Kernel Panic all'apertura dello schermo
Giobatta
Buongiorno,
dopo un lungo periodo di "quiete" stamani il Mac (MacBook Pro 16" i9 2,3 GHz, 32 GB) si è svegliato all'apertura dello schermo con un Kernel Panic. A ciel sereno.
Vi posto le prime righe sperando bastino a smorfiarne la natura:
{"caused_by":"macos","macos_version":"Mac OS X 10.15.7 (19H114)","os_version":"Bridge OS 5.1 (18P3030)","macos_system_state":"running","incident_id":"7B315F1F-E654-44F1-9E42-AAFF04B75D9E","timestamp":"2021-01-13 08:58:36.00 +0000","bug_type":"210"}
  "build" : "Bridge OS 5.1 (18P3030)",
  "product" : "iBridge2,14",
  "kernel" : "Darwin Kernel Version 20.2.0: Fri Nov 13 19:36:30 PST 2020; root:xnu-7195.60.74~2\/RELEASE_ARM64_T8010",
  "incident" : "7B315F1F-E654-44F1-9E42-AAFF04B75D9E",
  "crashReporterKey" : "c0dec0dec0dec0dec0dec0dec0dec0dec0de0001",
  "date" : "2021-01-13 08:58:36.77 +0000",
  "panicString" : "panic(cpu 0 caller 0xfffffff00d3cb61c): x86 CPU CATERR detected\nDebugger message: panic\nMemory ID: 0x6\nOS release type: User\nOS version: 18P3030\nmacOS version: 19H114\nKernel version: Darwin Kernel Version 20.2.0: Fri Nov 13 19:36:30 PST 2020; root:xnu-7195.60.74~2\/RELEASE_ARM64_T8010\nKernel UUID: 8A8DE90C-FE50-3637-BEA1-D78B0D41128E\niBoot version: iBoot-6723.61.3\nsecure boot?: YES\nx86 EFI Boot State: 0xd\nx86 System State: 0x0\nx86 Power State: 0x0\nx86 Shutdown Cause: 0x5\nx86 Previous Power Transitions: 0x10001000100\nPCIeUp link state: 0x89473614\nPaniclog version: 13\nKernel slide:      0x0000000005494000\nKernel text base:  0xfffffff00c498000\nmach_absolute_time: 0x1bf44204f3c\nEpoch Time:        sec       usec\n  Boot    : 0x5ff18bad 0x0005fb19\n  Sleep   : 0x5ffea4a5 0x00048e95\n  Wake    : 0x5ffeb5f8 0x0001c8ea\n  Calendar: 0x5ffeb622 0x000c8411\n\nPanicked task 0xffffffe19b3d36d8: 3481 pages, 223 threads: pid 0: kernel_task\nPanicked thread: 0xffffffe19b504000, backtrace: 0xffffffe801b4b710, tid: 441\n\t\t  lr: 0xfffffff00cbc43fc  fp: 0xffffffe801b4b750\n\t\t  lr: 0xfffffff00cbc4258  fp: 0xffffffe801b4b7c0\n\t\t  lr: 0xfffffff00ccead5c  fp: 0xffffffe801b4b890\n\t\t  lr: 0xfffffff00d1d95fc  fp: 0xffffffe801b4b8a0\n\t\t  lr: 0xfffffff00cbc3f8c  fp: 0xffffffe801b4bc20\n\t\t  lr: 0xfffffff00cbc3f8c  fp: 0xffffffe801b4bc80\n\t\t  lr: 0xfffffff00dbb6b34  fp: 0xffffffe801b4bca0\n\t\t  lr: 0xfffffff00d3cb61c  fp: 0xffffffe801b4bcd0\n\t\t  lr: 0xfffffff00d3b9d70  fp: 0xffffffe801b4bd30\n\t\t  lr: 0xfffffff00d3bbcb0  fp: 0xffffffe801b4bdc0\n\t\t  lr: 0xfffffff00d3b9418  fp: 0xffffffe801b4be50\n\t\t  lr: 0xfffffff00d2a94e0  fp: 0xffffffe801b4be80\n\t\t  lr: 0xfffffff00d1356cc  fp: 0xffffffe801b4bec0\n\t\t  lr: 0xfffffff00d134f4c  fp: 0xffffffe801b4bf00\n\t\t  lr: 0xfffffff00d1e45a0  fp: 0x0000000000000000\n\n",
  "panicFlags" : "0x902",
  "otherString" : "\n** Stackshot Succeeded ** Bytes Traced 41218 (Uncompressed 124016) **\n",
  "macOSPanicFlags" : "0x0",
  "macOSPanicString" : "BAD MAGIC! (flag set in iBoot panic header), no macOS panic log available",
  "memoryStatus" : {"compressorSize":0,"compressions":0,"decompressions":0,"busyBufferCount":0,"pageSize":16384,"memoryPressure":false,"memoryPages":{"active":7880,"throttled":0,"fileBacked":10128,"wired":5690,"purgeable":37,"inactive":6151,"free":8940,"speculative":1730}},
  "processByPid" : {
    "0" :
Una rapida ricerca mi ha restituito alcune segnalazioni che ipotizzano danni hardware anche se, fino a ieri sera, ho manipolato video impegnando seriamente la macchina e senza alcun problema...
Avete qualche idea della possibile causa?
Vi ringrazio per il tempo e la pazienza.
Giovanni
PowerBook 2005 15" 1,67 GHz, MacPro 2006 3 GHz, Mac Mini 2011 2,5 GHz, iMac 27" 2013 3,5 GHz, MacBook Pro 16" 2,3 GHz 2019
Alberto.G
Non so se la tua ricerca coincide con la mia; sul web ho trovato diversi link che hanno a che fare con il tuo KP.
Per la mia ricerca ho utilizzato come indice questo "panicString" : "panic(cpu 0 caller 0xfffffff00d3cb61c): x86 CPU CATERR detected\nDebugger message: panic\nMemory ID: 0x6\nOS release type: User\nOS version: 18P3030\nmacOS version: 19H114
e mi sono soffermato su due:
https://discussions.apple.com/thread/251755817
https://forums.macrumors.com/threads/20 ... 6/page-134
e poi anche questo "macOSPanicString" : "BAD MAGIC! (flag set in iBoot panic header), no macOS panic log available"
ed ho scelto questi:
https://discussions.apple.com/thread/250826263
https://forums.macrumors.com/threads/ma ... h.2216640/
Sono discussioni prese dai forum; prova a vedere se qualcuno ha risolto…
Giobatta
Scusa per il ritardo col quale ti rispondo.
Dai link che hai postato ho visto che per molti si trattava di kernel panic ripetuti. Nel mio caso è stato solo uno.
In realtà non ho gli strumenti per capire di cosa si tratti ma probabilmente (facendo debiti scongiuri) è stato un caso isolato.
Desideravo capire cosa diavolo significasse quanto riportato e se dovevo preoccuparmi.
Ti ringrazio per la cortesia e la disponibilità.
Giovanni
Alberto.G
Giobatta, ti auguro fortemente che il tuo kernel panic sia proprio un caso isolato.
Leggendo quei post ho rilevato che molti utenti avevano macchine nuove o nuovissime.
Sarebbe utile, anche per il Forum, sapere l’anno del tuo MBP 16” o quando lo hai acquistato.
Questo, quantomeno per circoscrivere le caratteristiche dei Mac rispetto alla frequenza ed al tipo di “panic” segnalati nei forum.
A volte, un piccolo dettaglio può risultare utile a capire le modalità con qui avvengono i KP.
Giobatta ha scritto:
gio, 14 gen 2021 16:44
Magari fossimo ingegneri elettronici o informatici alle dipendenze di mamma Apple!
Giobatta
Alberto.G ha scritto:
gio, 14 gen 2021 18:19
Hai ragione.
E' un MacBook Pro 16" del 2019, 2,3 GHz Intel Core i9, RAM 32 GB, scheda grafica AMD Radeon Pro 5500M 8 GB.
Grazie di nuovo.🤞
Giovanni
