Pop up your computer is low on memory
Infatti.
Il link l'ho dato io, forse ho il link sbagliato.
Non ce l'ho più su DropBox.
Comunque aspetto risposta
faxus ha scritto:
mer, 22 gen 2020 21:14
Infatti.
Ok. Comunque il link l'aveva dato Kernel Panic ed era quello alla versione giusta, la 3.4.7
Kernel Panic ha scritto:
dom, 19 gen 2020 17:45
Fai un test con la vecchia versione di Etrecheck >>> http://www.imaccanici.org/apps/EtreCheck.zip
Pacotom, per favore, collabora...
pacotom
faxus ha scritto:
mer, 22 gen 2020 21:51
scusate, ma alle 21 viene la badante a mettermi a letto, ecco l'ultimo report
EtreCheck version: 3.4.7 (461)
Report generated 2020-01-23 09:44:20
Runtime: 3:29
Performance: Good
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Click the [Clean up] link to delete unused files.
Problem: Computer is restarting
Hardware Information: ⓘ
iMac (Retina 5K, 27-inch, 2019)
iMac - model: iMac19,1
1 3 GHz Intel Core i5 (i5-8500) CPU: 6-core
64 GB RAM Upgradeable - [Instructions]
BANK 0/ChannelA-DIMM0
16 GB DDR4 2667 MHz ok
BANK 1/ChannelA-DIMM1
BANK 2/ChannelB-DIMM0
BANK 3/ChannelB-DIMM1
Handoff/Airdrop2: supported
Wireless: en1: Unknown
iCloud Quota: 4.81 GB available
iCloud Status: One pending file
Video Information: ⓘ
Radeon Pro 570X - VRAM: 4 GB
iMac
Disk Information: ⓘ
TS256GSSD230S disk1: (256,06 GB) (Solid State - TRIM: No)
[Show SMART report]
EFI (disk1s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
(disk1s2) <not mounted> [APFS Container]: 255.85 GB
APPLE SSD SM0032L disk0: (28 GB) (Solid State - TRIM: Yes)
(disk0s1) <not mounted> [EFI]: 315 MB
(disk0s2) <not mounted> [APFS Container]: 27.55 GB
USB Information: ⓘ
USB31Bus
Generic 4-Port USB 3.0 Hub
Seagate M3 Portable
M3 Portable disk4: (2 TB)
SEAGATE 2 T (disk4s1 - Journaled HFS+) /Volumes/SEAGATE 2 T : 2.00 TB (610.81 GB free)
TOSHIBA External USB 3.0
External USB 3.0 disk5: (4 TB)
EFI (disk5s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
TOSHIBA 4 T (disk5s2 - Journaled HFS+) /Volumes/TOSHIBA 4 T : 4.00 TB (2.71 TB free)
Elgato EyeTV Diversity
Generic 4-Port USB 2.0 Hub
Sennheiser Communications Sennheiser USB headset
Apple Inc. Magic Keyboard
Logitech USB Optical Mouse
USB31Bus
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk2s1 - APFS) / [Startup]: 255.85 GB (120.50 GB free)
Physical disk: disk1s2 255.85 GB (120.50 GB free)
(disk2s2) <not mounted> [Preboot]: 255.85 GB
(disk2s3) <not mounted> [Recovery]: 255.85 GB
(disk2s4) /private/var/vm [VM]: 255.85 GB
System Software: ⓘ
macOS 10.14.6 (18G2022) - Time since boot: about one hour
Configuration files: ⓘ
System Integrity Protection status: enabled (Custom Configuration)
Gatekeeper: ⓘ
Possible adware: ⓘ
Unknown file: ~/Library/LaunchAgents/com.LaterAgent.silhouette.plist
~/Library/Application Support/.nfcd/seld
Unknown file: ~/Library/LaunchAgents/com.nuendo.plist
~/Library/Application Support/.max/mixxx
Unknown file: ~/Library/LaunchAgents/com.reason.plist
~/Library/Application Support/.reaper/sibelius
3 possible adware files found. [Remove/Report]
Clean up: ⓘ
/Library/LaunchAgents/com.microsoft.OneDriveStandaloneUpdater.plist
/Applications/OneDrive.app/Contents/StandaloneUpdater.app/Contents/MacOS/OneDriveStandaloneUpdater
Executable not found!
/Library/LaunchDaemons/com.microsoft.OneDriveStandaloneUpdaterDaemon.plist
/Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon
/Library/LaunchDaemons/com.microsoft.OneDriveUpdaterDaemon.plist
/Applications/OneDrive.app/Contents/OneDriveUpdaterDaemon.xpc/Contents/MacOS/OneDriveUpdaterDaemon
/Library/LaunchDaemons/jp.co.canon.MasterInstaller.plist
/Library/PrivilegedHelperTools/jp.co.canon.MasterInstaller
~/Library/LaunchAgents/com.nchsoftware.videopadit.schedule.CacheDeleteAll.plist
/Volumes/VideoPad/VideoPad.app/Contents/MacOS/VideoPad -scheduled_launch -bgtask delcache
5 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Applications/Wondershare Video Converter Ultimate.app
[not loaded] com.Perfect.Driver.SystemAudioRecorder (1.1.0 - SDK 10.6) [Lookup]
/Library/Application Support/Roxio
[not loaded] com.roxio.TDIXController (1.6) [Lookup]
/Library/Application Support/VirtualBox
[loaded] org.virtualbox.kext.VBoxDrv (6.0.10) [Lookup]
[loaded] org.virtualbox.kext.VBoxNetAdp (6.0.10) [Lookup]
[loaded] org.virtualbox.kext.VBoxNetFlt (6.0.10) [Lookup]
[loaded] org.virtualbox.kext.VBoxUSB (6.0.10) [Lookup]
/System/Library/Extensions
[not loaded] com.elgato.driver.DontMatchAfaTech (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergy450 (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergyXS (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchEmpia (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchVoyager (1.1) [Lookup]
[not loaded] org.defyne.driver.ConexantCX2388X (0.2) [Lookup]
[not loaded] org.defyne.driver.MMInputFamily (0.6.0) [Lookup]
[not loaded] org.defyne.driver.PhilipsSAA7146 (0.5.5) [Lookup]
[not loaded] org.defyne.driver.PrincipalMMInputs (0.7.4) [Lookup]
[not loaded] org.defyne.driver.TypicalDVBFrontends (0.7.4) [Lookup]
[not loaded] org.defyne.driver.UDMUtils (0.1.0) [Lookup]
/Users/[redacted]/Apowersoft/Mac Online Launcher/Mac Online Launcher.app
[loaded] com.Apowersoft.driver.AudioDevice (1.6.7 - SDK 10.11) [Lookup]
[not loaded] com.Cycling74.driver.Soundflower (1.0.0 - SDK 10.8) [Lookup]
Startup Items: ⓘ
udmarket: Path: /Library/StartupItems/udmarket
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[not loaded] 9 Apple tasks
[loaded] 179 Apple tasks
[running] 112 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 36 Apple tasks
[loaded] 177 Apple tasks
[running] 120 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 ba46f95b - installed 2018-04-29) [Lookup]
[loaded] com.adobe.ElementsAutoCreator-18.0.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[running] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[not loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[failed] com.microsoft.OneDriveStandaloneUpdater.plist (? b97e8726 0 - installed 2019-12-07) [Lookup] - /Applications/OneDrive.app/Contents/StandaloneUpdater.app/Contents/MacOS/OneDriveStandaloneUpdater: Executable not found!
[loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2019-12-07) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.acc.installer.v2.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[loaded] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2020-01-13) [Lookup]
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2019-12-04)
[loaded] com.binarynights.ForkLiftHelper.plist (BinaryNights LLC - installed 2018-04-28) [Lookup]
[running] com.bombich.ccchelper.plist (Bombich Software, Inc. - installed 2019-12-07) [Lookup]
[running] com.crystalidea.macsfancontrol.smcwrite.plist (Ilya Parniuk - installed 2019-12-27) [Lookup]
[running] com.memeo.WDMemeod.plist (? d0fcb9dc 2b12012e - installed 2009-09-30) [Lookup]
[failed] com.microsoft.OneDriveStandaloneUpdaterDaemon.plist (? 1a4f628 0 - installed 2020-01-14) [Lookup] - /Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon: Executable not found!
[loaded] com.microsoft.OneDriveUpdaterDaemon.plist (? a510a00 0 - installed 2019-12-07) [Lookup] - /Applications/OneDrive.app/Contents/OneDriveUpdaterDaemon.xpc/Contents/MacOS/OneDriveUpdaterDaemon: Executable not found!
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2019-12-07) [Lookup]
[loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2019-11-11) [Lookup]
[loaded] jp.co.canon.MasterInstaller.plist (? d0637166 0 - installed 2020-01-10) [Lookup] - /Library/PrivilegedHelperTools/jp.co.canon.MasterInstaller: Executable not found!
[not loaded] org.virtualbox.startup.plist (Shell Script 700b9385 - installed 2019-10-01) [Lookup]
User Launch Agents: ⓘ
[running] com.LaterAgent.silhouette.plist (? 69136dce 10be6241 - installed 2020-01-13) [Lookup]
[loaded] com.adobe.AAM.Updater-1.0.plist (? 6a3cceca ba46f95b - installed 2018-04-29) [Lookup]
[loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-01-19) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2019-12-07) [Lookup]
[loaded] com.google.keystone.xpcservice.plist (Google, Inc. - installed 2019-12-07) [Lookup]
[loaded] com.nchsoftware.videopadit.schedule.CacheDeleteAll.plist (? 3dbd1ae 0 - installed 2020-01-14) [Lookup] - /Volumes/VideoPad/VideoPad.app/Contents/MacOS/VideoPad: Executable not found!
[running] com.nuendo.plist (? fc47c0ee 3064553d - installed 2019-10-28) [Lookup]
[loaded] com.reason.plist (? fee43be2 b128766c - installed 2019-10-28) [Lookup]
[not loaded] org.virtualbox.vboxwebsrv.plist (Oracle America, Inc. - installed 2019-10-01) [Lookup]
User Login Items: ⓘ
EyeTV Helper Applicazione
(/Library/Application Support/EyeTV/EyeTV Helper.app)
SilentStartHelper SMLoginItem - Hidden (Apple, Inc. - installed 2019-10-15)
(/Applications/Silent Start.app/Contents/Library/LoginItems/SilentStartHelper.app)
ForkLiftMini SMLoginItem - Hidden (BinaryNights LLC - installed 2018-04-28)
(/Applications/ForkLift.app/Contents/Library/LoginItems/ForkLiftMini.app)
ForkLiftMini SMLoginItem - Hidden (BinaryNights LLC - installed 2019-11-28)
(/Volumes/TOSHIBA 4 T/Install Mac/Programmi/ForkLift/ForkLift 2.app/Contents/Library/LoginItems/ForkLiftMini.app)
(/Volumes/SEAGATE 2 T/Install Mac/Programmi/ForkLift/ForkLift 2.app/Contents/Library/LoginItems/ForkLiftMini.app)
CanonIJExtendedSurveyLaunchAgent SMLoginItem - Hidden (Canon Inc. - installed 2020-01-10)
(/Applications/Canon Utilities/Inkjet Extended Survey Program/Inkjet Extended Survey Program.app/Contents/MacOS/ESPController.app/Contents/Library/LoginItems/CanonIJExtendedSurveyLaunchAgent.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 32.0.0.321 (installed 2020-01-21) [Lookup]
Flash Player: 32.0.0.321 (installed 2020-01-21) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2020-01-21)
PepperFlashPlayer: 32.0.0.321 (installed 2020-01-21) [Lookup]
EPPEX Plugin: 10.0 (installed 2018-09-20) [Lookup]
Safari Extensions: ⓘ
[enabled] Open in Internet Explorer - Parallels - http://www.parallels.com (installed 2018-04-28)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2020-01-13) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 255.85 GB Disk used: 135.35 GB
Destinations:
SAMSUNG 1 T [Local]
Total size: 999.85 GB
Total number of backups: 35
Oldest backup: 19/10/2019, 11:05
Last backup: 23/01/2020, 09:13
Size of backup disk: Excellent
Backup size 999.85 GB > (Disk size 255.85 GB X 3)
Top Processes by CPU: ⓘ
6% Console
3% Google Chrome Helper (Renderer)
3% diagnosticd
3% Google Chrome
2% com.apple.SpeechRecognitionCore.speechrecognitiond
Top Processes by Memory: ⓘ
721 MB com.apple.SpeechRecognitionCore.speechrecognitiond
573 MB Google Chrome
384 MB Microsoft Word
351 MB Microsoft Excel
295 MB mds_stores
Input Output Process name
6 MB 1 KB systemmigrationd
157 KB 127 KB mDNSResponder
23 KB 6 KB netbiosd
16 KB 7 KB AddressBookSourceSync
5 KB 8 KB apsd
99.72 iconservicesagent
53.98 diagnosticd
42.88 Console
38.26 systemmigrationd
34.28 System Information
Virtual Memory Information: ⓘ
49.71 GB Available RAM
44.51 GB Free RAM
14.29 GB Used RAM
5.20 GB Cached files
0 B Swap Used
ApolloOne: 2.4.1 (installed 2020-01-07)
Speedtest: 1.9 (installed 2020-01-09)
Inkjet Extended Survey Program: (null) (installed 2020-01-10)
Driver della stampante Canon IJ: (null) (installed 2020-01-10)
Canon IJScanner16f: (null) (installed 2020-01-10)
Canon IJ Scan Utility2: (null) (installed 2020-01-10)
Canon IJ Scan Utility Lite: (null) (installed 2020-01-10)
UserRegistration: (null) (installed 2020-01-10)
Manuale a video: (null) (installed 2020-01-10)
My Image Garden V364: (null) (installed 2020-01-10)
Quick Menu: (null) (installed 2020-01-10)
Adobe Flash Player: (null) (installed 2020-01-14)
Adobe Pepper Flash Player: (null) (installed 2020-01-14)
Paint S: 5.7.8 (installed 2020-01-17)
Adobe Flash Player: (null) (installed 2020-01-21)
Adobe Pepper Flash Player: (null) (installed 2020-01-21)
Speedtest: 1.10 (installed 2020-01-23)
2020-01-22 18:46:47 Microsoft Word.app High CPU use [Open] [Details]
2020-01-22 15:19:19 backupd High CPU use [Open] [Details]
2020-01-20 14:08:46 ReportCrash Crash [Open]
Cause: dyld3 mode
Analyzing process: EtreCheckPro[3590], path: ???; parent process: [1], path: /sbin/launchd
2020-01-20 13:57:17 DetectX Swift.app Crash [Open]
Cause: *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'NSWindow drag regions should only be invalidated on the Main Thread!'
terminating with uncaught exception of type NSException
abort() called
2020-01-18 20:18:44 Kernel Panic [Open] [Details]
3rd Party Kernel Extensions:
org.virtualbox.kext.VBoxUSB 6.0.10
org.virtualbox.kext.VBoxNetAdp 6.0.10
org.virtualbox.kext.VBoxNetFlt 6.0.10
org.virtualbox.kext.VBoxDrv 6.0.10
com.Apowersoft.driver.AudioDevice 1.6.7
iMac 20 2007 4 GB SL
iMac 27 late 2019 SSD 64 GB Catalina
pacotom
faxus ha scritto:
mer, 22 gen 2020 20:06
Dovrebbe riportare le ultime installazioni.
In ogni caso:
Compare del malware generalmente associato a finti Flash Player, Mackeeper e anche a download da siti warez.
E la finestra di popup in questione è generato solo da questa situazione.
Oltre a questo c'è del disordine e delle cose incoerenti.
Altre che appartengono a cose vecchie, obsolete.
È grave che non possiamo analizzare con DetectX.
Quanto spazio libero hai sul disco 1?
(vedi su informazioni su questo Mac - Archiviazione)
Ti dovrei consigliare di inizializzare il disco.
Installare Catalina da chiavetta.
E curare un'attenta installazione de software.
Eliminando almeno qualcosa.
Per prima cosa installare DetectX e vedere se va...
spazio libero sul disco 1: 136 gb
vorrei fare installazione pulita di mojave, con catalina dovrei ricomprare 4 licenze
va bene questa procedura? https://support.apple.com/it-it/HT201372
DetectX continua a crashare
Process: DetectX Swift [2520]
Path: /Applications/DetectX Swift.app/Contents/MacOS/DetectX Swift
Identifier: com.sqwarq.DetectX-Swift
Version: 1.093 (1.093)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: DetectX Swift [2520]
User ID: 501
Date/Time: 2020-01-23 09:57:16.416 +0100
OS Version: Mac OS X 10.14.6 (18G2022)
Report Version: 12
Anonymous UUID: 3808376F-5015-F06B-BD87-3F977ABF9617
Sì, vengono confermati i sospetti peggiori.
Il malware c'è, ormai radicato.
Quello che emerge è la parte visibile da EtreCheck, ma significa che c'è dell'altro.
Senza DetectX o una connessione diretta sarebbe impossibile trovarlo e disattivarlo.
In più emerge la spiegazione dei crash e dei kernel panic.
Librerie danneggiate e installazioni incongrue o malfatte.
Al momento mi sembra sia solo un problema software.
Oltre a quanto già detto su applicazioni vecchie, malassortite, male installate o corrotte.
Non tantissimo, poca roba ma va ad aggiungersi al resto.
Inutile dilungarsi, ne trarrei queste conclusioni:
Conviene in assoluto installare Catalina.
Perché comunque devi reinstallare da zero.
A causa del malware, delle librerie corrotte e delle disfunzioni di varia origine del software.
E per verificare che non ci siano problemi hardware.
Quindi, a mio parere procedi
pacotom ha scritto:
gio, 23 gen 2020 09:59
... vorrei fare installazione pulita di mojave, con catalina dovrei ricomprare 4 licenze...
Ne sei proprio sicuro?
In genere non lo è, al massimo in qualche caso si tratta di pagare il solo upgrade.
Semmai segnalaci le licenze e verifichiamo
... va bene questa procedura? https://support.apple.com/it-it/HT201372...
Sì, è quella.
In più nei tutorial del Forum trovi anche la procedura passo passo
Il problema che resta è che operi in modo un po' anomalo.
Hai un buon Mac, sinceramente molto sbilanciato.
Una quantità di ram che neanche in uno studio audiovisivo...
Una memoria di massa forse asfittica anche per un portatile.
Hai una poco funzionale gestione del software.
Andrebbe maturata e perfezionata.
Capisco le tue difficoltà, vissute in prima persona a lungo e con residui irrisolti.
Al momento di selezionare il software e irrobustire le difese, manda un mp, poi vediamo
pacotom
Ho inizializzato journaled una pendrive da 128, ho scaricato mojave dall’applestore, ma solo l’aggiornamento, non l’intero os poi, seguendo il tuo consiglio, ho scaricato anche Catalina.
Però, prima di aggiornare, devo verificare se le 4 licenze che ho cioè forklift, Carbon Copy cloner, EYE TV e Wondershare filmora hanno già le versioni a 64-bit, per cui adesso farei un installazione pulita di mojave, riservandomi di aggiornare in seguito.
Intanto Catalina, appena scaricato, si vuole installare subito, ovviamente esco dal programma di installazione.
Come installo mojave da zero? cmd + R e scelgo fra le opzioni o devo creare la chiavetta? Grazie
mi spiace
pacotom ha scritto:
gio, 23 gen 2020 14:03
Da zero indica che devi inizializzare l'intero disco.
Quindi devi operare dall'esterno, con una chiavetta, in entrambe i casi.
Fai quelle verifiche della validità del software anche per Catalina.
Anche se mi sembra che sia valido.
Va bene Carbon Copy Cloner ed anche EyeTv.
Non so a cosa ti serva Forklift e come funzioni.
Ho avuto l'impressione, senza però aver approfondito o provato, che potesse essere coinvolto nei tuoi problemi.
Invece del software Wondershare ne sono certo.
È assolutamente inadeguato a macOS, malfatto, invadente, pesante, causa di problemi più volte visti.
Praticamente non disinstallabile e probabilmente spione
Se devi installare da zero questa versione non basterà, e devi fare la chiavetta apposta con il sistema di installazione
pacotom
faxus ha scritto:
gio, 23 gen 2020 14:12
OK, come la creo la chiavetta con mojave?
è un file manager due finestre, come i vecchi win commander e norton commander dos, li uso dal 95
ok, lo elimino
EYE TV
EveTV 3 NON funziona con Catalina.
EyeTV 4 sì.
EyeTv 4 è uscito a dicembre e va ricomprato ex-novo, senza possibilità di sconti.
pacotom ha scritto:
gio, 23 gen 2020 15:59
... come la creo la chiavetta con mojave?...
Sta nel link che tu stesso hai postato.
Comunque ripetuto e semplificato dalla risposta che vedo di Kernel Panic
...[Forklift] è un file manager...
Visto e informato...
Appare un buon software.
In effetti il Finder di sistema, per quanto migliorato lascia ancora insoddisfatti.
Soprattutto nelle funzioni, che ci sono, ma macchinose o complesse
Paolofast ha scritto:
gio, 23 gen 2020 17:27
... EyeTv 4 è uscito a dicembre e va ricomprato ex-novo, senza possibilità di sconti.
Belli str...afottenti.
Arrivano fino al 2020 con un attrezzo (quasi preistorico) a 32 bit.
Poi finalmente lo portano a 64 bit (che se non si sbrigano siamo già passati ai 128).
E ovviamente te lo fanno pagare ex novo.
Vabbè tanto il ragionamento è sempre quello.
Se questi si sono già fatti prendere per le caviglie e scuotere bene da Apple che si è presa i bigliettoni...
Non faranno poi tanto caso a noi che ci prendiamo gli spicci rimasti a terra
pacotom
gio, 23 gen 2020 16:23
..... OK, come la creo la chiavetta con mojave?
Fatto stamattina, mi chiede di scaricare mojave dall’applestore, ma mi da solo l’ultimo l’aggiornamento non ho una copia dell’os, nelle applicazioni trovo installa macos mojave 22,8 mb e installa macos catalina 8,19 gb, quindi os completo
Oppure con l'ausilio di una app come questa >>> https://diskmakerx.com
Scaricato e avviato, spunta
ed è Scomparsa la pendrive da finder, da forklift e da utility disco.
Ho riavviato, ma non si vede più
ma se installo catalina da preferenze-aggiornamento, sovrascrive lasciando la monnezza o installa da zero?
Torna a “macOS Mojave 10.14”
