Direi di averlo eliminato, l'ho cercato con Easy Find, ma mi sembra non ci sia. Ti allego poche righe sotto il check con Etrecheck fatto pochi minuti, ma prima devo durti che ho problemi ad andare avanti nella Console, mi dici: poi aggiungi Poi aggiungi, cercando su Console:
~/Library/Logs/DiagnosticReports/quicklookd_2016-11-07-083020_***.crash
~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2016-11-06-182819_***.crash
devo incollare nel cerca una riga alla volta -Library etc ?????
EtreCheck version: 3.1.2 (334)
Report generated 2016-11-08 17:32:37
Download EtreCheck from
https://etrecheck.com" onclick="window.open(this.href);return false;
Runtime 16:03
Performance: Poor
Problem: Apps are crashing
Hardware Information: ⓘ
iMac (27-inch, Late 2012)
iMac - model: iMac13,2
1 2,9 GHz Intel Core i5 (i5-3470S) CPU: 4-core
8 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
Empty
BANK 1/DIMM1
Empty
Bluetooth: Good - Handoff/Airdrop2 supported
Wireless: en1: 802.11 a/b/g/n
Video Information: ⓘ
NVIDIA GeForce GTX 660M - VRAM: 512 MB
iMac 2560 x 1440
System Software: ⓘ
macOS Sierra 10.12.1 (16B2657) - Time since boot: about 2 hours
Disk Information: ⓘ
APPLE HDD WDC WD10EALX-408EA0 disk0 : (1 TB) (Rotational)
[Show SMART report]
Macintosh HD (disk0s2) / [Startup]: 999.35 GB (150.39 GB free)
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
TOSHIBA External USB 3.0
Apple Inc. MacBook Air SuperDrive
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Configuration files: ⓘ
/etc/hosts - Count: 15
Gatekeeper: ⓘ
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.elgato.driver.DontMatchAfaTech (1.1 - 2016-11-07) [Support]
[not loaded] com.elgato.driver.DontMatchCinergy450 (1.1 - 2016-11-07) [Support]
[not loaded] com.elgato.driver.DontMatchCinergyXS (1.1 - 2016-11-07) [Support]
[not loaded] com.elgato.driver.DontMatchEmpia (1.1 - 2016-11-07) [Support]
[not loaded] com.elgato.driver.DontMatchVoyager (1.1 - 2016-11-07) [Support]
[not loaded] com.eltima.ElmediaPlayer.kext (1.0 - SDK 10.4 - 2016-11-07) [Support]
System Launch Agents: ⓘ
[not loaded] 7 Apple tasks
[loaded] 172 Apple tasks
[running] 100 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 40 Apple tasks
[loaded] 173 Apple tasks
[running] 99 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (2013-09-02) [Support]
[running] com.epson.Epson_Low_Ink_Reminder.launcher.plist (2015-07-03) [Support]
[loaded] com.epson.esua.launcher.plist (2016-08-28) [Support]
[running] com.epson.eventmanager.agent.plist (2015-07-03) [Support]
[loaded] com.oracle.java.Java-Updater.plist (2016-11-06) [Support]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (2016-10-26) [Support]
[loaded] com.apple.installer.osmessagetracing.plist (2016-10-21)
[loaded] com.microsoft.office.licensing.helper.plist (2015-06-04) [Support]
[loaded] com.oracle.java.Helper-Tool.plist (2016-11-06) [Support]
User Login Items: ⓘ
iTunesHelper Applicazione (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Arq Agent Applicazione (/Applications/Arq.app/Contents/Library/LoginItems/Arq Agent.app)
AdobeResourceSynchronizer Applicazione (/Applications/Adobe Reader 8/Adobe Reader.app/Contents/Support/AdobeResourceSynchronizer.app)
laciebackupd Applicazione (/Library/Application Support/LaCie/LaCie Backup/laciebackupd.app)
SpeechSynthesisServer Applicazione (/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesisServer.app)
NoteBookHelper Applicazione (~/Library/Services/NoteBookHelper.service)
Safari Applicazione (/Applications/Safari.app)
AdobeResourceSynchronizer Applicazione (/Applications/Adobe Acrobat 8 Professional/Adobe Acrobat Professional.app/Contents/Support/AdobeResourceSynchronizer.app)
TrapsMonitor Applicazione (/Library/Application Support/hp/laserjet MFP/Trap Monitor/TrapsMonitor.app)
Internet Plug-ins: ⓘ
Flip4Mac WMV Plugin: 3.2.0.16 - SDK 10.8 (2013-09-30) [Support]
FlashPlayer-10.6: 23.0.0.207 - SDK 10.9 (2016-11-08) [Support]
QuickTime Plugin: 7.7.3 (2016-10-21)
Flash Player: 23.0.0.207 - SDK 10.9 (2016-11-08) [Support]
AdobePDFViewer: 8.3.1 (2013-08-14) [Support]
JavaAppletPlugin: Java 8 Update 111 build 14 (2016-11-06) Check version
SharePointBrowserPlugin: 14.5.2 - SDK 10.6 (2015-06-24) [Support]
RealPlayer Plugin: Unknown (2013-08-14) [Support]
Silverlight: 5.1.30514.0 - SDK 10.6 (2015-02-25) [Support]
DirectorShockwave: 12.1.3r153 - SDK 10.6 (2014-06-24) [Support]
iPhotoPhotocast: 7.0 (2013-08-14)
Safari Extensions: ⓘ
1-ClickWeather - TWCi -
http://www.weather.com/" onclick="window.open(this.href);return false; (2015-01-28)
Facebook Photo Zoom - Regis Gaughan -
http://www.regisgaughan.com" onclick="window.open(this.href);return false; (2015-01-28)
searchtab - Roby Strand -
http://www.yahoo.com" onclick="window.open(this.href);return false; (2015-01-04)
ClickToFlash - Marc Hoyois -
http://hoyois.github.com/safariextensio ... ktoplugin/" onclick="window.open(this.href);return false; (2016-10-05)
ClickToPlugin - Marc Hoyois -
http://hoyois.github.com/safariextensio ... ktoplugin/" onclick="window.open(this.href);return false; (2016-11-03)
SaveFrom.net helper - SaveFrom.net -
http://savefrom.net" onclick="window.open(this.href);return false; (2016-10-05)
Translate - SideTree.com - Apps for Mac and Web -
http://SideTree.com/extensions.html#Translate" onclick="window.open(this.href);return false; (2016-01-29)
3rd Party Preference Panes: ⓘ
Adobe Version Cue CS3 (2013-08-14) [Support]
Flash Player (2016-10-26) [Support]
Flip4Mac WMV (2013-03-29) [Support]
Java (2016-11-06) [Support]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: OFF
Auto backup: NO - Auto backup turned off
Volumes being backed up:
Macintosh HD: Disk size: 999.35 GB Disk used: 848.96 GB
Destinations:
Hard disk back up [Local]
Total size: 999.86 GB
Total number of backups: 34
Oldest backup: 24/10/15, 11:49
Last backup: 03/02/16, 11:43
Size of backup disk: Too small
Backup size 999.86 GB < (Disk used 848.96 GB X 3)
Top Processes by CPU: ⓘ
3% WindowServer
2% bird
1% kernel_task
0% fontd
0% com.apple.AmbientDisplayAgent
Top Processes by Memory: ⓘ
1.83 GB com.apple.WebKit.WebContent(32)
1.22 GB kernel_task
492 MB firefox
279 MB Finder
279 MB Safari
Virtual Memory Information: ⓘ
1.99 GB Available RAM
69 MB Free RAM
6.01 GB Used RAM
1.92 GB Cached files
0 B Swap Used
Diagnostics Information: ⓘ
Nov 8, 2016, 03:25:04 PM /Library/Logs/DiagnosticReports/Finder_2016-11-08-152504_[redacted].hang
/System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Nov 8, 2016, 03:07:33 PM Self test - passed
Nov 8, 2016, 01:20:57 PM /Library/Logs/DiagnosticReports/Safari_2016-11-08-132057_[redacted].hang
/Applications/Safari.app/Contents/MacOS/Safari
Nov 8, 2016, 12:26:36 PM /Library/Logs/DiagnosticReports/Adobe InDesign CS5.5_2016-11-08-122636_[redacted].hang
/Users/[redacted]/*/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
Nov 8, 2016, 10:47:14 AM ~/Library/Logs/DiagnosticReports/DiskSpaceEfficiency_2016-11-08-104714_[redacted].crash
/Applications/iBooks.app/Contents/PlugIns/DiskSpaceEfficiency.appex/Contents/MacOS/DiskSpaceEfficiency
Nov 8, 2016, 08:18:00 AM /Library/Logs/DiagnosticReports/Finder_2016-11-08-081800_[redacted].hang
Nov 8, 2016, 07:58:39 AM ~/Library/Logs/DiagnosticReports/quicklookd_2016-11-08-075839_[redacted].crash
/System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/MacOS/quicklookd
Nov 7, 2016, 07:39:48 PM /Library/Logs/DiagnosticReports/Finder_2016-11-07-193948_[redacted].hang
Nov 7, 2016, 03:30:03 PM /Library/Logs/DiagnosticReports/Finder_2016-11-07-153003_[redacted].hang
Nov 7, 2016, 03:29:32 PM /Library/Logs/DiagnosticReports/Finder_2016-11-07-152932_[redacted].hang
Nov 7, 2016, 03:29:32 PM /Library/Logs/DiagnosticReports/Safari_2016-11-07-152932_[redacted].hang
Nov 7, 2016, 03:05:19 PM /Library/Logs/DiagnosticReports/Safari_2016-11-07-150519_[redacted].cpu_resource.diag [Details]
Nov 7, 2016, 08:30:20 AM ~/Library/Logs/DiagnosticReports/quicklookd_2016-11-07-083020_[redacted].crash
Nov 6, 2016, 06:28:19 PM ~/Library/Logs/DiagnosticReports/com.apple.WebKit.WebContent_2016-11-06-182819_[redacted].crash
/System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
Nov 6, 2016, 01:11:55 PM /Library/Logs/DiagnosticReports/com.apple.appkit.xpc.openAndSavePanelService_2016-11-06-131155_[redacted].cpu_resource.diag [Details]
/System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Nov 6, 2016, 08:05:57 AM ~/Library/Logs/DiagnosticReports/quicklookd_2016-11-06-080557_[redacted].crash
Nov 5, 2016, 05:58:34 PM ~/Library/Logs/DiagnosticReports/quicklookd_2016-11-05-175834_[redacted].crash
Files deleted by EtreCheck: ⓘ
Nov 8, 2016, 05:04:26 PM - ~/Library/LaunchAgents/WebSocketServerApp
