Safari ed App Store non funzionano
Amede90
Ho appena installato MacOs Sierra 10.12.6 e Safari e App Store hanno smesso di collegarsi ad internet mentre Chrome e Mail lo fanno tranquillamente. Qual è il problema? E cosa devo fare per risolverlo? Grazie in anticipo
Ciao e benvenuto nel Forum, Amede90.
Saremo in tanti a salutarti.
Prova ad avviare tenendo il tasto ⇧ abbassato.
Verifica se Safari e AppStore funzionano.
Poi riavvia normalmente e prova di nuovo.
Se continuassero a non funzionare scarica, installa e posta il resoconto di un EtreCheck:
Amede90
Ecco il resoconto
EtreCheck version: 3.4.6 (460)
Report generated 2017-10-10 14:43:39
Runtime: 7:01
Performance: Below Average
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Click the [Clean up] link to delete unused files.
Problem: Other problem
Description:
Safari and App Store do not connect to internet
Hardware Information: ⓘ
13" MacBook Air (Mid 2012)
MacBook Air - model: MacBookAir5,2
1 1,8 GHz Intel Core i5 (i5-3427U) CPU: 2-core
4 GB RAM Not upgradeable
BANK 0/DIMM0
2 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en0: 802.11 a/b/g/n
Battery: Health = Check Battery - Cycle count = 849
Proxy: ProxyAutoConfig
Proxy: ProxyAutoDiscovery
Video Information: ⓘ
Intel HD Graphics 4000 - VRAM: 1536 MB
Color LCD 1440 x 900
Disk Information: ⓘ
APPLE SSD TS128E disk0: (121,33 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [CoreStorage Container]: 120.47 GB
Recovery HD (disk0s3 - Journaled HFS+) /Volumes/Recovery HD [Recovery]: 650 MB (86 MB free)
USB Information: ⓘ
USB20Bus
hub_device
USB20Bus
hub_device
hub_device
Apple Card Reader
Apple Inc. BRCM20702 Hub
USB30Bus
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk1 - Journaled HFS+) / [Startup]: 120.10 GB (52.91 GB free)
Physical disk: disk0s2 120.47 GB Online
System Software: ⓘ
macOS Sierra 10.12.6 (16G29) - Time since boot: less than an hour
Gatekeeper: ⓘ
Possible adware: ⓘ
Adware: /Library/LaunchAgents/com.MacUpdater.agent.plist
Adware: ~/Library/LaunchAgents/com.Hot-Shoppy.agent.plist
Adware: ~/Library/LaunchAgents/com.macalive.protect.update.plist
Adware: ~/Library/LaunchAgents/com.pcv.hlpramcn.plist
4 possible adware files found. [Remove/Report]
Clean up: ⓘ
/Applications/MacUpdater/MacUpdater -guid 41826763959677239 -source pic-1628
Executable not found!
~/Library/LaunchAgents/com.infocert.dike.plist
/Applications/Dike.app/Contents/MacOS/Dike -o NO_SHELL -f NO_MAIN_WIN
~/Library/LaunchAgents/com.jdibackup.ZipCloud.autostart.plist
open /Applications/ZipCloud.app/Contents/Resources/Utility.app -n --args 9 -l
~/Library/LaunchAgents/com.jdibackup.ZipCloud.backupstart.plist
open /Applications/ZipCloud.app/Contents/Resources/Utility.app -n --args 8 -b
~/Library/LaunchAgents/com.jdibackup.ZipCloud.notify.plist
open /Applications/ZipCloud.app/Contents/Resources/Utility.app --args 7 1
5 orphan files found. [Clean up]
System Launch Agents: ⓘ
[not loaded] 6 Apple tasks
[loaded] 177 Apple tasks
[running] 63 Apple tasks
[killed] 36 Apple tasks
36 processes killed due to insufficient RAM
System Launch Daemons: ⓘ
[not loaded] 41 Apple tasks
[running] 72 Apple tasks
[killed] 28 Apple tasks
28 processes killed due to insufficient RAM
Launch Agents: ⓘ
[not loaded] com.MacUpdater.agent.plist (? c0cafe79 0 - installed 2016-07-16) Adware! [Remove/Report]
[loaded] com.oracle.java.Java-Updater.plist (? 80e0657f be93c7fb - installed 2017-01-20) [Lookup]
Launch Daemons: ⓘ
[loaded] com.BlueStacks.AppPlayer.bstservice_helper.plist (BlueStack Systems, Inc. - installed 2015-09-11) [Lookup]
[loaded] com.adobe.fpsaud.plist (? 2afb3af7 bb6105db - installed 2016-10-26) [Lookup]
[loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e afb3bef0 - installed 2010-08-25) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2016-12-13) [Lookup]
[loaded] com.safervpn.HelperTool.plist (Safer Social Ltd. - installed 2017-03-04) [Lookup]
[running] me.hide.osxhelper.plist (EVENTURE LTD. - installed 2017-03-04) [Lookup]
User Launch Agents: ⓘ
[not loaded] com.Hot-Shoppy.agent.plist (? d1aee693 ? - installed 2017-05-23) Adware! [Remove/Report]
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2017-09-27) [Lookup]
[loaded] com.facebook.videochat.[redacted].plist (Apple, Inc. - installed 2016-10-24)
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-07-10) [Lookup]
[failed] com.infocert.dike.plist (? 95e070bd 0 - installed 2017-05-16) [Lookup] - /Applications/Dike.app/Contents/MacOS/Dike: Executable not found!
[failed] com.jdibackup.ZipCloud.autostart.plist (? ec9f6e08 0 - installed 2016-07-16) [Lookup] - /Applications/ZipCloud.app/Contents/Resources/Utility.app: Executable not found!
[loaded] com.jdibackup.ZipCloud.backupstart.plist (? 4d1e88d1 0 - installed 2016-07-16) [Lookup] - /Applications/ZipCloud.app/Contents/Resources/Utility.app: Executable not found!
[loaded] com.jdibackup.ZipCloud.notify.plist (? e34fb907 0 - installed 2016-07-16) [Lookup] - /Applications/ZipCloud.app/Contents/Resources/Utility.app: Executable not found!
[running] com.macalive.protect.update.plist (Anat Guttmann Chohen - installed 2017-10-10) Adware! [Remove/Report]
~/Library/Application Support/macalive/macalive.app/Contents/MacOS/Installer
[running] com.pcv.hlpramcn.plist (Techyutils Software Private Limited - installed 2017-08-10) Adware! [Remove/Report]
~/Library/Application Support/amc/helperamc.app/Contents/MacOS/helperamc
[running] com.spotify.webhelper.plist (Spotify - installed 2017-10-10) [Lookup]
User Login Items: ⓘ
iTunesHelper Application (Apple, Inc. - installed 2017-10-03)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Dropbox Application
(/Applications/Dropbox.app)
Spotify Application
(/Applications/Spotify.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 23.0.0.207 (installed 2016-11-19) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-10-03)
Flash Player: 23.0.0.207 (installed 2016-11-19) Cannot contact Adobe
JavaAppletPlugin: Java 8 Update 121 build 13 (installed 2017-01-20) Check version
SharePointBrowserPlugin: 14.0.0 (installed 2016-03-12) [Lookup]
User internet Plug-ins: ⓘ
WebEx64: 1.1.0 (installed 2017-01-30) [Lookup]
3rd Party Preference Panes: ⓘ
Flash Player (installed 2016-10-26) [Lookup]
Java (installed 2017-01-20) [Lookup]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
42% softwareupdated
7% WindowServer
3% kernel_task
0% Dropbox
0% fontd
Top Processes by Memory: ⓘ
586 MB kernel_task
309 MB softwareupdated
96 MB Google Chrome
90 MB Google Chrome Helper
80 MB soagent
Input Output Process name
75 KB 125 KB Dropbox
11 KB 27 KB apsd
26 KB 5 KB mDNSResponder
522 B 354 B netbiosd
384 B 384 B ntpd
8.12 WindowServer
0.68 Google Chrome Helper
0.32 Dropbox
0.14 launchd
Virtual Memory Information: ⓘ
976 MB Available RAM
200 MB Free RAM
3.05 GB Used RAM
776 MB Cached files
517 MB Swap Used
2017-10-08 21:18:05 configd High CPU use [Open] [Details]
Non mi hi detto se avviando in modalità provvisoria (tasto ⇧ abbassato) il problema persiste...
Comunque, hai un sacco di disinstallazioni malfatte che hanno lasciato residui.
Hai del fastidioso adware, collezionato in navigazione.
Hai del software che non funzione e altro che è da aggiornare.
Prima di capire cosa è crea conflitto impedendo alle applicazioni integrate di collegarsi alla rete, bisogna sistemare.
Poi vedremo, se persiste, di trovare il motivo del blocco, che al momento sembra essere più di uno.
Anche perché con la tua scarsa dotazione di ram, rispetto alle aspettative di Sierra, basta poco per soffrire di problemi.
Esegui:
- eliminazione dell'adware
- eliminazione dei residui di cattiva disinstallazione
Clicca sulle azioni qui sotto evidenziate, e dovunque altro le trovi, per eliminarli
Dopo di che scarica EasyFind e cerca tutti gli altri file che potrebbero essere collegati
http://www.devontechnologies.com/products/freeware/" onclick="window.open(this.href);return false;
- Elimina il pannello Flash dalle Preferenze di Sistema.
https://helpx.adobe.com/it/flash-player ... ac-os.html" onclick="window.open(this.href);return false;
Nel caso tu voglia reinstallarlo, scaricalo nuovamente
- Aggiorna Java
- Elimina il plugin WebEX64 dalla tua libreria utente in Internet Plug-ins, se ti serve lo reinstallerai aggiornato
- Elimina BlueStack, se ti serve lo reinstallerai aggiornato
https://bluestacks.zendesk.com/hc/en-us ... -Mac-OS-X-" onclick="window.open(this.href);return false;
- Elimina me Hide, se ti serve lo reinstallerai aggiornato
- Fatto tutto questo scarica OnyX
http://www.titanium.free.fr/onyx.html" onclick="window.open(this.href);return false;
Ed esegui SOLO questo
Poi riavvia il sistema.
Fatto tutto, ma proprio tutto, controlla il funzionamento.
Se il problema persiste prova a riavviare col tasto ⇧ abbassato e ricontrolla.
Se ancora non va posta un nuovo EtreCheck
Torna a “macOS Sierra 10.12”
