La cosa succede molto spesso, ma non sempre, a volte il mac resta acceso per ore senza problemi.
Sapete indirizzarmi e consigliarmi su quale potrebbe essere il problema? Perché ho cercato in rete e qui ma trovo sempre errori diversi rispetto a questo.
Anonymous UUID: 97963E03-9EB3-636F-4A7C-60E84EBA077E
Tue Dec 8 13:37:13 2020
*** Panic Report ***
panic(cpu 14 caller 0xffffff8006d07736): "thread_deallocate: thread not properly terminated\n"@/Library/Caches/com.apple.xbs/Sources/xnu/xnu-3248.60.11/osfmk/kern/thread.c:569
Backtrace (CPU 14), Frame : Return Address
0xffffff817f513e10 : 0xffffff8006cdab52
0xffffff817f513e90 : 0xffffff8006d07736
0xffffff817f513ec0 : 0xffffff8006cf3108
0xffffff817f513ef0 : 0xffffff8006cf6d39
0xffffff817f513f40 : 0xffffff8006cf2a51
0xffffff817f513fb0 : 0xffffff8006dc9117
BSD process name corresponding to current thread: kernel_task
Mac OS version:
15G1011
Kernel version:
Darwin Kernel Version 15.6.0: Mon Aug 29 20:21:34 PDT 2016; root:xnu-3248.60.11~1/RELEASE_X86_64
Kernel UUID: E349749B-3303-3DDF-959C-B5885A0E1F6E
Kernel slide: 0x0000000006a00000
Kernel text base: 0xffffff8006c00000
__HIB text base: 0xffffff8006b00000
System model name: MacPro4,1 (Mac-F221BEC8)
Syst
Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2,26 GHz, 12 GB, SMC 1.39f5
Graphics: ATI Radeon HD 4870, ATI Radeon HD 4870, PCIe, 512 MB
Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030382E4130304C4620
Memory Module: DIMM 2, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030382E4130304C4620
Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030382E4130304C4620
Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030382E4130304C4620
Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030382E4130304C4620
Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030382E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
PCI Card: ATI Radeon HD 4870, Display Controller, Slot-1
PCI Card: pci1b4b,9123, AHCI Controller, Slot-3
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: WDC WD7500AZEX-00RKKA0, 750,16 GB
Serial ATA Device: WDC WD20EARS-60MVWB0, 2 TB
Serial ATA Device: WDC WD10EADS-00L5B1, 1 TB
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Optical Mouse
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Keyboard
USB Device: USB Bus
USB Device: USB 2.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
