Lo posto io per te
Sleep Wake failure in EFI
Failure code:: 0xffffffff 0x0000001f
Please IGNORE the below stackshot
Date/Time: 2020-10-22 16:52:54 +0200
OS Version: ??? ??? (Build ???)
Architecture: x86_64
Report Version: 29
Data Source: Stackshots
Shared Cache: 0xc04b000 222B0115-65DB-3977-B6E4-DCBB55F6DA95
Event: Sleep Wake Failure
Duration: 0.00s
Steps: 1
Time Awake Since Boot: 12s
Process: swd [296]
Footprint: 408 KB
Start time: 2020-10-22 16:52:54 +0200
End time: 2020-10-22 16:52:54 +0200
Num samples: 1 (1)
Thread 0x759 1 sample (1) priority 4 (base 4)
<thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
1 start + 1 (libdyld.dylib + 109769) [0x7fff73070cc9] 1
1 ??? [0x107ed3454] 1
1 ??? [0x107ed31dd] 1
1 __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 135862) [0x7fff731d22b6] 1
*1 ??? [0xffffff80002c1206] 1
*1 ??? [0xffffff8000984be7] 1
*1 ??? [0xffffff800089d771] 1
*1 ??? [0xffffff80002e49e7] (running) 1
Binary Images:
0x7fff73056000 - 0x7fff7308cfff libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff731b1000 - 0x7fff731ddfff libsystem_kernel.dylib (6153.141.2) <A576A1CF-7726-3146-B04B-A26E1CDB9757> /usr/lib/system/libsystem_kernel.dylib
Model: MacBookAir7,2, BootROM 195.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 1,6 GHz, 4 GB, SMC 2.27f2
Graphics: kHW_IntelHDGraphics6000Item, Intel HD Graphics 6000, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A54424C41522D4E5444
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A54424C41522D4E5444
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1615.2)
Bluetooth: Version 7.0.6f7, 3 services, 18 devices, 1 incoming serial ports
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 27.2
