- Genio guastatore
faxus ha scritto: ↑sab, 16 giu 2018 19:54
Cestina /Library/Developer/CommandLineTools/
Poi riavvia e riprova, da AppStore.
Fatto nulla ...
Se eseguo
brew update
Already up-to-date.
Se eseguo
brew upgrade
Error: Your Xcode (9.4.1) is too outdated.
Please update to Xcode 10.0 (or delete it).
Xcode can be updated from
https://developer.apple.com/download/more/
Se eseguo
brew doctor
Please note that these warnings are just used to help the Homebrew maintainers
with debugging if you file an issue. If everything you use Homebrew for is
working fine: please don't worry or file an issue; just ignore this. Thanks!
Warning: You are using macOS 10.14.
We do not provide support for this pre-release version.
You may encounter build failures or other breakages.
Please create pull-requests instead of filing issues.
Warning: Ruby version 2.3.6 is unsupported on 10.14. Homebrew
is developed and tested on Ruby 2.3.3, and may not work correctly
on other Rubies. Patches are accepted as long as they don't cause breakage
on supported Rubies.
Warning: Your Xcode (9.4.1) is too outdated.
Warning: Your Xcode (9.4.1) is outdated.
If 10.0 is installed, you may need to:
sudo xcode-select --switch /Applications/Xcode.app
Current developer directory is:
/Applications/Xcode.app/Contents/Developerx
Precedentemente come detto, sono andato anche in
https://developer.apple.com/download/more/ cercando i Xcode 10
- Pro-Expert
Ah, ecco.
Devi disinstallare tutto Xcode.
Non solo CLT.
Con Mojave beta devi installare Xcode 10 beta.
O se l'hai installato cambia la path con l'opzione --switch
- Genio guastatore
Ho provato a disinstallare e re-installare Brew ... ma non cambia !!!
come posso resettarlo per ricominciare da capo ????
- Pro-Expert
Chi ha parlato di disinstallare brew?
Ho scritto, leggi bene, disinstallare Xcode.
Poi reinstallare Xcode aggiornato o i CLT
- Genio guastatore
non dicevo "tu mi hai detto"...
L'ho fatto io per capire se iniziando come fosse nuovo avessi risolto... ma invece no!!!
ora ti chiedo : quali comandi si posso utilizzare per resettare tutto il "sistema brew" ???
- Pro-Expert
Ma non c'entra un tubo...
Il problema risiede in una versione vecchia di Xcode.
Puoi smontare e rimontare brew mille volte, resterà sempre.
Non è connesso a brew, è uno strumento esterno.
Ogni volta che monti brew ti segnalerà l'avviso.
Se, invece, vuoi risolvere il problema (che problema non è, non è un errore, puoi conviverci...) devi eliminare la vecchia versione di Xcode.
È semplice...
- Genio guastatore
faxus ha scritto: ↑dom, 17 giu 2018 14:33
È semplice...
Fatto, ma mi risponde così :
xcrun: error: active developer path ("/Applications/Xcode.app/Contents/Developer") does not exist
Use `sudo xcode-select --switch path/to/Xcode.app` to specify the Xcode that you wish to use for command line developer tools, or use `xcode-select --install` to install the standalone command line developer tools.
See `man xcode-select` for more details.
Error: NaN
/usr/local/Homebrew/Library/Homebrew/os/mac/xcode.rb:154:in `to_i'
/usr/local/Homebrew/Library/Homebrew/os/mac/xcode.rb:154:in `detect_version_from_clang_version'
/usr/local/Homebrew/Library/Homebrew/os/mac/xcode.rb:146:in `detect_version'
/usr/local/Homebrew/Library/Homebrew/os/mac/xcode.rb:116:in `version'
/usr/local/Homebrew/Library/Homebrew/os/mac/xcode.rb:60:in `without_clt?'
/usr/local/Homebrew/Library/Homebrew/os/mac/xcode.rb:51:in `needs_clt_installed?'
/usr/local/Homebrew/Library/Homebrew/extend/os/mac/diagnostic.rb:131:in `check_if_xcode_needs_clt_installed'
/usr/local/Homebrew/Library/Homebrew/install.rb:31:in `block in check_development_tools'
/usr/local/Homebrew/Library/Homebrew/install.rb:30:in `each'
/usr/local/Homebrew/Library/Homebrew/install.rb:30:in `check_development_tools'
/usr/local/Homebrew/Library/Homebrew/install.rb:50:in `perform_preinstall_checks'
/usr/local/Homebrew/Library/Homebrew/cmd/install.rb:242:in `install'
/usr/local/Homebrew/Library/Homebrew/brew.rb:99:in `<main>'
Error: Git must be installed and in your PATH!
Error: NaN
- Genio guastatore
È semplice...
Error: NaN
Error: NaN
- Pro-Expert
Ti risponde così a cosa?
Stefano, ti è chiaro che devi radicalmente disinstallare Xcode dal sistema?
Cosa c'entra brew?
- Genio guastatore
E' stato eliminato xcode, infatti neanche FindAnyFile trova nulla...
se eseguo doctor
/System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/ruby/2.3.0/rubygems/core_ext/kernel_require.rb:55:in `require': cannot load such file -- os/mac/xcode (LoadError)
from /System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/ruby/2.3.0/rubygems/core_ext/kernel_require.rb:55:in `require'
from /usr/local/Homebrew/Library/Homebrew/os/mac.rb:2:in `<top (required)>'
from /usr/local/Homebrew/Library/Homebrew/os.rb:15:in `<module:OS>'
from /usr/local/Homebrew/Library/Homebrew/os.rb:1:in `<top (required)>'
from /usr/local/Homebrew/Library/Homebrew/global.rb:91:in `<top (required)>'
from /usr/local/Homebrew/Library/Homebrew/brew.rb:27:in `<main>'
se eseguo
MacBookAir:~ stefano$ sudo xcode-select --install
Password:
sudo: xcode-select: command not found
- Genio guastatore
Risolto !!!
Grazie Faxus... scusa la rottura
- Pro-Expert
La disinstallazione della copia datata di Xcode ha risolto.
Come sempre un po' di pazienza e un doppio riavvio vanno messi in conto.
Quando si fanno modifiche a livello basso, capita.
Probabilmente le routine e le cache hanno bisogno di ricalcolo...
iStefano ha scritto: ↑dom, 17 giu 2018 15:59
Risolto !!!
Hai le scuse anche da parte del gruppo WhatsApp e del gruppo di iMessage.
- Genio guastatore
fragrua ha scritto: ↑dom, 17 giu 2018 21:50
Risolto !!!
- Pro-Expert
Consiglio ai mastri birrai l'articolo odierno di OSXDaily
http://osxdaily.com/2018/07/05/where-ho ... X+Daily%29
Indica ai curiosi come trovare, col Finder o Terminale, i pacchetti installati con brew.
Tramite il menù Vai > Vai alla cartella...
/usr/local/Cellar/
Si troveranno materialmente i software installati
Egualmente, con Terminale si potrà elencare il contenuto della cartella
Mentre in
opt sono ospitati i symlink.
Quindi se in Terminale cerchiamo lo specifico pacchetto, per esempio
archey
Lo troveremo in opt
Da cui trarrà le informazioni dettagliate stampabili sulla shell con
brew info
