Google Drive; Dropbox; OneDrive; iCloud; WOW Space; Mega; ecc… Il cloud storage è un modello di conservazione dati su computer in rete dove i dati stessi sono memorizzati su molteplici server virtuali generalmente ospitati presso strutture di terze parti o su server dedicati.
fomo89
- Apprendista Maccanico
edit by admin [era: Aiuto! messaggio terminale]
ciao a tutti, sto provando a disabilitare all'avvio del Mac adobe creative cloud, in internet ho trovato una guida che dice di inserire nel terminale questa dicitura,
launchctl scarico -w /Library/LaunchAgents/com.adobe.AdobeCreativeCloud.plist
inserendola e premendo invio mi da questo messaggio. Qualcuno sa dirmi se ho fatto qualche danno o non è nulla ? Grazie in anticipo.
Last login: Sat Mar 3 08:38:51 on console
MBP-di-Fabio:~ fabio$ launchctl scarico -w /Library/LaunchAgents/com.adobe.AdobeCreativeCloud.plist
Unrecognized subcommand: scarico
Usage: launchctl <subcommand> ... | help [subcommand]
Many subcommands take a target specifier that refers to a domain or service
within that domain. The available specifier forms are:
system/[service-name]
Targets the system-wide domain or service within. Root privileges are required
to make modifications.
user/<uid>/[service-name]
Targets the user domain or service within. A process running as the target user
may make modifications. Root may modify any user's domain. User domains do not
exist on iOS.
gui/<uid>/[service-name]
Targets the GUI domain or service within. Each GUI domain is associated with a
user domain, and a process running as the owner of that user domain may make
modifications. Root may modify any GUI domain. GUI domains do not exist on iOS.
session/<asid>/[service-name]
Targets a session domain or service within. A process running within the target
security audit session may make modifications. Root may modify any session
domain.
pid/<pid>/[service-name]
Targets a process domain or service within. Only the process which owns the
domain may modify it. Even root may not do so.
When using a legacy subcommand which manipulates a domain, the target domain is
inferred from the current execution context. When run as root (whether it is
via a root shell or sudo(1)), the target domain is assumed to be the
system-wide domain. When run from a normal user's shell, the target is assumed
to be the per-user domain for that current user.
Subcommands:
bootstrap Bootstraps a domain or a service into a domain.
bootout Tears down a domain or removes a service from a domain.
enable Enables an existing service.
disable Disables an existing service.
uncache Removes the specified service name from the service cache.
kickstart Forces an existing service to start.
attach Attach the system's debugger to a service.
debug Configures the next invocation of a service for debugging.
kill Sends a signal to the service instance.
blame Prints the reason a service is running.
print Prints a description of a domain or service.
print-cache Prints information about the service cache.
print-disabled Prints which services are disabled.
plist Prints a property list embedded in a binary (targets the Info.plist by default).
procinfo Prints port information about a process.
hostinfo Prints port information about the host.
resolveport Resolves a port name from a process to an endpoint in launchd.
limit Reads or modifies launchd's resource limits.
runstats Prints performance statistics for a service.
examine Runs the specified analysis tool against launchd in a non-reentrant manner.
config Modifies persistent configuration parameters for launchd domains.
dumpstate Dumps launchd state to stdout.
dumpjpcategory Dumps the jetsam properties category for all services.
reboot Initiates a system reboot of the specified type.
bootshell Brings the system up from single-user mode with a console shell.
load Bootstraps a service or directory of services.
unload Unloads a service or directory of services.
remove Unloads the specified service name.
list Lists information about services.
start Starts the specified service.
stop Stops the specified service if it is running.
setenv Sets the specified environment variables for all services within the domain.
unsetenv Unsets the specified environment variables for all services within the domain.
getenv Gets the value of an environment variable from within launchd.
bsexec Execute a program in another process' bootstrap context.
asuser Execute a program in the bootstrap context of a given user.
submit Submit a basic job from the command line.
managerpid Prints the PID of the launchd controlling the session.
manageruid Prints the UID of the current launchd session.
managername Prints the name of the current launchd session.
error Prints a description of an error.
variant Prints the launchd variant.
version Prints the launchd version.
help Prints the usage for a given subcommand.
- Pestifero
Premesso che sarebbe meglio chiedere prima di fare modifiche fidandosi del primo che scrive,
che problemi ti da ora il computer?
albertocchio
- Type Expert
l'avvio automatico si disattiva dall'applicazione stessa. nulla più.
fomo89
mattleega ha scritto:Premesso che sarebbe meglio chiedere prima di fare modifiche fidandosi del primo che scrive,
il computer al momento nn mi da nessun problema , il punto è che adobe creative cloud continua ad avviarsi al riavvio del computer e quindi nn capisco cosa è il messaggio che mi è venuto fuori.
albertocchio
- Type Expert
ma ve le andate a cercare apposta?
bastava togliere quella dannata spunta nelle preferenze
- Pestifero
Se il computer non ha problemi, è successo nulla.
Adobe è il peggior generatore di virus.
Non è possibile che per installare una applicazione, si debbano impestare quasi tutte le cartelle con qualche porcheria.
Andrebbero boicottati.
Attendi fiducioso, prima o poi qualcuno ti fornirà la soluzione.
Credo sia un file nella libreria (nascosta) app support/adobe... da cestinare.
Vuoi disabilitare all'avvio del Mac l'Adobe Creative Cloud?
E mica serve il Terminale!?
Esegui il login
Aggiorna all'ultima versione
E disabilita l'avvio automatico
fomo89
grazie , l'unica cosa che vorrei capire è se il messaggio che è uscito dal terminale non è nulla o magari ho fatto qualcosa che potrebbe rovinare il sistema.
Vai tranquillo, il sito (schifoso) dal quale hai preso le informazioni (sbagliate) non si è curato nemmeno di verificare la traduzione automatica che ha coinvolto il comando da Terminale.
L'originale è
launchctl unload -w /Library/LaunchAgents/com.adobe.AdobeCreativeCloud.plist, mentre quello che hai incollato tu è NULLO.
fomo89
fragrua ha scritto:Vai tranquillo, il sito (schifoso) dal quale hai preso le informazioni (sbagliate) non si è curato nemmeno di verificare la traduzione automatica che ha coinvolto il comando da Terminale.
L'originale è
ah ok grazie mille, quindi in poche parole il messaggio del terminale voleva dire che è un comando che nn trova e che quindi nn ha fatto nessuna modifica nel sistema?
Esattamente. Nessuna modifica al tuo Mac.
PS: Mi correggo, il sito straniero (rumeno) tradotto in automatico.
fomo89
fragrua ha scritto:Esattamente. Nessuna modifica al tuo Mac.
ah menomale ho avuto un momento di terrore e ho pensato di dover inizializzare il Mac , grazie mille per avermi dato la conferma che nulla è stato modificato .
albertocchio
- Type Expert
ah ok… c'era un modo giusto di rispondere…
albertocchio ha scritto:ah ok… c'era un modo giusto di rispondere…
Il tuo modo era perfetto, però avevo già preparato la mia risposta (lentamente perché stavo aggiornando l'app con hotspot 3G) e solo dopo aver inviato mi sono accorto dei precedenti commenti!
E mi dispiaceva buttare la mia.
albertocchio
- Type Expert
