMD160, SHA-1, SHA-224, SHA-256, SHA-384, SHA-512, Streebog256, Streebog512, Whirlpool). Window menu > Checksums
• Improvements on the "Force empty the Trash" procedure
• Fixed minor compatibility issues with System Integrity Protection
• Resolves a number of other customer reported issues discovered in the previous release
• Updated Help files
Download it from http://cocktail.maintain.se or launch Cocktail and choose "Check for Update" from the Cocktail application menu.
Cocktail is a general purpose utility for macOS that lets you clean, repair and optimize your Mac. It is a powerful digital toolset that helps hundreds of thousands of Mac users around the world get the most out of their computers every day. When unregistered, Cocktail runs in demo mode and will expire after the tenth launch.
>>> http://www.maintain.se/cocktail/
Cocktail -
13.2.2
Cocktail 13.2.2 (Catalina Edition) for users running macOS Catalina has been released.
• Addresses an issue in which Cocktail may disable Safari extensions
• Addresses an issue in which Cocktail may unexpectedly quit while rebuilding XPC helper agent caches
• Fixed a bug in which some items in /private/tmp folder were not deleted during clearing of the temporary files
• Improvements on the "Perform essential system maintenance" procedure
• Improvements on the "Purge inactive memory" procedure
• Added compatibility with macOS Catalina 10.15.5
• Resolves a number of other issues discovered in the previous release
Please note that Cocktail (Mojave Edition) requires macOS Mojave 10.14 to run.
Cocktail (High Sierra Edition) for macOS 10.13 and Cocktail (Sierra Edition) for macOS 10.12 are available for download from our website.
Cocktail -
13.2.3
Cocktail 13.2.3 (Catalina Edition) for users running macOS Catalina has been released.
• Addresses several compatibility issues with macOS Catalina 10.15.5
• Improvements on the maintenance procedures performed by the Pilot feature
• Resolves an issue in which the uninstaller may fail to reset some settings to their default values
• Addresses an issue in which Cocktail may fail to restart Core Audio daemon
• Addresses an issue in which "Shut Down" and "Restart" Automator actions may fail or result in an error
• Fixed compatibility issues with Adobe Creative Cloud
• Overall performance improvements
Cocktail -
13.2.4
Cocktail 13.2.4 (Catalina Edition) for users running macOS Catalina has been released. Here are the release notes for this version:
• Addresses an issue in which some USB peripherals may stop responding after clearing of the system caches
• Addresses an issue in which inserting a USB device may cause a kernel panic after clearing of the kernel caches
• Addresses an issue in which some websites may not have appeared in Safari preferences after clearing of the Internet caches
• Fixed registration issues some users encountered when registering
• Fixed compatibility issues with the latest versions of supported web browsers
• Updated network optimization presets
• Fixed a number of other bugs discovered in the previous version
• Added macOS Catalina 10.15.6 compatibility.
Please note that Cocktail (Catalina Edition) requires macOS Catalina 10.15 to run.
Cocktail (Mojave Edition) for macOS 10.14, Cocktail (High Sierra Edition) for macOS 10.13 and Cocktail (Sierra Edition) for macOS 10.12 are available for download from our website.
Cocktail -
13.2.5
Cocktail 13.2.5 (Catalina Edition) for users running macOS Catalina has been released. Here are the release notes for this version:
• Addresses an issue in which clearing of the user caches may cause Microsoft OneNote to crash
• Addresses an issue in which clearing of the user caches may cause iCloud synchronization to fail
• Addresses compatibility issues with VMware Fusion 11 and Parallels Desktop 16
• Added compatibility with macOS Catalina 10.15.6 Supplemental Update
Cocktail -
14.0
We would like to inform you that Cocktail 14.0 (Big Sur Edition) for users running macOS Big Sur has been released.
• Added compatibility with macOS Big Sur (11.0.1)
• Major speed improvements on the "Delete localization files" procedure
• Improvements on the "Clear System caches" procedure
• Updated Automator actions
• Updated help files
• Many other improvements and enhancements
Download it from http://cocktail.maintain.se.
Please note that Cocktail (Big Sur Edition) requires macOS Big Sur 11.0 to run. If you are running macOS Catalina 10.15, please continue to use Cocktail (Catalina Edition).
Cocktail is a general purpose utility for macOS that lets you clean, repair and optimize your Mac. It is a powerful digital toolset that helps hundreds of thousands of Mac users around the world get the most out of their computers every day. The application serves up a perfect mix of maintenance tools and tweaks, all accessible through a clean and easy to use interface.
Cocktail's features are arranged into five categories that helps you manage various aspects of your computer. It also comes with an automatic Pilot mode that allows you to simply press a button and relax, knowing that Cocktail will take care of the rest.
Cocktail -
14.1
We would like to inform you that Cocktail 14.1 (Big Sur Edition) for users running macOS Big Sur has been released.
• Addresses an issue in which Cocktail may fail to find corrupted preference files
• Addresses an issue in which Cocktail may fail to force empty the Trash
• Improvements on the "Clear User caches" procedure
• Improvements on the "Delete local Time Machine snapshots" procedure
• Various improvements to Pilot
• Major updates to Automator actions
• Added compatibility with macOS Big Sure 11.1.0
• Miscellaneous improvements and enhancements
Watch the introduction video: http://vimeo.com/109816714
Cocktail -
14.2
We would like to inform you that Cocktail 14.2 (Big Sur Edition) for users running macOS Big Sur has been released.
• Added compatibility with M1 Macs
• Addresses an issue in which Cocktail may fail to delete locked items
• Cocktail now clears .tracev3 files when clearing Apple System logs and diagnostic messages
• Improvements on the "Check for Update" procedure
Cocktail -
14.2.1
We would like to inform you that Cocktail 14.2.1 (Big Sur Edition) for users running macOS Big Sur has been released.
• Improvements on the "Search for corrupted preference files" procedure
• Addresses an issue in which demo version may expire after the second launch
• Added compatibility with macOS Big Sur 11.2
• Interface improvements
• Updated Help files.
Download it from >>> http://cocktail.maintain.se.
Cocktail -
14.2.2
We would like to inform you that Cocktail 14.2.2 (Big Sur Edition) for users running macOS Big Sur has been released.
Improvements on the "Clear iOS backups and software updates" procedure
Improvements on the "Clear Internet caches" procedure
Addresses an issue in which Cocktail may fail to install Archives preference pane
Addresses compatibility issues with System Integrity Protection
Added compatibility with macOS Big Sur 11.2.1
Updated Help files
Cocktail -
14.2.3
We would like to inform you that Cocktail 14.2.3 (Big Sur Edition) for users running macOS Big Sur has been released.
Addresses an issue in which "Check for Update" feature may fail to establish secure connection
Addresses an issue in which Cocktail may display incorrect list of disks in the System Spotlight and System Trash tab views
Addresses an issue in which Cocktail may fail to delete DS Store files in the subfolders
Addresses few compatibility issues with M1 Macs
Updated Launch Daemons (Malwarebytes is no longer reporting these files as suspicious)
Added macOS 11.3 compatibility.
Cocktail -
14.3
We would like to inform you that Cocktail 14.3 (Big Sur Edition) for users running macOS Big Sur has been released. Here are the release notes for this version:
• Added ability to disable tab previews on hover in Safari (by default, in Safari 14 hovering mouse pointer over a non-active browser tab shows an image preview of the tab's content). Interface > Misc
• Added ability to disable DNS prefetching in Safari which can cause a number of issues, such as partially-loaded pages or a "webpage cannot be found" message. Interface > Misc
• Added ability to hide or show items (files, folders, applications, etc.). Files > Misc
• Added instructions how to grant Full Disk Access to Cocktail
• Improvements on the "Clear system caches" procedure. Cocktail is now able to clear hibernate (sleepimage) file and virtual memory swap files even if System Integrity Protection is enabled.
• Improvements on the "Clear user caches" procedure. Cocktail is now able to clear Spotlight caches, iOS backups and temporary files (including files in the /private/tmp directory) even if System Integrity Protection is enabled.
• Improvements on the "Clear applications caches" procedure. Addresses an issue in which Cocktail may fail to clear some caches.
• Cocktail is now able to rebuild Mail's envelope index even if System Integrity Protection is enabled
• Fixed minor issues with Safari 14.1
• Addresses an issue in which some Accessibility settings may be restored to their default values
• Added macOS 11.2.3 compatibility
Download it from >>> http://cocktail.maintain.se. or launch Cocktail and choose "Check for Update" from the Cocktail application menu.
Cocktail (Catalina Edition) for macOS 10.15, Cocktail (Mojave Edition) for macOS 10.14, Cocktail (High Sierra Edition) for macOS 10.13 and Cocktail (Sierra Edition) for macOS 10.12 are available for download from our website.
Cocktail -
14.3.1
We would like to inform you that Cocktail 14.3.1 (Big Sur Edition) for users running macOS Big Sur has been released. Here are the release notes for this version:
• Fixed a critical bug in which Cocktail may cause kernel panic on macOS 11.3
• Added ability to enable Debug menu in Safari, the Debug menu provides advanced settings and features for Safari (Interface > Misc)
• Improvements on the "Verify boot volume" procedure
• Addresses minor compatibility issues with Microsoft Office 365
Watch the introduction video >>> http://vimeo.com/109816714
Alberto.G
- Pro-Expert
Cocktail - 14.3.2 (Big Sur Edition)
Desideriamo informarti che è stato rilasciato Cocktail 14.3.2 (Big Sur Edition) per gli utenti che eseguono macOS Big Sur. Ecco le note di rilascio per questa versione:
• Miglioramenti alla procedura "Esegui la manutenzione essenziale del sistema"
• Cocktail ora cancella i file .tracev3 quando si cancellano i registri di sistema Apple e i messaggi diagnostici
• Miglioramenti alla procedura "Cancella backup iOS e aggiornamenti software"
• Risolve problemi di compatibilità con System Integrity Protection
• Cocktail è ora in grado di ricostruire l'indice della busta di Mail anche se è abilitata la protezione dell'integrità del sistema
• Aggiunta compatibilità con macOS Big Sur 11.5
• Risolve una serie di altri problemi scoperti nella versione precedente
Scaricalo da >>> http://cocktail.maintain.se. oppure avvia Cocktail e scegli "Verifica aggiornamenti" dal menu dell'applicazione Cocktail.
Tieni presente che Cocktail (Big Sur Edition) richiede macOS Big Sur 11.0 per funzionare. Se stai utilizzando macOS Catalina 10.15, continua a utilizzare Cocktail (Edizione Catalina).
Cocktail (Edizione Catalina) per macOS 10.15, Cocktail (Edizione Mojave) per macOS 10.14, Cocktail (Edizione High Sierra) per macOS 10.13 e Cocktail (Edizione Sierra) per macOS 10.12 sono disponibili per il download dal nostro sito web.
Cocktail è un'utilità generale per macOS che ti consente di pulire, riparare e ottimizzare il tuo Mac. È un potente set di strumenti digitali che aiuta ogni giorno centinaia di migliaia di utenti Mac in tutto il mondo a ottenere il massimo dai propri computer. L'applicazione offre un mix perfetto di strumenti di manutenzione e modifiche, tutti accessibili tramite un'interfaccia pulita e facile da usare.
Le funzionalità di Cocktail sono organizzate in cinque categorie che ti aiutano a gestire vari aspetti del tuo computer. Inoltre è dotato di una modalità Pilot automatico che ti consente di premere semplicemente un pulsante e rilassarti, sapendo che Cocktail si prenderà cura del resto.
Guarda il video introduttivo >>> http://vimeo.com/109816714
Cocktail -
14.3.3
We would like to inform you that Cocktail 14.3.3 (Big Sur Edition) for users running macOS Big Sur has been released. Here are the release notes for this version:
• Addresses minor compatibility issues with macOS 10.6
