sudo chown -R $(whoami):admin /usr/local
sudo mkdir /usr/local && sudo chflags norestricted /usr/local && sudo chown -R $(whoami):admin /usr/local
csrutil disable
csrutil enable
brew cask search
brew cask cleanup
brew cask list
brew cask list | xargs brew cask install --force
MacBook-Pro-di-Fabio:~ faxus$ brew upgrade
==> Upgrading 1 outdated package, with result:
openssl 1.0.2f
==> Upgrading openssl
==> Downloading https://homebrew.bintray.com/bottles/openssl-1.0.2f.el_capitan.b
######################################################################## 100,0%
==> Pouring openssl-1.0.2f.el_capitan.bottle.tar.gz
==> Caveats
A CA file has been bootstrapped using certificates from the system
keychain. To add additional certificates, place .pem files in
/usr/local/etc/openssl/certs
and run
/usr/local/opt/openssl/bin/c_rehash
This formula is keg-only, which means it was not symlinked into /usr/local.
Apple has deprecated use of OpenSSL in favor of its own TLS and crypto libraries
Generally there are no consequences of this for you. If you build your
own software and it requires this formula, you'll need to add to your
build variables:
LDFLAGS: -L/usr/local/opt/openssl/lib
CPPFLAGS: -I/usr/local/opt/openssl/include
==> Summary
/usr/local/Cellar/openssl/1.0.2f: 466 files, 11.9M
==> Upgrading 2 outdated packages, with result:
binutils 2.26, openssl 1.0.2g
==> Upgrading binutils
==> Downloading https://homebrew.bintray.com/bottles/binutils-2.26.el_capitan.bo
############################################################### 88,7%
Si era scollegato il modem...
curl: (56) SSLRead() return error -9806
Error: Failed to download resource "binutils"
Download failed: https://homebrew.bintray.com/bottles/binutils-2.26.el_capitan.bottle.tar.gz
Warning: Bottle installation failed: building from source.
==> Downloading http://ftpmirror.gnu.org/binutils/binutils-2.26.tar.gz
==> Downloading from http://mirrors.muzzy.it/gnu/binutils/binutils-2.26.tar.gz
==> ./configure --program-prefix=g --prefix=/usr/local/Cellar/binutils/2.26 --in
==> make
==> make install
** /usr/local/Cellar/binutils/2.26: 109 files, 140.3M, built in 23 minutes 11 seconds
==> Downloading https://homebrew.bintray.com/bottles/openssl-1.0.2g.el_capitan.b
==> Pouring openssl-1.0.2g.el_capitan.bottle.tar.gz
==> Caveats
and run
build variables:
==> Summary
** /usr/local/Cellar/openssl/1.0.2g: 1,678 files, 12.0M
MacBook-Pro-di-Fabio:~ faxus$ brew update
Error: /usr/local must be writable!
MacBook-Pro-di-Fabio:~ faxus$ brew doctor
Please note that these warnings are just used to help the Homebrew maintainers
with debugging if you file an issue. If everything you use Homebrew for is
working fine: please don't worry and just ignore them. Thanks!
Warning: /usr/local is not writable.
You should probably change the ownership and permissions of /usr/local
back to your user account.
sudo chown -R $(whoami) /usr/local
Warning: Some directories in /usr/local/share/man aren't writable.
This can happen if you "sudo make install" software that isn't managed
by Homebrew. If a brew tries to add locale information to one of these
directories, then the install will fail during the link step.
You should probably `sudo chown -R $(whoami)` them:
/usr/local/share/man/man3
/usr/local/share/man/man7
Even if this directory was writable when you installed Homebrew, other
software may change permissions on this directory. For example, upgrading
to OS X El Capitan has been known to do this. Some versions of the
"InstantOn" component of Airfoil or running Cocktail cleanup/optimizations
are known to do this as well.
Warning: Your Homebrew is outdated.
You haven't updated for at least 24 hours. This is a long time in brewland!
To update Homebrew, run `brew update`.
MacBook-Pro-di-Fabio:~ faxus$ sudo chown -R $(whoami) /usr/local
Password:
MacBook-Pro-di-Fabio:~ faxus$ sudo chown -R $(whoami) /usr/local/share/man/man3
MacBook-Pro-di-Fabio:~ faxus$ sudo chown -R $(whoami) /usr/local/share/man/man7
To restore the stashed changes to /usr/local run:
'cd /usr/local && git stash pop'
To restore the stashed changes to /usr/local/Library/Taps/caskroom/homebrew-cask run:
'cd /usr/local/Library/Taps/caskroom/homebrew-cask && git stash pop'
==> Homebrew has enabled anonymous aggregate user behaviour analytics
Read the analytics documentation (and how to opt-out) here:
https://git.io/brew-analytics
Updated Homebrew from d0b713c to 7dad182.
Updated 2 taps (caskroom/cask, homebrew/core).
==> New Formulae
apache-brooklyn-cli gdrive meson
apache-flink geode micropython
asciiquarium git-secret mit-scheme
aspectj git-standup mlkit
aws-sdk-cpp git-utils n98-magerun
befunge93 github-markdown-toc no-more-secrets
bookloupe gpx nuget
byteman grt ocamlbuild
certstrap gst-editing-services opentsdb
charm gtk-vnc oysttyer
citus gx parquet-tools
civl gx-go pcb2gcode
cli53 hadolint pelikan
cocoapods hspell percona-xtrabackup
cosi ios-deploy pgtoolkit
cppp ironcli roswell
czmqpp kerl stanford-ner
dasht kpcli swi-prolog
derby kubernetes-helm tile38
docker-clean latexml umlet
dockward launch_socket_server vcs
docutils leaps wallpaper
dssim libguess webdis
dumb liblzf wiredtiger
eris libosinfo yadm
fades llnode zplug
flume mas zsh-navigation-tools
frege-repl mdv
==> Updated Formulae
ace libpointing
activemq librdkafka
activemq-cpp libre
afl-fuzz libressl
agda librsvg
akka libsass
algol68g libslax
allegro libsodium
amazon-ecs-cli libsoxr
ammonite-repl libspectre
android-ndk libstfl
anjuta libswiften
ansible libtasn1
ansible-cmdb libtiff
ant libusrsctp
apktool libuv
app-engine-go-32 libvirt
app-engine-go-64 libvisio
appscale-tools libwebsockets
aqbanking libxml2
arangodb libzip
archey ✔ lldpd
argon2 logstash
aria2 logtalk
artifactory luyten
asciinema2gif mackup
at-spi2-core macvim
aurora-cli mailutils
avidemux mapnik
awscli mapserver
azure-cli mariadb
basex mdk
bash-preexec media-info
bazel mediaconch
beecrypt menhir
bind mercurial
bitlbee mercury
bitrise mesos
blucat metabase
boost mg3a
brew-gem midgard2
buildapp midnight-commander
buku mighttpd2
byobu miller
c-ares minimodem
cabal-install miniupnpc
cadubi miruo
cake mitmproxy
calabash mkvtoolnix
camlp4 moc
camlp5 moe
carina mogenerator
carthage mongo-c
cassandra mongodb
ccache monit
ccze moreutils
cflow mosquitto
cfr-decompiler mpd
cfssl mpfr
cgrep mpg123
chadwick mpop
chapel mpv
charm-tools mstch
cheat mutt
checkstyle mycli
chruby-fish mysql
clamav natalie
clojurescript ncmpcpp
closure-compiler ndpi
cmake neko
codequery neo4j
conan neofetch
confuse newsbeuter
consul nexus
consul-template nghttp2
coq nginx
corectl nifi
couchdb ninja
cpp-netlib node
cppcheck node-build
cppformat nodebrew
cputhrottle nomad
cryptol notmuch
crystal-lang nss
cscope ntl
cucumber-cpp nuxeo
curl nvm
daemonize ocaml
darcs ocamlsdl
datomic ola
dbus-glib olsrd
dcadec opam
ddrescue openshift-cli
deheader openssl ✔
deis openvpn
deisctl optipng
dependency-check orientdb
desk ossp-uuid
devd owfs
devil p0f
dfmt p7zip
diff-pdf pacapt
diff-so-fancy packer
direnv pandoc-citeproc
disco pandoc-crossref
dlite parallel
dmd passpie
dnsmasq pastebinit
docbook-xsl pazpar2
docker pcap_dnsproxy
docker-cloud pcre2
docker-compose pdf-redact-tools
docker-machine pdf2htmlex
docker-machine-parallels pdns
docker-swarm peco
dockviz perl
doctl pgpdump
doitlive pgroonga
dovecot pgrouting
dspdfviewer pjproject
dub planck
duplicity plantuml
duply platformio
dwarf plowshare
dwdiff pngcrush
ecl pod2man
editorconfig points2grid
efl ponyc
elasticsearch poppler
elixir postgis
elixirscript postgresql
elm postgrest
embulk ppl
emscripten premake
entr prips
eralchemy prometheus
etl protobuf-c
euca2ools purescript
euler-py pushpin
exempi pyenv
exercism pyenv-virtualenv
expat pygobject3
exploitdb pypy
fastd pyqt5
fcitx-remote-for-osx pyvim
fetch-crl qbs
ffind qd
ffmpeg qemu
file-roller qscintilla2
fish qtfaststart
fleetctl quazip
flow racket
fluent-bit radare2
flyway rakudo-star
folly rancher-compose
fontforge re2
ford redis
fourstore redpen
fpp remake
freeipmi rethinkdb
freeling rocksdb
freetds rt-audio
fribidi rtv
fswatch ruby
fwup ruby-build
fzf rust
galen saltstack
gammu saxon
ganglia sbcl
gawk scalaenv
gconf scriptcs
gd sdl2_ttf
genders selenium-server-standalone
getmail sflowtool
gexiv2 shadowsocks-libev
ghc shairport-sync
ghostscript shellcheck
gifify siege
gimp signing-party
git sile
git-annex sip
git-cola skinny
git-ftp slackcat
git-lfs slimerjs
git-secrets smali
git-vendor snapraid
gitbucket sngrep
gitlab-ci-multi-runner solr
gjstest sonar
glbinding sops
glide sourcekitten
gnatsd sphinx-doc
gnu-smalltalk sqlcipher
gnu-tar sqlite
gnu-units sqlmap
gnupg2 squid
gnustep-make squirrel
gnutls srtp
go sshrc
goaccess sshuttle
godep sslscan
google-benchmark ssreflect
googler stanford-parser
gor stash-cli
gost storm
gpg-agent stunnel
gphoto2 stuntman
gradle subnetcalc
grails subversion
graphite2 svtplay-dl
grib-api swagger-codegen
groonga swift
gst-libav swiftlint
gst-plugins-bad syncthing
gst-plugins-base syncthing-inotify
gst-plugins-good sysdig
gst-plugins-ugly szl
gst-python tailor
gst-validate tarantool
gstreamer tee-clc
gwenhywfar telegraf
gwyddion terraform
h2o texmath
haproxy the_platinum_searcher
harfbuzz the_silver_searcher
haskell-stack thefuck
hbase theharvester
hebcal tidy-html5
henplus tika
hg-flow tinc
hive tippecanoe
hledger tmux
hqx tomcat
htop ✔ tomcat-native
http_load tomee-jax-rs
httping tomee-plume
ibex tomee-plus
icdiff tomee-webprofile
ice trafficserver
icu4c translate-shell
idnits treeline
idris typesafe-activator
imagemagick u-boot-tools
imapfilter ucspi-tools
imapsync uhd
imgur-screenshot unar
imlib2 uncrustify
infer unifdef
influxdb unittest-cpp
ipfs unixodbc
irrlicht usbmuxd
jboss-forge v8
jenkins vault-cli
jetty vdirsyncer
jfrog-cli-go vim
jlog vnu
jmeter vorbis-tools
jruby vowpal-wabbit
jsonnet vte3
juise vultr
juju watchman
kafka wavpack
kapacitor web100clt
karn websocketd
keybase weechat
khal wine
khard winetricks
kibana wireshark
kobalt x264
kore xapian
kotlin xctool
kubernetes-cli xonsh
kvazaar xplanet
lablgtk xplanetfx
lastpass-cli xxhash
ldc yafc
libarchive yaws
libart yaz
libbluray youtube-dl
libcdr yubico-piv-tool
libcouchbase zebra
libfabric zimg
libgcrypt zint
libgpg-error znapzend
libgphoto2 zorba
libksba zpaq
libmarisa zsh-completions
libmspub zsh-syntax-highlighting
libphonenumber zzuf
==> Renamed Formulae
beanstalk -> beanstalkd letsencrypt -> certbot
d-bus -> dbus screenbrightness -> brightness
heroku-toolbelt -> heroku
==> Deleted Formulae
cowpatty eet gambit-scheme sam2p tokyo-tyrant
csync eina gasnet sickrage ttytter
cvc4 embryo libtorrent tegh xsp
discodex evas rtorrent tinyscheme
chown /usr/local/bin/root
ammonite-repl mal4s skinny
gitlab-ci-multi-runner offlineimap texmath
glew opencsg wallpaper
gource orientdb wartremover
jenkins protobuf-swift winetricks
libtiff pup
logstalgia scour
