Riavvio con schermata mutilingue con indicazione generica di problema
smacmac
Nell'ultima settimana si è verificato questo problema già due volte.
All'uscita dallo stop si riavvia con la suddetta schermata e poi procede normalmente.
L'iMac è il primo in firma
Se qualcuno esperto può chiarirmi il problema questo è il resoconto:
Anonymous UUID: 7391D0FB-F657-27C4-71C6-EDF6EFF1A468
Fri Jul 28 13:30:57 2023
*** Panic Report ***
panic(cpu 1 caller 0xffffff8018d8687f): Kernel trap at 0xffffff7f9bd3d460, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0x0000000000000000, CR3: 0x000000041343b000, CR4: 0x00000000000026e0
RAX: 0x0000000000000000, RBX: 0x0000000000000000, RCX: 0xffffff8201c2b900, RDX: 0xffffff8201c2b926
RSP: 0xffffff8201c2b890, RBP: 0xffffff8201c2b950, RSI: 0xffffff8201c2b7be, RDI: 0x0000000000000001
R8: 0x0000000000000000, R9: 0xffffff80194a3948, R10: 0x000000000000053a, R11: 0x000000000000001c
R12: 0x0000000000000001, R13: 0x0000000000000000, R14: 0x0000000000000000, R15: 0xffffff806323de00
RFL: 0x0000000000010297, RIP: 0xffffff7f9bd3d460, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000000, Error code: 0x0000000000000000, Fault CPU: 0x1, PL: 0, VF: 0
Backtrace (CPU 1), Frame : Return Address
0xffffff8201c2b360 : 0xffffff8018c6ae76
0xffffff8201c2b3b0 : 0xffffff8018d94484
0xffffff8201c2b3f0 : 0xffffff8018d86654
0xffffff8201c2b460 : 0xffffff8018c1ce60
0xffffff8201c2b480 : 0xffffff8018c6a8ec
0xffffff8201c2b5b0 : 0xffffff8018c6a6ac
0xffffff8201c2b610 : 0xffffff8018d8687f
0xffffff8201c2b780 : 0xffffff8018c1ce60
0xffffff8201c2b7a0 : 0xffffff7f9bd3d460
0xffffff8201c2b950 : 0xffffff7f9bd49669
0xffffff8201c2b9b0 : 0xffffff7f9bd6e2e9
0xffffff8201c2ba60 : 0xffffff7f9bd6de74
0xffffff8201c2baa0 : 0xffffff8018ecdf14
0xffffff8201c2baf0 : 0xffffff8018e9918b
0xffffff8201c2bb30 : 0xffffff8018e84be9
0xffffff8201c2bb90 : 0xffffff8018e98e28
0xffffff8201c2bc10 : 0xffffff8018e98656
0xffffff8201c2bc50 : 0xffffff8018e9c92f
0xffffff8201c2bcc0 : 0xffffff8018ea7825
0xffffff8201c2bd60 : 0xffffff8018ea73c4
0xffffff8201c2bf40 : 0xffffff8019202818
0xffffff8201c2bfa0 : 0xffffff8018c1d646
Kernel Extensions in backtrace:
com.apple.filesystems.hfs.kext(407.50.6)[09445723-F283-31E5-B409-43D905BA81C6]@0xffffff7f9bd2c000->0xffffff7f9bd92fff
dependency: com.apple.filesystems.hfs.encodings.kext(1)[F737F125-223E-3B67-B4FF-5AB56291D4FE]@0xffffff7f99c83000
BSD process name corresponding to current thread: umount
Mac OS version:
17G14042
Kernel version:
Darwin Kernel Version 17.7.0: Fri Oct 30 13:34:27 PDT 2020; root:xnu-4570.71.82.8~1/RELEASE_X86_64
Kernel UUID: 5E83A13A-32F5-3604-8591-50E2F2F70DC6
Kernel slide: 0x0000000018a00000
Kernel text base: 0xffffff8018c00000
__HIB text base: 0xffffff8018b00000
System model name: iMac10,1 (Mac-F2268CC8)
System uptime in nanoseconds: 8023012707450
last loaded kext at 2868992296243: com.apple.driver.AppleXsanScheme 3 (addr 0xffffff7f9c0d7000, size 32768)
last unloaded kext at 3049039932269: com.apple.driver.usb.cdc 5.0.0 (addr 0xffffff7f9c0bb000, size 28672)
loaded kexts:
at.obdev.nke.LittleSnitch 5474
com.apple.filesystems.afpfs 11.1
com.apple.nke.asp-tcp 8.0.2
com.apple.driver.AppleBluetoothMultitouch 92
com.apple.driver.AudioAUUC 1.70
com.apple.driver.AGPM 110.23.37
com.apple.filesystems.autofs 3.0
com.apple.driver.AppleMikeyHIDDriver 131
com.apple.driver.AppleMikeyDriver 281.52
com.apple.driver.AppleHDA 281.52
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.driver.AppleUpstreamUserClient 3.6.5
com.apple.AGDCPluginDisplayMetrics 3.20.18
com.apple.kext.AMDLegacyFramebuffer 1.6.8
com.apple.driver.AppleHV 1
com.apple.iokit.IOUserEthernet 1.0.1
com.apple.iokit.IOBluetoothSerialManager 6.0.7f22
com.apple.driver.pmtelemetry 1
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AppleIntelSlowAdaptiveClocking 4.0.0
com.apple.driver.AppleOSXWatchdog 1
com.apple.driver.AppleLPC 3.1
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.driver.AppleBacklight 170.12.6
com.apple.driver.AppleMCCSControl 1.5.5
com.apple.ATIRadeonX2000 10.0.4
com.apple.kext.AMD4600Controller 1.6.8
com.apple.driver.AppleIRController 353
com.apple.driver.AppleUSBCardReader 439.70.3
com.apple.filesystems.hfs.kext 407.50.6
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.BootCache 40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0
com.apple.AppleSystemPolicy 1.0
com.apple.iokit.SCSITaskUserClient 404.30.3
com.apple.filesystems.apfs 748.51.0
com.apple.driver.AppleFWOHCI 5.5.9
com.apple.driver.AppleAHCIPort 329.50.2
com.apple.nvenet 2.0.22
com.apple.driver.AirPort.Atheros40 700.74.5
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleACPIButtons 6.1
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleACPIEC 6.1
com.apple.driver.AppleAPIC 1.7
com.apple.driver.AppleIntelCPUPowerManagementClient 220.50.1
com.apple.nke.applicationfirewall 186
com.apple.security.TMSafetyNet 8
com.apple.security.quarantine 3
com.apple.driver.AppleIntelCPUPowerManagement 220.50.1
com.apple.security.SecureRemotePassword 1.0
com.apple.driver.IOBluetoothHIDDriver 6.0.7f22
com.apple.driver.AppleMultitouchDriver 1614.1
com.apple.driver.AppleInputDeviceSupport 1614.13
com.apple.kext.triggers 1.0
com.apple.driver.DspFuncLib 281.52
com.apple.kext.OSvKernDSPLib 526
com.apple.driver.AppleSMBusPCI 1.0.14d1
com.apple.iokit.IOAVBFamily 683.1
com.apple.plugin.IOgPTPPlugin 680.15
com.apple.iokit.IOEthernetAVBController 1.1.0
com.apple.driver.AppleSSE 1.0
com.apple.iokit.IOSurface 211.15
com.apple.iokit.IOSerialFamily 11
com.apple.AppleGPUWrangler 3.20.18
com.apple.iokit.IOSlowAdaptiveClockingFamily 1.0.0
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.IOPlatformPluginFamily 6.0.0d8
com.apple.driver.AppleBacklightExpert 1.1.0
com.apple.driver.AppleSMBusController 1.0.18d1
com.apple.driver.AppleHDAController 281.52
com.apple.iokit.IOHDAFamily 281.52
com.apple.iokit.IOAudioFamily 206.5
com.apple.vecLib.kext 1.2.0
com.apple.iokit.IONDRVSupport 519.21
com.apple.iokit.IOFireWireIP 2.2.9
com.apple.AppleGraphicsDeviceControl 3.20.18
com.apple.kext.AMDLegacySupport 1.6.8
com.apple.iokit.IOGraphicsFamily 519.23
com.apple.driver.AppleHIDKeyboard 205.1
com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 6.0.7f22
com.apple.iokit.IOBluetoothHostControllerUSBTransport 6.0.7f22
com.apple.iokit.IOBluetoothHostControllerTransport 6.0.7f22
com.apple.iokit.IOBluetoothFamily 6.0.7f22
com.apple.driver.usb.IOUSBHostHIDDevice 1.2
com.apple.driver.usb.networking 5.0.0
com.apple.driver.usb.AppleUSBHostCompositeDevice 1.2
com.apple.driver.usb.AppleUSBHub 1.2
com.apple.filesystems.hfs.encodings.kext 1
com.apple.iokit.IOSCSIMultimediaCommandsDevice 404.30.3
com.apple.iokit.IOBDStorageFamily 1.8
com.apple.iokit.IODVDStorageFamily 1.8
com.apple.iokit.IOCDStorageFamily 1.8
com.apple.iokit.IOAHCISerialATAPI 267.50.1
com.apple.iokit.IOAHCIBlockStorage 301.40.2
com.apple.iokit.IOFireWireFamily 4.7.2
com.apple.iokit.IOAHCIFamily 288
com.apple.iokit.IO80211Family 1200.12.2
com.apple.driver.corecapture 1.0.4
com.apple.driver.usb.AppleUSBEHCIPCI 1.2
com.apple.driver.usb.AppleUSBOHCIPCI 1.2
com.apple.driver.usb.AppleUSBOHCI 1.2
com.apple.driver.usb.AppleUSBEHCI 1.2
com.apple.driver.NVSMU 2.2.9
com.apple.driver.AppleEFINVRAM 2.1
com.apple.driver.usb.AppleUSBHostPacketFilter 1.0
com.apple.iokit.IOUSBFamily 900.4.1
com.apple.driver.AppleUSBHostMergeProperties 1.2
com.apple.driver.AppleEFIRuntime 2.1
com.apple.iokit.IOSMBusFamily 1.1
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.security.sandbox 300.0
com.apple.kext.AppleMatch 1.0.0d1
com.apple.driver.DiskImages 480.60.3
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleEffaceableStorage 1.0
com.apple.driver.AppleKeyStore 2
com.apple.driver.AppleUSBTDM 439.70.3
com.apple.driver.AppleMobileFileIntegrity 1.0.5
com.apple.iokit.IOUSBMassStorageDriver 140.70.2
com.apple.iokit.IOSCSIBlockCommandsDevice 404.30.3
com.apple.iokit.IOSCSIArchitectureModelFamily 404.30.3
com.apple.iokit.IOStorageFamily 2.1
com.apple.driver.AppleCredentialManager 1.0
com.apple.driver.KernelRelayHost 1
com.apple.iokit.IOUSBHostFamily 1.2
com.apple.driver.usb.AppleUSBCommon 1.0
com.apple.driver.AppleBusPowerController 1.0
com.apple.driver.AppleSEPManager 1.0.1
com.apple.driver.IOSlaveProcessor 1
com.apple.iokit.IOReportFamily 31
com.apple.iokit.IOTimeSyncFamily 680.15
com.apple.iokit.IONetworkingFamily 3.4
com.apple.driver.AppleACPIPlatform 6.1
com.apple.driver.AppleSMC 3.1.9
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.pthread 1
com.apple.kec.Libm 1
com.apple.kec.corecrypto 1.0
EOF
Model: iMac10,1, BootROM 215.0.0.0.0, 2 processors, Intel Core 2 Duo, 3,06 GHz, 16 GB, SMC 1.52f9
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E433136464B44
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E433136464B44
Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E433136464B44
Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E433136464B44
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.74.0-P2P
Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Crucial_CT1050MX300SSD1, 1,05 TB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: USB Bus
USB Device: IR Receiver
USB Device: MFC-250C
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 2.0 Bus
USB Device: Internal Memory Card Reader
USB Device: Built-in iSight
USB Device: Keyboard Hub
USB Device: Apple Keyboard
Thunderbolt Bus:
Grazie in anticipo
iMac 21.5" Late 2009 - 3 GHz Intel Core 2 Duo - 16Gb RAM - SSD Crucial MX300 1Tb HSierra
iMac 21.5" Retina 4K - 3,6 GHz Intel Core i7 - 16Gb RAM - SSD 500Gb Ventura
MacBook Air Late 2008 Core 2 Duo 1.6 13" 2 GB RAM 120 GB SATA Snow Leopard
Alberto.G
Probabilmente hai un guasto hardware.
I kernel panic sono prevalentemente causati da estensioni del kernel di terze parti o guasti hardware.
Hai di recente installato delle estensioni del kernel di terze parti?
Se sì, potresti segnalarcelo?
Inoltre, il riferimento che ti dà il panic : Kernel trap at 0xffffff7f9bd3d460, type 14=page fault è, quasi sicuramente, dovuto ad un errore di pagina che è correlato alla memoria, quindi potrebbe essere la RAM.
La Apple Diagnostics può essere utilizzata per controllare la RAM.
Link
https://support-apple-com.translate.goo ... x_tr_hl=it
Il ripristino della NVRAM può risolvere anche alcune cause di panico.
Link https://support.apple.com/it-it/HT204063
Se per caso hai un hardware esterno collegato al Mac, questo potrebbe anche causare il panico.
Se hai qualcosa di diverso da tastiera o mouse o stampante collegato, prova a disconnetterlo e verifica se il kernel panic si ripresenta.
smacmac
Non ho installato nulla di nuovo almeno da un anno, ne estensioni del kernel di terze parti.
Sono collegati solo tastiera con filo, magic mouse e stampante, oltre alla Time Machine via ethernet.
Sono riuscito a fare solo il ripristino della NVRAM, invece la Apple Diagnostics non c'è stato verso di avviarla, il tasto D all'avvio non funziona, dopo un tempo più lungo del normale, compare la mela e la barra di avvio e poi prosegue normalmente.
Adesso funziona bene se dovesse ripresentarsi il problema mi rifarò vivo.
Grazie e buona notte.
